When system on continuous beep - Computers & Internet
  • Computers & ... Master
  • 27,725 Answers
Power supply, system board, or keyboard problem
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines or a can of compressed air.
Dust causes static which causes lots of problems with a computer and its parts
you might have to uninstall your keyboard restart your computer then reinstall it
Make sure the batteries are fully charged and have good seating points (if applicable) corrosion
Make sure the ps2 lead connection is secure and dust free (if applicable)
Make sure the usb device is inserted correctly into the usb port (if applicable)
Click start control panel administration tools computer management device manager scroll to keyboards also mouse you might see a yellow exclamation or question mark ! ? or red x you will need to update driver right click to update driver
If your computer came with a motherboard disk the drivers could be on it
Troubleshoot a Motherboard
Motherboards are an important part of your computer.
They enable it to function, and they're an integral piece of your hardware.
If you want to avoid the costliness of hiring a professional to troubleshoot and repair your motherboard, you need to learn the best way to figure out the problems yourself.
Back up everything possible on your hard drive.
If you're experiencing hardware issues, this is a luxury you might not have.
Keep backup files on an alternate data storage system to avoid data loss during hardware problems.
Notice the issue and reproduce it so you're aware of where the symptom manifests itself.
Isolate the problem.
If the system isn't getting power, make sure it's not the power cord or wall outlet before you try a different motherboard.
If everything is trying to run but not actually able to, check for loose parts on the motherboard before you replace it.
Remove all of the hardware that isn't actually necessary to make the computer function before you can narrow down the causes for your problem to the motherboard.
Try another compatible motherboard in your machine once you've eliminated all other potential problems-ok If it works with the alternate motherboard, replace the old one.
To check the motherboard for faults first check all the capacitors,IC(i.e. the small black coloured chips you see on the motherboard).
Identifying bad capacitors
http://www.youtube.com/watch?v=ngA4k32jLGc
If any of them is blown off or swollen on burnt then you have to change it by calling a good computer engineer.
Check the slots of the RAM clean them by a 1 inch broad painting brush and also clean the RAM by an ereaser.
If the problem is due to the slots then sorry you have to change the motherboard.
The simptons that the RAM slots are faulty is the buzzer on the motherboard will start beeping continuosly.
One thing also check the CMOS battery that small one on the motherboard I hope you know that battery.
If that battery is down change it and try.
Posted on Nov 28, 2013
Low battery mess changed it and still continues to beep how do i fix
Power your system down first. Plug in the battery, the panel should beep, then plug in the AC power. If the panel doesn't beep you might have a bad battery. If the panel powers up after the battery then AC power reset your time and the beeping should stop.
May 16, 2014 | GE Security Simon 3 Wireless Home Security...
Lenevo t61 1 long beep and 2 short beeo no display
Standard Original IBM POST Error Codes 1 short beep Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Nov 09, 2012 | Lenovo ThinkPad T61 6457 Notebook
My pc is booting but no display
Did you check your monitor with other system or individually. If it works fine in these conditions then the issue belongs to your pc.
First of all, you have to confirm that is it the problem of VGA itself or the motherboard. For this, you have to see that does system beep when you start it because system with beeps having the error and the beep sound with continuous or 2-3 beeps relate with different issues. I am going to write down the beep conditions.
best of luck!
Mar 13, 2012 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
No signal on monitor, vga tested and ok
Mar 11, 2012 | Computers & Internet
Winwos doesn load freezes
how many beeps... what kind of pc? below is the standard beeps codes with the the issue.
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Jun 18, 2010 | Western Digital My Book Home Edition 500...
Continues beeping
did you leave it plugged in to let it charge? ups's will beep continuosly till they are charged, if it has dead battery packs inside, it will continue to beep because there is no battery charge to support its job. leave it plugged in for 2 hours. if it doesnot stop beeping, toss it and get a new ups
Jun 04, 2010 | CyberPower 575SL (CPS575SL) UPS System
IBM ThinkPad 600X continuous beeping
Hi...
Continuous beep usually mean problem with the memory module.
Get it checked.
Thanks
Smith
Aug 09, 2009 | IBM Computers & Internet
Iam using lennovo y410 series.my lapton suddenly making some beep sound continuously on running and its not getting turned off. i removed battery and shutted down,i have been running laptop continuously ...
1 short beep
Feb 22, 2009 | Lenovo 3000 Y410 Notebook
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
