Question about Coffee Makers & Espresso Machines
Briel artemis problem
My espresson machine stopped brewing; it still makes noise albeit a lower noise than normal while brewing and water doesn't come dripping out anymore; i dont' think it's clogged but rather the pump may stop working? thanks for any advice don
  • 3 more comments
  • soundriven Nov 22, 2007
    Espressione Retro has worked beautifully for a year, but now after
    sitting unused for 2 months while I was away from home, very little
    water will come through the head when I attempt to make coffee. Tried
    the steam wand (to perhaps prime the pump and determine whether or not
    it draws water) and that seems to work as normal,. The Machine just
    doesn't get very much pressure of volume of water through the head.
    Also can't see how to remove the shower head to clean and check for
    clogs at that end of the system. Help?
  • javanonsense Apr 13, 2008
    Stopped brewing.  I thought it might be clogged and I've tried cleaning it.  Any suggestions?
  • Anonymous Jun 01, 2008
    Exacetly the same problem after not using the machiene for 6 weeks or so. It will not make any coffee, but the steam works fine. The pump works as normal as long as the steam valve is open and water can flow freely. If you close the steem valve the pump becomes muffled as though it is trying to pump against a blockage. I think it is probably an air lock but have no idea how to fix the problem.
  • michaelffe Jul 27, 2008
    I was away for a week and have the exact same problem as noted above. The steamer works, the coffee grinder works, but no water flows through the coffee. The red coffee bean warning light comes on. It appears that the pump is not working.
  • alexandar Nov 13, 2008
    Same problem here except I got it when I was descaling the machine with a product I have used before and worked fine.
    Appears to be working properly in any other way but is not brewing the coffee.
    Sound like it will brew but then it struggles like it is clogged and stops.
Regarding the retro: you need a special tool to remove brew head screen.
If you are handy you can try a spanner or spring clip as this has worked for some.
If that doesn't work you can send for repair to:
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
Posted on Sep 22, 2008
Sounds like you might have coffee oil build up. I would suggest soaking the Brew Head Screen, unscrew from the brew head where the coffee oils come into contact with machine, and filter holder in a coffee oil remover by or dezcal.
Remove the screw if your filter basket has one and do not screw too tight when putting back together or it will happen again.
Further technical info can be found at:
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
I had the same problem.  Try putting a descaling tablet in hot water and in the tank.  Then try the rinse cycle over and over.  I did this a couple of times and it finally cleared up.  When it was clogged I could see the calcium built up on a little tube right inside, and now it is clear.
Posted on Sep 08, 2008
I have the briel multi pro EG 281 PG/APG. When I try make espresso, water comes from the frother and not from the brew head. Any suggestions on what the problem might be? Thanks!
sounds as though your brew head is clogged. when was the last time you descaled your machine? even if you've recently done it, it would not hurt it to do it again. descaling will eventually clean out the head and lines to the head and thus, your brew head should be despensing the coffee again. the reason it is having water coming from the frother is because under pressurization the water is shot into the areas that are open for releasing the pressure in the form of water. if one or the other outlets are clogged, then the next one available takes the pressure from it as it is re-routed to the only open source as your frother.
Feb 10, 2015 | Briel Coffee Makers & Espresso Machines
When it is brewing it make a loud noise during the brewing
Any coffee brewer will bring water to a boil and expel the hot water over grounds or into a container. This water is sometimes under great steam pressure and is released by the user with a knob, handle, etc. These pressurised machines all make noises but should be within the normal operating range while using the machine. If it makes noise other than when in use then there may be an issue. Have a technician check for safety reasons as you are dealing with a 'steam BOILER' . For drip makers there should be no pressure other than the normal 'glug-glug' sounds while brewing. A commercial brewer will just have water sprinkling down into the basket and possible 'whine' noise as the tank refills. But if it's not your normal noise then have a tech check it out.
Oct 14, 2013 | Coffee Makers & Espresso Machines
It turns on makes noise but it doesn't brew
  • Clean the puncture needle with a paper clip. It has 2 holes.
  • Turn unit off for a few minutes, remove and replace the water tank. Turn back on.
  • If all fails unplug, remove water tank, turn over and slap it on it's bottom. I know, sounds silly but it works!
Feb 08, 2013 | Keurig Elite B40 Coffee Maker
i solved it by taking it all apart, then putting it back together, whoo hey it works
Aug 04, 2009 | Briel Artemis ES42 Espresso Machine
Brew head leaks at gasket,causing some water to bypass the coffee and leak around outside of brew head
The filter holder not pushed far enough ino lock position, also the basket doesn't quite hold 2 level spoons of coffee.
Thanks, David
Jun 18, 2009 | Briel Chamonix ES-35 Espresso Machine
Coffee Machine Brewing Water
Try an experiment - brew a test cup, but use only a small amount of grounds in the brew basket (use a paper filter) [or else, put the grounds in the gold tone filter basket]. See if the machine makes coffee (albeit weak coffee). If it does not make coffee, see if the water is draining properly from the brew basket, or if it is leaking over the sides of the brew basket. Also, make sure the lid to the brew basket is completely open and in the correct position.
If you still get water only in the caraffe, replace the brew basket. The part costs about $11.95 with shipping - or even call Cuisinart to see if your 3-year warranty will cover the issue.
-Tha Mp3 Doctor
Mar 03, 2009 | Cuisinart Thermal DGB-600 Grinder
Briel Apollo no water when making espresso
Check that the water tank is seated properly. When you lower it in place just give it a little nudge down to make sure its slotted into the catch.
Nov 24, 2008 | Briel Domus Due Espresso Machine & Coffee...
While making espreso, the machine leaks water from underneith.
Please email me with your request and I will send you info to fix it.
it is basically info on removing coffee oils from the Brew Head Screen.
if that does not work you can contact the service center at phone 201-439-1700 or email:
Thank you.
Nov 17, 2008 | Briel Domus Due Espresso Machine & Coffee...
Briel Sintrac cofee/express machine
I all ways have a good coffe(express)until now.Sems to me to much water and the coffe is no good
What can i do?
May 27, 2008 | Coffee Makers & Espresso Machines
Espresso Machine
Possibly, if it is leaking from the bottom only, and if you have a Domus Due model, you might just need a new water reservoir as the water reservoirs are a different system than all of the other briel machines and a new reservoir will usually fix the problem of leaking on the bottom in the Domus Due machines. Something with the seal on the reservoir.
You can order just a water reservoir by contacting the service center at:
41 Woodbine St
ph 201-439-1700
If your machine is leaking over the filter handle, brew head etc, that could be the coffee oils have built up in the Brew Head Screen and/or filter basket itself. For that, remove the Brew Head Screen and soak along with the Filter Basket in a coffee oil remover (not descaler) you can get the Cafiza powder at or any other brand and then use a brush to clean it after soaking. If you have the Briel filter basket with a screw in the middle, please remove the screw and clean in there as it tends to get clogged. Then just be sure not to screw it too tight again as this can cause leaking.
I hope the info was helpful.
Apr 16, 2007 | Briel Domus Due Espresso Machine & Coffee...
Coffee Makers & Espresso Machines Logo
322 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
