Question about HP Computers & Internet
Spacebar brings up a new window instead of spacing my text
Pavillion
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 89 Answers
Press ctrl+esc. This happens when a key is stuck.
Posted on Nov 30, 2013
Logitec K120 spacebar skips runs wild. How to remedy problem
I'd bet that if you pulled the space bar off the keyboard that you'll find a bunch of gunk around either the spring bar, keyswitch or both.
Either that or someone set a keyboard macro for "sticky key" on your space bar when you weren't looking.
For hints on pulling keycaps, check youtube. Getting them off is easy. Getting them back on is the hard part.
Mar 03, 2015 | Computers & Internet
Tip
How to remove the text from the Desktop icon
Desktop is the interface of Windows, which contain the icons, taskbar etc. that allow the user to interact with the computer to perform different operations. Usually the picture of icon represents its purpose so if you want your desktop looking very clean then you can remove the title under the desktop icons. May be you are thinking it is so easy, just go to rename option and set blank name or single spacebar entry but the problem is this, windows will not allow you to set blank name or name with single spacebar entry. Here interesting thing is this; window will allow you to use the ASCII code for a space, which is 0160.
First clear all the text from that icon
Now type the ASCII code, simply hold the Alt key, type the number 0160 from the number pad and release the Alt key then press Enter button to finish the process.
But if you want to remove the text of multiple icons, then repeat the above process with adding one extra ASCII code for second icon, (for example for second icon you type the 0160 twice and for third icon type 0160 three times with Alt key and so on).
on Feb 26, 2010 | Computers & Internet
Fix spacebar
On a Desktop, just purchase a new kb for $16 or so. On a laptop, it's an involved process to replace the kb.
To get a space without a spacebar, try these two suggestions:
- Press Alt/32 (that's Alt with 3 2) then release the Alt key.
- Run OSK and click the spacebar.
The actual model number MIGHT get you a repair procedure in a Google or Youtube search for "repair spacebar".
Oct 28, 2013 | Computers & Internet
(Remington Streamliner) the space bar automatically tabs instead of moving one space forward. How do I fix this?
This can mean that the spacebar is not being tapped hard enough, the spacebar is sticky, the escapement is sticky, or the spacebar linkage needs adjusted. If the letters do not cause this, then the escapement being sticky is less of a concern. Sometimes the touch on the spacebar is right on the point where the escapement mechanism just barely escapes and doesn't lock in. First try tapping the spacebar more firmly to see if this helps.
Aug 14, 2013 | Office Equipment & Supplies
Space
Try hitting the spacebar a few hundred times and see if it pulls out of its funk. If not, then bring it to a pc shop and have them replace the keyboard..
Jul 27, 2012 | Sony VAIO VPCEB37FX PC Notebook
My dog knocked over my Compaq keyboard. Now the divided spacebar is opposite what it should be. Instead of spacing on the right spacebar I have to hit the left side. How do I fix this?
Pull the space bar off by using your fingers. Underneath, you'll find a metal rod. Take note on which way it is facing, and how it fits. Make sure nothing in broken under the space bar, then put the space bar back on making sure it hooks in correctly.
Mar 08, 2011 | Compaq Keyboard
HP Pavillion DV8000 Laptop won't boot.
When your computer hardware appears to power up okay, but the Windows XP operating system won't boot properly, you have to begin a troubleshooting expedition that includes getting into the operating system, determining the problem, and then fixing it. To help you get started on this expedition, here are 10 things you can do when Windows XP won't boot.
Click here for more information
Nov 27, 2009 | HP Computers & Internet
Sidekick lx spacebar
Go to:
http://www.fixmysidekick.com/sidekick-lx-or-sidekick-2008-space-bar-not-working/164/
Or just read this...:
sidekick2008spacebarpicture.jpgIs the space bar on your Sidekick LX not working when you are trying to text or in AIM? Do you have thesame space bar button problem on your T-mobile Sidekick 2008? Does the Sidekick spacebar work in other apps though?
If so then this fix is for you.
1. Open the AutoText & Spelling screen. From the Jump screen, press the MENU button, then select Settings > AutoText & Spelling.
2. Uncheck the following settings:
    • Highlight misspelled words
    • Auto correct spelling
3. Exit out of the settings screen and try it out.
Hopefully, this will have solved your issue.
How to check for misspelled words with these two options unchecked?
Run a manual spell check on T-mobile Sidekick: To run a spell check while in a text field from any Edit Text submenu, or by using the keyboard shortcut by pressing MENU +S.
Dec 19, 2008 | Sharp Sidekick LX Smartphone
Spacebar was pulled off
These can be tricky to snap back into place. YOu have to make sure the wire used to help hold the spacebar in place is in correctly before you can snap it back on.
You have to make sure it is on the correct way or you will install it backward and it will look funny and get stuck. If you fail to put it back on correctly you can always use a butterknife or a flathead screwdriver to pop it off and try again.
Are any of the connection parts damaged? Does it still look like it will reconnect?
Dec 11, 2007 | HP Pavillion ZV6000 Notebook
Computers & Internet Logo
18 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
