Home | Tasco | Specialty 25x30 1AGST Brass Spyglass Tel... | Trash inside my mon...
Tasco Specialty 25x30 1AGST Brass Spyglass Telescope
Problem for Tasco Specialty 25x30 1AGST Brass Spyglass Telescope
Trash inside my monocular
By jmoraleso on May 08, 2009
I have a tasco 1 AGST speciality 25x30 and has little things inside my cuestion is: can I could desarme it to clean it? if I can how I do it?
Solution #1
posted on Jul 13, 2009
Not Rated)
cb1997
Rank: Master
Rating: 80%, 13 votes
The previoust reply of How to clean is very good.  However, it does not answer your question of how to disassemble it.  It's pretty easy to take apart and get back together again.  Removing all the dust is always a challenge outside a lab.
To access:  Hold the body/front lens with one hand and unscrew the knurled ring toward the back/eyepiece end with the other.  It shouldn't be very tight, as the main tube is plastic.  Hopefully this is where the dust is.  From here, you can clean the inside of the largest (objective) lens, and one side of the "second" lens.  (This is the lens you can see through the objective lens).  Due to design, this area is most susceptible to dust every time it is extended for use, as the felt shims do not fully circle the inside of the brass tubes.  There is a good quarter inch end gap for air/dust flow on each felt.
If you still have dust after assembly:
The eyepiece is threaded to a small ring that threads into the smallest brass tube, and there are two lenses inside in a plastic holder, with a spacer to hold them apart.  This may come apart as an assembly, or like mine, the eye lens will be ready to fall out. (BTW, the lenses curved surfaces face each other). When re-assembling, thread this assembly to the brass eyepiece finger tight so the eye lens doesn't rattle.  Set it aside.  Looking down the smallest brass tube, you will see a lens at the bottom.  This is the other side of the "second" lens you cleaned earlier.  When clean, thread the eyepiece assembly back into the brass tube.
If this was performed under lab conditions, all is clean.
Charles
Was this helpful?
Yes
No
Solution #2
posted on May 16, 2009
Not Rated)
Joe L
Rank: Guru  Binoculars & Telescopes  Expert
Rating: 89%, 223 votes
Blow it out with canned air-- if the lens is dirty follow these instructions--
http://www.televue.com/engine/page.asp?ID=143
Was this helpful?
Yes
No
Popular Solutions for Tasco Specialty 25x30 1AGST
Questions and Unsolved Problems for Tasco Specialty 25x30 1AGST
Do you recommend Tasco Specialty 25x30 1AGST Brass Spyglass Telescope?
Answer
Answer
i have a micronta electric powered zoom telescope 12x-40x-40mm cat. no. 66-203 ----- electric does... (More)
Answer
What is the voltage and battery number for a Tasco red dot Propoint PDP2
Answer
What is the voltage and number of the battery for a Tasco red dot Propoint PDP2
Answer
I purchased a bushnell 78-5500 and i don't have a manual and i can't mount it How can i mount it or... (More)
Answer
I would like to find an instruction manual for this telescope. Any ideas where to look? Want to... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Tasco Specialty 25x30 1AGST...:
Top Telescope Experts
Rank: Guru Guru
Solutions: 1364
Experience: I have been solving problems and fixing things for over 30 years!
Ask Me
Find more Telescope Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
