Question about Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Color quality for vcr films very dark and will not adjust to bright
We have many vcr's and many will not show and are to dark to see
  • wally_now May 09, 2009
    the TV brand is SONY KDL-32NL-140 the .The player is a Emerson VCR & DVD The DVD has no problem bur many of the vcr tapes are so dark they can't be watched,however they work on our other TV ??
    Hi, Actually it is hooked up to the coaxel cable, I have tried the red,white and yellow combo wire and then get no signal notice. I also tried just the yellow while the coaxel cable is connected. The thing is that some videos play O>K> and others do not. But they all are OK on our older TV and VCR player.??
  • 10,594 Answers
Please provide details of VCR problem like what is model and brand of VCR and TV.
Do you see clear and bright picture in TV with other sources like DVD Player, cable etc.
Hit "add a comment" button to reply.
Thanks.
Posted on May 08, 2009
  • Shahid Electronics
    Shahid Electronics May 09, 2009
    Thanks for reply / updates.
    I think VCR/DVD combo is connected via Component video input in TV, if it is, please use Composite video (yellow) wire connection to test VCR result on this Sony TV or let me know how VCR/DVD combo is connected with TV? what input is being used in TV for that.
    Thanks.
    Please connect Combo with Yellow-Red-White cable at Input-1 of TV and select that input-1 in TV Menu with TV remote to get picture of Combo.
    Also set video settings of TV in Menu while playback VHS tapes in Combo to get brighter picture.
    Thanks.
How to adjust color on sk-32h570d
This is from the MANUAL
www.westinghousedigital.com/pdf/197_User_Manual.pdf
PAGE 27
A-1 Settings
Use the Settings sub-menu options to manually adjust the display quality. Use the ◄/► keys to adjust the
option level.
Adjust the luminance level.
Adjust the brightness to darkness ratio.
Adjust the balance of the red, green, and blue colors in the display.
Adjust the color intensity.
Adjust the sharpness or softness of the display.
Adjust the brightness level of the screen backlight.
AND this is from the troubleshooting procedures in the manual
PAGE 64
Wrong, abnormal or missing colors
・ If any colors (red, green or blue) are missing, check the video cable to make sure it is securely connected. Loose or broken pins in the cable connector could cause an improper connection.
・ Press and select Picture | Settings to adjust the Hue and Saturation settings. You can also select
Picture | Advanced to adjust the Color Temperature settings.
・Connect the TV to another computer and check if the problem is with the computer screen.
Other than that there is no mention of color adjustment
May 08, 2009 | Westinghouse Electric SK-32H570D 32 in....
Dark Color on TV. Can't adjust the color correctly
Having same problem now for a second time on a 57T500. First time was a bad green bulb that was covered under warranty. Only lasted 2 years....currently debating wether to fix or buy a new set. Bulbs cost about $300. Set is only 5 years old, so very dissapointed with quality.
Feb 01, 2009 | Hitachi 57F500 57" Rear Projection...
Dark scenes are impossible to see
This is a fundamental limit of Ti DLP. The part can not reproduce low grey scale, so low light film is dominated by artifacts. It helps to sit farther away from the screen. The color shift is caused by a factory tollerance on the color wheel, but there is no user adjustment for it.
Sep 10, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Adjusting darkness
Hi Angel,
Are you really sure , your set has video? How dark is it ? As if really nothing visible? Am, sure you can hear sounds. You can adjust the brightness + button to increase the brightness. But if nothing happens , you have problem with your TV set. The problem might be in the Video section. Please let an expert technician to check it. Please don't do it by yourself, it's risky.
Please send feedback whatever comes up. So we can help you further in the future.
Thanks,
Eriez
May 26, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Dark picture
**WORKS**
In my case, the adjustment was available from outside the TV. Sortof. On the rear of the TVabout 2 inches to the right of the coax in, there are two vertical slits on a little protrusion. Inside the slits are the two adjustment screws. The lower screw adjusts brightness, the upper screw adjusts focus.
Nov 23, 2007 | JVC AV-27S33 27" TV
Need to find out how to adjust color
im curious why you think you need to ajust the color do you have red screen? or missaligned colors?
If your B&W images look okay (bright and dark areas), either films, ads,
or turing the color off, you shouldn't tinker with grayscale
adjustments. You'll really mess up your set. Haven't seen many
complaints about 'red push' with Pioneers, but that may be the problem.
A further check would be the decoder test on the Avia disc. Also visit
http://www.hometheaterspot.com/ and search the Pioneer section for
similar complaints.
Nov 16, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Edge Enhancement Option Disabled...
edge enhancement option i think would be enabled if you are in dynamic or movie mode. What it does is to enhance the contrast of the edges of 2 different colors.
I have the LA32S8, similar specs but only 7000:1 CONTRAST ratio. when playing dvd, i set it to movie mode. Settings vary on different tv and player. you can adjust first the backlight, then brightness then contrast, color and sharpness. the brightness you adjust by choosing the level that shows enough details on dark scenes. adjust if its too dark not to see the details of the scene. contrast, you can set by distiguishing vivid colors of the picture, dont put too much contrast as your picture would look flat. it should have a 3d look, same also with sharpness, you can experiment on the face of a person to show details on the edges.
color you set just enough to make it accurate on color reproduction.
My settings for movie are
contrast 92
brightness 49
sharpness 23
color 57
tint g48 r52
backlight 7
tone warm1
digital NR off
black adjust high
dynamic ocntrast high
gamma +2
edge enhancement on
color space auto
Oct 05, 2007 | Samsung LN-S3241D 32 in.LCD HDTV
HP scanjet 4370 focus problem
adjust the brightness resolution or default settings for scanner while scaning. Also read the manual of the scanner.
Aug 25, 2007 | HP Scanjet 4370
Picture too dark
There are only 2 chips for colour convergence in this unit. there is also a screen control on each tube but most of all there is a bleeder assy. that can control the brightness.
Dec 14, 2006 | Toshiba 57H82 57" Rear Projection...
Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
