Question about Panasonic Microwave Ovens
Panasonic microwave will not power on
Will not power on
    Top Expert:
  • Panasonic Master
  • 12,223 Answers
Follow this steps and fix it. God bless you
  1. Inspect the power cord Unplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switch If your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fuses To determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motor Locate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Posted on Nov 27, 2013
Panasonic genius prestige microwave won't turn
If power is supplied to turntable motor yet it does not spin, then replace the motor.
Dec 28, 2017 | Panasonic Microwave Ovens
No power to my Panasonic microwave
assuming u have pwr to the plug - and nothing lights up = it is probably a bad transformer - open thermal fuse.
WHICH was probably caused by a shorted mag, which means junk.
Feb 02, 2016 | Panasonic Genius Prestige Inverter...
Dead panasonic microwave oven
We recommend you unplug the unit's power cord and test a different outlet. If the problem persists, please use the below link to locate an authorized service center.
www.panasonic.com/repair Welcome to Panasonic Online Repair
Apr 02, 2014 | Panasonic Microwave Ovens
Panasonic NN-651W microwave gone dead
There si a place called encompass parts that is a distributor for Panasonic, Look them up or call them with your model number and check price and availibility on the PCB
Oct 18, 2017 | Panasonic Microwave Ovens
My Panasonic Genius Prestige model microwave is in the "Demo" mode and will not operate. How to fix it?
RESET THE SYSTEM BY UNPLUGING THE MICROWAVE CORD FROM POWER FOR 30 SECONDS, CONNECT BACK TO POWER IF THE MICROWAVE CONTINUE WITH THE PROBLEM MAY HAVE A BAD CONTROL BOARD OR BAD ELECTRONIC CONTROL PAD...
Feb 19, 2011 | Panasonic NN-SD797S Microwave Oven
Discussion on the appearance, aesthetics, form and colur
Hello dutch.
This is an excellent microwave, over the range, white only. Here is a link to all of the features, and even the owner manual http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Microwave-Ovens/Over-the-Range-Microwaves/Technical-Specification/model.NN-S254WF.T#ts
Microwave Type: Over-the-Range Cooking Power: 1200 Watts Capacity: 2 cu. ft. Convection Cook: Without Convection Cook Dimensions Exterior Depth: 15 in. Exterior Height: 9.5 in. Exterior Width: 23.25 in. Miscellaneous Product ID: 22541798 More Information Details: Over the Range Microwave with Panasonic Inverter Technology provides true multiple power levels. When the user asks for 60% power, the oven delivers a true 60% power, not a pulsed delivery of 100% power 60% of the time. This method is called linear power delivery
Dec 08, 2010 | Panasonic NN-S254WF Microwave Oven
1200 watt panasonic, power on but will not perform
Hello :
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
best regards .
please don't forget to rate !
Apr 04, 2010 | Panasonic NN-S262SF Microwave Oven
Panasonic NN-CD997S microwave
i have microwave problems power trip when switch on the unit. please help me.
Jan 06, 2010 | Panasonic Microwave Ovens
Panasonic nn-s558ba microwave won't power on
Lee,
Have Landlord replace unit after verifying that outlet has power.
In the future, follow manufacturer's cleaning instructions and DO NOT
run microwave without something in it (even a microwave safe cup of water).
Larry Hanson EH&S Specialist
Apr 04, 2009 | Panasonic NN-S558BA/WA Microwave Oven
Microwave Ovens Logo
37 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
