Question about Frigidaire Dishwashers
Latch cover on dishwasher soap dispenser no longer functions.
Latch is stuck in open position preventing proper use of soap dispenser. Visual inspection does not show anything broken, perhaps stuck with dried soap?
  • marymena May 09, 2009
    This helped tremendously, the latch is functioning again! Thanks.
  • Anonymous Mar 23, 2014
    soap dispenser problem
  • 68 Answers
Hello there. i hope i can help you?. please check the latch spray a little wd40. and give the soap dispenser. a good clean with warm water. please check that you are useing the correct soap? as this can cause alot of problems. check once a week.top tip give the machine a good clean once a month. i hope this has helped you marymena? also please check for any little obstructions.
Posted on May 08, 2009
The soap dispenser only closes after several tries. At the end of the cycle, the soap is wet and stuck in the open dispenser
May want to try liquid detergent instead. Sometimes using too much detergent will prevent the dispenser from opening and then the soap turns into a wet glob in the dispenser.
Mar 15, 2016 | Dishwashers
Soap dispenser doesn't open
How many cycles have you attempted? It may take a few cycles before the detergent pack becomes soft enough to run out and allow the latch to function properly.
Otherwise, if you can reply back with additional information such as model number, someone here on Fixya will be able to provide assistance.
Best regards,
Feb 11, 2018 | GE Dishwashers
Ge nautilus dishwasher 165d5450p004 latch won't close
RoselsRose,
Thanks for the info about your grandson coming bye the dishwasher and messing with the dial! My son (14 month old) did the same thing and the soap dispenser door/latch would not stay closed. It just kept springing back open. I thought for sure the latch was broke until I saw your post and went to the outside dial and brought it back to off. Sure enough, the soap dispenser door stays closed. You just saved me an expensive repair! Thanks!
Sep 26, 2012 | Dishwashers
My soap dispenser is stuck closed cant open it
The soap door has a latch to open it. Pour some warm water on it with the machine door completely open to melt old soap around dispenser. Read instructions on door.
Jan 31, 2011 | Dishwashers
Soap dispenser cover latch will not stay in the hole. So now the soap holder will not stay closed.
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Jan 31, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Soap dispenser will not close stays open will not latch
Turn off power to the machine. Remove the inner door panel and inspect the dispenser cover latch for any broken components. If everything looks ok, check the action of the release solenoid by hand. If it is sticky or stuck closed, try removing the center pole piece and clean the solenoid interior and pole piece with a small rag or 'Q tips' with WD40. Don't otherwise lubricate the solenoid. Push the cover closed and push the solenoid pole to release the latch, then repeat the process again. If the cover will latch again, you can replace everything and try a load of dishes. Hope this helps
Mar 29, 2010 | Bosch Dishwashers
The some dispenser and the rinse aid dispenser seem to be "stuck", soap door doesnt open and dishes appear streaky from no rinse aid. this happened after I cleaned the deposits from under the screen in the...
There is a solenoid which pops open the soap lid after the initial rinse.
If the solenoid or soap lid latch is faulty, you will need to replace it. In the interim just poar your soap in the bottom of the dishwasher tray before cycle starts.
Only use a little amount as per normal. Dishwashing tablets are best as it is a measured amount and has the rinse aid built in.
Good luck.
Ash
Oct 21, 2009 | Bosch Dishwashers
During dishwasher cycle soap dispenser won't open. at the end the soap tab is lying on the floor of the dishwasher.
Remove the door inner panel and check the dispenser door solenoid for free movement along with the latch mechanism. Water can enter through a leaking seal and corrode the interior of the solenoid causing sluggish or non-functioning of the latch. Change the solenoid if it seems sticky and can't be fixed by cleaning the bore and plunger (don't apply oil as it will gum up the operation after a while).
Oct 18, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Soap dispenser
A wax motor controls the opening of the lid. Also a seal that fits around the latch lever may be deteriorating and obstructing the function of the lever. Follow the link below for images and part numbers with cost.
Item# 1405...$20.30
Item# 1434...$ 3.95
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Jun 04, 2008 | Maytag 24 in. DWU9202 Built-in Dishwasher
Soap door latch won't latch close
Make sure the dial that you turn to start the dishwasher is all the way to the beginning. Sometimes my little grandson comes by and plays with it, turning it. I load, add soap and the dispenser won't close. I check the outside dial, and sure enough, set it to the very beginning and the dispenser locks in place!
Nov 04, 2007 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
665 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
