Question about Vehicle Parts & Accessories
Ford escape v6 timming marks
Vehicle jerking after engine overhaul
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 90 Answers
Timing marks do not line up after you rotate the engine. What they do is have an even number of teeth on the gears and an odd number of teeth on the belt. If they were both even, the belt would wear down quicker from the gear hitting on the same spot. When you rotate the engine over one time you will see the mark on the belt moves one tooth ahead. With each rotation it moves farther away.
Posted on Nov 28, 2013
WHAT IS SYMPTOMS OF ILL OPERATING DISTRIBUTOR.WHAT IS THE CORRECT SPARK PLUGS FOR 2002 FORD BANTAM 1.6I .SHOULD I USE COPPER WIRE OR CARBON PLUG LEADS.
using a timing light, watch the light on the timing mark and if it is all over the place and not steady on the mark then that indicates a worn shaft and bushes in the distributor
use carbon resistance plug leads that have thick insulation( (not el-cheapo leads ) modern plugs are designed to run carbon leads
run the fault codes as the problem may be in the air /fuel control sensors and not the distributor or crank. cam position sensors
May 07, 2017 | Ford Cars & Trucks
02 ford escape V6 what is positions of the camshaft sprocket timing marks and the crankshaft keyway
The camshaft and Crank mark (key way) should be pointing at each other (directly aligned with each other).
ie. The Camshaft mark will be point directly downward toward the crank and the crank mark (key way) will be pointing directly upward toward the camshaft.
Nov 16, 2014 | 2002 Ford Escape
Ford engine troubleshooting
have the throttle position sensor checked
Jun 13, 2017 | 2003 Ford Escape
Ford escape jerking after engine overhaul
Sounds like it may be short of fluids. Also recheck all the small hose connections for leaks.
Nov 27, 2013 | Vehicle Parts & Accessories
Hi, I have a 2001 Ford Escape XLT V6. It has been jerking intermittently while driving and for a couple days my check engine light was on but then turned off. Code P0305 came up on the reader saying...
Take the cover off the engine, there you will view below you three coils, disconnect the wire from the middle one only after disconnecting the battery, disconnect the wire harness to that coil, remove the not securing that with a 5/16 socket trhen pull straight up, replacement is opposite removal.
Mar 29, 2011 | 2001 Ford Escape
2005 ford escape xlt awd v6, vehicle "jerks" as it accelerates from 0 to about 40mph. First few "jerks" are hard then then get a little smoother, until 40 mph is reached. When slowing...
Ford Escape - ConsumerAffairs.com
www.consumeraffairs.com > Automotive > Auto Manufacturers
Rating: 1.3 - ‎59 votes I have had my 2005 Escape 8 years. .... Ford Escape Limited 2010 - V6 AWD ....Brought my vehicle for 15T kms servicing and reported a jerking when I am ..
Jan 18, 2011 | 2005 Ford Escape
I'm russian. I've got Ford Escape XLT 2005 v6 3.0 and I can't find engine sequence/engine number/or product sequence number on the engine. Please, help me to find it.
we have the same problem here in spain with american built vehicles ,When i come to do the paperwork and their is no engine number and the spanish authorities insist on numbers on everything and three copies of it all with stamps on.So when i get a crysler gran voyager or ford mercury with no chassis number stamped in the actual chassis ,just a silly plate in the dash which means nothing here .I do a bit of doctoring before the vehicle goes for its mechanical inspection and they evan measure it for height and width and length and they look for the stamped chassis number which on all american vehicles i take to the test and they are always in the same place .Drivers side on top of suspension ,and engine number stamped on a nice area of the block,thats accessable ,if no engine number exists then use the last 6 numbers of the chassis number .----know what i mean
Nov 05, 2009 | 2005 Ford Escape
Car dose not start after installing timing chains
You didn't by chance hit or move crankshaft position sensor when doing other work. (Behind crankshaft pulley)
Jan 22, 2009 | 2002 Ford Escape
I have a ford escape 2001 v6,water was fulled in the tank
if it runs without overheating issues but doesn't move forward or reverse....check your transmision fluid level...if its too low the vehicle won't move but the engine will run just fine.
Jan 16, 2009 | 2001 Ford Escape
Vehicle Parts & Accessories Logo
54 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
