Question about Steam Fast Irons
I want a manual for Calor Supergliss 60 FV 3160
Want a manual
Need parts manual and wiring diagram
there are several sites and you really need to be more detailed on what product that you need a manual for. The bottom line is most of the time just go straight to the vender or manufacturer of the product. For example if you needed a manual on a 2015 ford Tarus you would go to www.ford.com. If you needed a manual on a Huffy Bicycle you would go to www.huffy.com. Good Luck.
other resources:
Product Manuals Retrieved
Free User Manuals and Owners Guides ManualsOnline com
User Manual Product Guide Download
May 29, 2015 | Irons
What does it weigh please? How old is it? Is it worth buying second hand cheaply or is a new singer 2 much better?
WOW with no pertinent information about your device IE model # or any other information i would like to convey my best advice to you.
this is my advice :: all things today are constructed to fail. and the devices of the past are also disposable for it is not worth a person`s time to fix/service for you your device.
Are you willing to pay 60 dollars to have your device repirid ?
Depending on what you have and i am thinking of an clothing iron you can purchase one form many places for the cost of a repair of your old one and have a warranty or other..
just bye a new one
Best regards Falco
Oct 20, 2013 | Singer Electronic Steam Press
Why does the engine light start flashing when i brak
stop immediately, call AAA for a tow to your mechanic.
Generally a flashing "Check Engine" light requires immediate attention to avoid possibly very expensive engine damage.
If you have a friend like me locally who has a OBD Engine analyzer, you get the error codes, translate the code for free and fix it yourself if you have the skills. I got my Innova Brand at WalMart for $120 in Hawaii. Mechanics will charge $100 to hook up the analyzer, plus $60/hr minimum service fee.
Nov 17, 2012 | Bosch Audi A4 1.8l Engine Motor Turbo 02...
The alarm on the iron comes on and switches off the iron
What sort of Alarm do you get?
Does this iron have the 3-way alarm feature:
1.) Tilt over
2.) Laying down alarm (like 60 seconds)
3.) Idle alarm (like 15 minutes or longer..)
Can you give us more details on the alarm you get getting, and when?
Mack B
Aug 08, 2011 | Morphy Richards 40659 Iron
Will not light and will not heat up
Problems like this assume the iron is at fault. but may not be.
Check the wall socket you are using works with other appliances.
If you use the iron via an extension lead, check that the lead is working by checking with another appliance also.
Take out the fuse in the plug of the iron and put into another appliance to test its working and not fused.
Only if all is well at this point should you bin the iron.
Flat 'hot plate' irons are so cheap nowadays, so bin it and get an new one. The best are steam generator irons with a reservoir of water container attached. Mine cost £30/$60 so spend wisely.
AndystUK
Nov 08, 2009 | Euro-Pro Shark GI490 Iron
Manual for Euro-Pro G6118H
I don't know if you have the number for the euro pro customer service department; but, I had the same problem, called customer service, and had a manual emailed to me. The manual came within a couple of hours via email. In case you don't have the number and still need a manual for your unit, try calling 800.798.7398. I hope this helps and good luck!
Jan 15, 2008 | Euro-Pro G6118 Iron
Irons Logo
26 people viewed this question
Top Steam Fast Irons Experts
Are you a Steam Fast Iron Expert? Answer questions, earn points and help others
