Does not read the water level
Sumsung Fussy 9.2 kg Model WA1065D1IW/XFA Serial: 51ABC00047D does not want to read the water level selected keeps on adding watre
    Problem Solver:
  • 12 Answers
To fix this you have to unplug unit and open back cover behind knob and look for small round sensor with small hose attached if you are able and knowledgably of doing this unhook hose from sensor and blow into it and see if it bubbles or it is clogged. And try to run machine when unhooked see if water still fills if so you may have bad level sensor. to conform blow into sensor where hose connected and see if error show up if none you have bad sensor, oh machine needs to be on when checking for error codes. If you don't feel comfortably with doing this contact 1800 Samsung and see if you can try to get them to come out.
Posted on Nov 27, 2013
2 Suggested Answers
  • 6277 Answers
SOURCE: I have a magic chef 10.1 kg super capacity heavy
(pre-typed for hot AND cold!)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Posted on Oct 08, 2011
I have a defy laundromaid. The machine doesn't reach the correct water level to start the washing cycle. However if I deselect wash and rinse options it does spin
good solid commercial unit 13 kg
could be a timer or control board fault
my best guess is
faulty water level sensor
Sep 20, 2016 | Washing Machines
Fuzzy logic 12 kg model T9507TEFT0 overfills water
your water level switch is most likely bad or there is trash in the line feeding it.
Mar 17, 2014 | LG Washing Machines
How do I maximize water levels in my whirlpool wfc7500vw washing machine? In other words, which cycle uses the most water, and/or how I can turn off the water sensor so that the machine uses extra water?
The water levels in you machine are set by a pressure activated diaphragm that is controlled by the knob with the levels settings around it or by the computer if you have a press button type.. Heavy or long wash cycles use the most water with light washes using the least. So to explain if you are washing blankets and you have a full 7.5 kg load to wash you would set the water level at high and heavy or full wash. You can disconnect the tube to the control unit but if you do that the bowl will keep filling over the top and the machine would not know when to start washing as the control unit reads enough water and moves the power to the motor while closing of the water solenoid. If you follow the instruction in the operators manual you will find that you save the most water at any wash requirement.
Jul 29, 2013 | Washing Machines
Flashing SE and stop running, there is still water inside
5E error
WATER DRAIN ERROR
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drainerror can be cleared by turning POWER SW OFF and back ON.
Nov 06, 2012 | Samsung Washing Machines
The digital timer skips 9 minutes out of the wash cycle. After starting the normal 140 degree wash cycle (46 minutes) the washer will start and wash normally until it has counted down to 41, then it...
hi shotgun - sometimes the mieles with auto adjustment functions do make changes to the wash time - usually based on a smart sensor technology.
Unfortunately I have no data or information for your particular model, I have info on earlier & the latest models only. In hindsight what this function does is adjust water levels based on the load weight or amount of the wash, the computer then calibrates the water levels and accordingly the amount of time to wash.
Eg - 4 kg load would be longer than say a load 1.5kg to process - if can understand this concept. However I cannot be 100% certain it applies to your particular model, if the user manual is availbel it may just pay to read thru in case it applies to the washer.
Jun 21, 2011 | Miele Super Novotronic W1986 Front Load...
Sumsung GT-C 3530 do not connect with pc pleace give me sumsung pc suite
Download Samsung Kies PC sync software from following Link:
http://downloadcenter.samsung.com/content/SW/201105/20110501111040085/Kies_2.0.0.11044_11_3.exe
If this direct link doesn't work, Go to:
http://www.samsung.com/us/support/downloads/global
Select Category as "Mobile Phone", Sub Category as GSM(2G), and select your model as GT- C3530
It will show list of options. Select the second link and download Samsung Kies software. Then you will be able to connect your phone to pc
May 31, 2011 | Samsung Cell Phones
I Need Help With My Sumsung Phone And The Puk Code Is Locked
sumsung is it the model number thats whn we can help you tell us the model number o the serial number of the phone
May 30, 2011 | Cameras
Hi i have a 18 x 48 above ground intex frame pool with a salt water pump /chlorinator system. i have put the required amount of salt in 75 kg and it has fully desolved. the alarm keep coming up on the pump...
the amount of salt that they reccomend in the book is just a starting point
You need to get a salt test kit that reads in #'s not colors
Get your pool to as close to 3000ppm as possible
lower than 2800ppm and you will not produce enough chlorine
any higher than 3500ppm and you can trigger high salt alarm, have bad tasting water, or even get cloudy water
Like you have done, when adding salt , filter only for 6 hours or so to fully disolve
Jul 18, 2010 | Intex Automatic Salt Water System for ...
Whirlpool top loader 9 kg - I can't see any serial no.
There are no lint filters on this machine. The lint is pumped out with the water. There may be a restriction in the drain line starting where it connects to the tub or the small drain holes in the inner tub may be clogged.
Jan 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
