My Whirlpool Duet Washer, model number WFW9400SW01 will not turn on. The button lock is off and does light up indicating power to the front panel/unit. Any ideas?
  • pjock13 May 16, 2009
    We hav the same problem - the power button would go on, but the start button only beeped...then we unplugged and turned off/on the circuit breaker. Now the power button only beeps, and the only item that works is the lock button when we hold it down to lock/unlock. Frustrating because Whirlpool has nothing with this sort of problem documented.
  • christine german Oct 16, 2012
    my whirlpool duet encountered the same F70 error. I unplugged to reset and then there were no lights at all. Server repair man encouraged me to buy new washer the cost to fix would have been almost 500.00. No guarantee this would be the end of problems he said he has seen many pumps go out from this model as well and if I hang onto it the pump may be next. My whirlpool was less over l years old. It seems this is the disposable model. Costly ..I will never buy another whirlpool again.
  • 3 Answers
If you are mechanical and are not afraid of small wires you can try this. I had the exact same problem on my machine. i very slowly diasssembled the machine. not hard to do. removed the top. unscrews from the back and slides to the back to come off. remove the door. unsnap the plastic plate that goes around the door.it is held on by small snap clip that pop off if you use a small flat screw driver to pry it out. remove detergent tray. and screws that attach it to the inner box. now the hard part. remove the face plate. it unsnaps similar to large door plate.very carefully unclip the circuit boards. they are held in by plastic clips around the outside and white plastic clips in the middle. you must gently pry up and release these clips one at a time. a second person is helpful, so are small needle nose pliers. clean both circuit boards very gently with isopropyl alcohol and qtips. mositen the qtips and clean every inch of the boards. be very careful not to bend or crack anything. you must get all the yellowish flux and any other corrosion growing on the board off. there is one more board that must be cleaned. the power supply board. it is mounted on the top right side near where the face plate wire come through. this is not hard to remove it is held in by small clips. the tricky part is the wires. they are all designed so they cannot be plugged in incorrectly but i have seen what people are capable of. make a map. number them with a sharpie so you know where they go. remove this board and clean it the same way. this on will probably be the worst offender. i cleaned all the boards reassembled and it works like new. below the door is a panel that should also be removed. there is a removable drain filter that should be cleaned out. i found pens and toys in mine. the machine could not pump out the water fast enough and would shut down and trigger f70 and f 20 codes.
Posted on Jun 20, 2009
I had the same problem. Inside the door there is a little black button that sends a signal to the panel telling it that the door is closed so that it will allow the washer to start. Mine broke off. I did my own fix it by using foil to fill the hole holding the button in permanently, then taped it. I will eventually get some superglue and glue the black piece back on. But my washer is working again. ( This was only discovered after I took it all apart, because i thought it was in the "start" button.
Posted on Jun 25, 2009
Control lock lit, no other buttons work
Instructions
    • 1 Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
    • 2 Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
    • 3 Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
Read more: How to Unlock the Control on a Whirlpool Duet ' eHow.com http://www.ehow.com/how_5701217_unlock-control-whirlpool-duet.html#ixzz2HVS4i8hL
Jan 09, 2013 | Kenmore HE4t 3.8 Cu. Ft. King Size...
My duet whirlpool washer has stop working. The control lock light is on. so what do I do from here
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Frigidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your specific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Oct 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Do you have instruction how to replace the whirpool duet door seal (boot)? modal number is wfw9400sw01. ser#csu2405380
Hi
Please see this video link to replace the door seal on your washer---
Please post for further assistance. Hope this helps...
Daniel
Aug 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control lock
My dear friend this is an very common problem people do face with.
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: The control lock light is lit on my whirlpool duet...
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet front end loaded washer that has a controlled locked light that is illuminated. what is wrong and what should I do
Feb 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Duet washer, and the Control lock light is lite, how do I get it to turn off
Somewhere on the control panel under one of the buttons it will say hold for 3 or 5 seconds to lock or unlock control panel. You may have accidently locked panel while cleaning or some one held button for too long and panel locked. The control lock is there in case you want to prevent small children from turning on your washer. Just hold down button for a few seconds and light should go off.
Feb 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet washer. It worked fine
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^%^^%%
Sep 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet control lock light is on and the machine will not do anything. I have held the end of cycle button for several seconds and even turned the breaker of all night hoping to "reset" it.. no...
Jul 29, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washing Machines Logo
1,869 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
