Question about HP Officejet 5610 All-In-One InkJet Printer
Copy darker i want to make a dark copy of a scanned image print out. Please give me immediate reply.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 42 Answers
Go into the menu and look for copy/print settings. you should see an option to lighten or darken the copy. It should look like a ascending /descending slider. tap to the left for lighter or to the right for darker
Posted on Nov 27, 2013
4 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: How do you print from dark to darker using HP
there is a setting on the control panel for "Best Normal or fast"select best for high quality, Normal for normal and fast for draft copies.
Posted on Jul 29, 2009
SOURCE: HP Laserjet 3015 - Printed pages are VERY light
Printed pages are VERY light, and the fuser temperature is low. The toner is not fixed on paper. Still it don`t give any errors. A detailed diagram of the power souce have anyone?
Posted on Nov 17, 2009
  • 23 Answers
SOURCE: Copying and scanning don't work but produce all-black image
please clean the scanning glass and also the feeder.
Open the machine check if any paper has struck anywhere inside.
In most of issues it will work, if this does not works call your technician to troubleshoot the problem
Posted on Jan 13, 2010
How to get the black darker
You can use Paint on your computer to modify it. If not it just might be the type of printer. See if you can buy darker ink at another store. If not your pretty much stuck like that. You can also go to copy stores or most major stores to get stuff copied for free or cost....
Windows 7 XP Security Center
Jan 29, 2014 | HP Designjet 5500 InkJet Printer
HP LaserJet M5025 MFP scans too light. Under default job options, image adjustment, darkness set to 3. The printer was sent to us upside down. We recently installed a brand new cartridge. Any suggestions?
If you print the configuration pages from the administration>information menu and they look dark then you know that the printing system is working fine. If they are light as well, then it is possible that being shipped upside down resulted in some dirt getting into the laser scanner. The image original settings are kind of wonky, in that it is backwards to normal assumptions. Darkness refers to the actual orignal you are scanning, so in most cases if you have lighter origjnals then you need to set darkness lower. As well, check whether the image type is set for photo or text. Setting for text will result in darker scans.
Jun 18, 2011 | HP LaserJet M5025 MFP Printer
When I copy, how do I adjust the light/dark, I need to get a darker copy!
The only way to adjust and print, copy or scan quality is by using the Lexmark software. Just go to your printers folder and then right click on the printer and go to properties there you will find the quality options.
Feb 04, 2010 | Lexmark X2500 All-In-One Printer
HP Laserjet 4345MFP scan to folder is too light.
make sure that you close the cover of the scanner so the original color of the image will apear on it.if you are looking the image on your computer.if the copy when you print will is light, try to change the resolution into picture quality.
Nov 15, 2009 | Office Equipment & Supplies
Copy Problem
Since you cleand the scanner and scans are fine, the other item I seen cause that problem is the power supply.
Jan 07, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Ink tone
Hi Pam -
This is a common problem with the CX 5000 - there is no contrast control (i.e., light/dark) like you would have on a photocopier. But if you use the scanning mode (EpsonScan) instead of the copying mode, there are a couple of alternative options that might help:
1) Brightness - in the EpsonScan program, in Home Mode, under Image Adjustments, there is a button labelled "Brightness." Depending on the colors and contrast of what you're copying, adjusting the brightness may help.
2) Color Restoration - In both Home Mode and Professional Mode, this feature is meant to restore the color to a faded photo - depending on the colors of your document, it may make the copy lighter or darker, but it's an option.
Hope this helps!
Dec 11, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Improving bar code image DPI for a darker output
Datamax Program Language (DPL) uses pcx and bmp graphic formats. The Adobe image must be opened in Adobe Reader and print using a windows driver. Use the datamax windows driver from www.seagullscientific.com
Jun 12, 2008 | Datamax DMX I-4206 Printer
Dell No. 962 (All-In-One Printer)
you need to go to your printer settings and make sure it is set as the default printer for everything. Make sure it is also set as your default scanner. you may also try lightening the image with the lighter/darker setting on the machine. if this continues, you may want to see if a section of the light is burnt out. this wiill cause darkness on scan & copies but not printing from the c drive. Make sure the machine is lighting up completely when is scans or copies. If part of the lighting is burnt out it will be a fix or replace situation.
Mar 05, 2008 | Dell 962 Photo All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
119 people viewed this question
Seeker5211
Seeker5211
