Question about Dell Inspiron 1545 Notebook
Dell 1545 battery
Battery calibration
New battery and charger wont charge over 45%
The battery needs to be calibrated from the setup. I this doesn't work, then ask for change of battery
Jan 27, 2013 | Dell Inspiron 1545 Notebook
My dell inspiron 1545 won't start, I have pressed
removed your battery and charger then hold the power button for at least 10 seconds then replaced battery and charger.. good luck
Apr 08, 2012 | Dell Computers & Internet
Dell inspiron 1545 laptop has went through 5 chargers they work for 6 months and then say does not not charging does not recognize battery
This is similar problem I had on my laptop.
Its a problem with the battery not the Charger If computer is in Warranty you get it from Dell or buy a new battery
Jun 21, 2011 | Dell Inspiron 1545 Notebook
My Dell Inspiron 1545 will not load windows. The screen is lit but it is blank. I have taken out the battery and reinserted. What else should I do?
Is the screen black with the cursor blinking at the top left?
I have a suspicion that the coin sized battery is dead.Go to www.dell.com and get a service manual, replace the coin battery (Lithium battery). Put it all back together and it should work.
Mar 10, 2011 | Dell Inspiron 1545 Notebook
My Inspiron 1545 turns off when I unplug it from adapter, and when plugged in, the power light on front flashes four times orange and one time white repeatedly.
Does the battery for dell inspiron 1545 plug in. It maybe because the battery pack is too hot ,you can turn off the laptop,let the pc notebook and the laptop battery both cooled down.Then try turn on it to see. If still happen to the matter,it must because the wrong turn off did harm to your Inspiron 1545 laptop adapter.
Dec 16, 2010 | Dell Inspiron 1545 Notebook
Dell inspiron 1545 laptop (Time- of- date clock
This could mean two things: a problem with the cmos battery or the motherboard itself. Try to remove the cmos battery first and install. If not,then replace the cmos battery.
Oct 12, 2010 | Dell Inspiron 1545 Notebook
Back-up battery wont charge and LED at the front of Laptop flashing
Find a good repair engineer to repair it, if if can't be repair any more,just pay more attention to the Dell inspiron 1545 battery not charging question for answer,and learn more laptop battery maintenience tips from now on.
Aug 07, 2010 | Dell Inspiron 1545 Notebook
My dell inspiron 1545 says plugged in but not charging
its the charger if the charger is longer before trie changing the battery or if that doesnt work u have to replace the motherboard (around 155.00 GBP)
Jul 26, 2010 | Dell Inspiron 1545 Notebook
Dell 1545 plugged in with correct adapter, but not charging.
Battery packs die after a while they are unable to hold charge this sounds like your case, you will need to replace battery pack, if you get two good years out of such you have already done well.
Nov 07, 2009 | Dell Computers & Internet
Dell Inspiron 1545 Notebook Logo
18 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
