Question about John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter
John deere rx75 deck pitch - John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter
  • 21 Answers
SOURCE: john deere stx38 wont move transmission locked up?
Engine OFF, raise drive wheels and check if transmission is locked
Posted on Jul 14, 2009
farmerbear
  • 490 Answers
SOURCE: need mower deck belt diagram for L-130 John Deere
I have found the manual at JD's website. Click the link and scroll down in the left column until you find the heading for replacing the belt. I contains big, clear photos. Here is the link:
http://manuals.deere.com/cceomview/OMGX21647_K3/Output/Index.html?tM=HO
You can copy it into your browser window or type it in. I sure hope this helps you out. If I can be of any further assistance, please let me know:)
Posted on Aug 21, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Replaced transmission on my John
Hi and welcome to FixYa, I am Kelly
This is a generic response to all John Deere Variator linkages but most likely what you must do with a transmission change.
To adjust the "Variator linkage" do the following.
1. Pry off the buttons on the side that cover the access holes located just below the variable speed lever.
2. Put the variable speed lever in notch #5.
3. Loosen cap screw one or two turns. This is located inside the hole.
4. Disconnect and ground the spark plug.
5. Turn ignition key to crank engine until clutch-brake pedal raises as high as it will go.
6. Take up linkage slack by pushing down on cap screw (see step #2). Tighten cap screw.
NOTE: If the tractor won't move with the variator in the first notch after these adjustments then the primary drive belt needs to be replaced.
I am concerned that maybe you did not connect the linkage properly but you have to do the above steps if no matter what you do you only have slow speeds.
Posted on Apr 22, 2011
  • 252 Answers
SOURCE: i need a diagram that
hi there pauly46 here
type f725 in the search box - under j/d cataloue
here is web site adress to go to that page
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt?search=model&model=f725
select f725 ,select sectional index , select mower deck and lift linkage,select mower drive belts sheaves and spindles ,
then a window with deck parts and diagram will appear
print this off
it will give a good idea of belt routing for deck
take a look and hope it helps
cheers pauly46
Posted on Apr 30, 2011
  • 24 Answers
SOURCE: need belt routing for 48 inch john deere mower
Go to john deer dealer they should be able to print u of that diagram for you.
Posted on Sep 14, 2011
What type of oil does it use? John Deere RX75
some use straight 30 some 5-30 others 10-30 jd has their own oil as well the following chart showes the type
May 12, 2016 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
Keep burning up deck belts on 20yr old John Deere rider rx75. What size belt should I be using
1/2 x 60
Check all deck idler pulleys and make sure no bad bearings or flat spots
Apr 24, 2015 | John Deere Garden
My rx75 runs well but will not engage the deck is it electronic?
The mower deck is 100% manually controlled with the yellow control handle. The linkage may be out of adjustment a lot, especially if new belts are now broken in. When engaged, the blade drive belt should be quite taunt,but not like a banjo string. Adjustment is easy and can be found on the operators manual.
Jun 18, 2014 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
John deere rx75 adjust belt tension
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Apr 21, 2014 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
I have a John Deere rx75. The mower deck seems to be too low when I set it at the highest position. I have no idea how to do that or to level the deck. Please help. The lawn is cutting uneven and its...
find someone who can read and use the internet
go to www.google.com
search for john deere lawn tractors
go to the john deere website and click around under "support" until you find the manuals
download a manual for your model,l but they are all about the same
have the person who can read, read you the part in the manual about adjusting the deck height and how to level it.
there you go, bob's your uncle.
Sep 19, 2011 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
John deere rx75 belt routing diagram
I found manual on amazon... so you can take a look there Amazon com john deere rx75 manual. I hope this was helpful. cheers
Jun 19, 2011 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter Logo
26 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
