Question about Brother IntelliFax-2820 Laser Fax
Paper getting stuck in machine.
My paper keeps getting stuck in the back of the machine, leaving a crumpled mess. please advise how I can fix it? P.S. We tried checking to make sure there was no debris in the machine.
  • 469 Answers
When the jam occurs, is the lead edge of the paper damaged?
Does it look like it collided with something?
If so, open up the machine to expose the paper path, (You may have to remove the drum unit) and manually feed the paper into the machine to see if you can detect what it is running into.
As it should line up with the damage.
Check the placement and alignment of the paper tray, if one end is higher than the other ot could skew and jam.
Check for bottom of drum unit for springs or flaps hanging down.
Check sensors, clean and operational? (Moving Type)
Blow out machine, clean rollers with alcohol.
Hope this is of some help.
Ed
Posted on May 09, 2009
Crumpled paper
A bit more information is need ie model number and a description of where the paper us crumpling most crumpling problem are due to a foreign object like a paper clip stuck in the paper path
Nov 02, 2013 | Kyocera Office Equipment & Supplies
Paper mismatch officejet 6500 crumples
There could be a foreign object or torn piece of paper that's stuck further inside the printer mechanism path. Try using a flashlight and inspecting any access or clean out hatches. Sometimes something will be caught inside and cause the paper you feed in to crumple and create a jam. I watched a video on youtube giving different ideas on how to fix this problem. Fixing Paper Pick-Up Issues
May 27, 2013 | HP Officejet 6500 Wireless All-in-One...
The document paper is crumpling as it enters the Fax Machine? I have cleared any old pieces of paper but it continues to crumple the paper???
In order for the documents to crease when entering the adf, there must be an obstruction. Since you have not mentioned the machine you have there it's harder to help. But, if you inspect the rollers and separation pad inside the adf, you may see that the sep pad has been dislodged or bent backwards or the rollers are dirty. If there is a sensor flag on your model, it may be stuck. Maybe there is a paper clip stuck somehwere along the paper path..
Jul 06, 2009 | Office Equipment & Supplies
Paper getting stuck in the rear of Brother 2820 fax machine...
Hi, There are many reasons for jams in the exit of machines and I will list the most common for you damp paper will curl as soon as it hits the fuser rollers... the fix - change paper the fuser rollers are worn (teflon coating is no longer able to deflect toner) and jams are occurring.... the fix - replace the fuser unit
Jun 09, 2009 | Brother IntelliFax-2820 Laser Fax
Paper get jammed in the automatic feeder on top of my printer
3 possibilities.
1 If you use this macine to copy labels, there may well be a small piece of a label stuck in the paper path on the crumpled side. Or a small bit of paper.
2, the paper pickup on the crumpled side is 'polished', and no longer feeding the paper at the same time as the uncrumpled side. They can be cleaned with rubbing alcohol. Though that is a temporary fix and the paper pickups should be replaced if cleaning fixes the issue.
3 The fuser film has a tear in it on the crumpled side you need to rule out 1 & 2 before going to three again replaceable but a bit more difficult
May 20, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Panasonic Panafax UF-880 Plain Paper Laser Fax - Info code 011
Remove the paper cassette completely, look in the cavity for a broken magnet or crumpled up paper. The machine thinks that there is no paper tray installed
May 08, 2009 | Panasonic Panafax UF-880 Plain Paper Laser...
Printer wont feed paper says out of paper
you "may" have something stuck on one of the feed rollers - a ripped piece of paper or something. See if you can examine the rollers, and look very carefully, particularly on the side that the paper keeps jamming.
In all honesty though, printers are pretty disposable these days. They're not worth getting fixed, and if you can't do quick maintenance on them, getting a new one is your best solution.
Mar 19, 2009 | Lexmark X4650 InkJet Printer
Paper jam at fuser unit section
answered here :
http://www.fixya.com/support/t636850-paper_jams_fusion_stage
also, if the paper stuck in FU is straight not crumpled and will come out easily then make sure that the 2 knobs located at top of the FU are in right position.
Jun 22, 2008 | Konica Minolta magicolor 2400 Laser...
Paper jam
If it is getting crumpled in the tray, there is something blocking the paper path.
What I would suggest is taking out the toner and drum cartridge, then remove the paper tray. Tip the machine on it's back and look into the paper feed area for something blocking the paper path.
When it is crumpling the paper like that, the feeder is working fine, just something blocking the paper path.
You can take a minela folder, and gently push it through the paper path to dislodge the obstruction.
Mar 31, 2008 | Sharp AL 1631 Copier
Brother IntelliFax-2820 Laser Fax Logo
218 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
