Question about Belling 644 Electric Kitchen Range
Top oven does not heat to high temperature - Belling 644 Electric Kitchen Range
Why is my left oven of our leisure Rangemaster 110 dual fuel not reaching high temperature?
Your left hand oven is a conventional oven it has two heating elements one at the top and one at the bottom, if one of these is not working then the high temperature cannot be reached.
May 07, 2015 | Rangemaster Kitchen Ranges
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
Neff oven not heating have replaced fan element
it has to be the temperature control itself...thats the only other component, aside from the high-heat cut out switch which rarely goes bad.
Jun 05, 2010 | Neff U1721 Double circotherm Electric Oven
F2 low temp
The most common probem is burned wires going to the heater on the top of the oven cavity. Typically you will see the coating on the wire close to the heater all cracked and bare. You can usually just cut the wire back an inch and pull some slack up and reconnect the wire and you will be good. In some cases the wire will be burned to much and the whole wire will need to be changed. Any oven repair shop will sell you these high temp wires. DO NOT use regular wires they MUST be high temp rated.
Here is some other things to check if the heater wires look good.
COMPONENTS
IR Element
The IR element - a dual coil type heater - is located
in the bottom of the oven cavity. The first coil is the
heating coil. The second is the IR thermocouple
wire. The heating coil outputs 3000 watts at 208
VAC. The heating coil's resistance is 14.4 ohms at
room temperature.
The thermocouple coil is a Type K thermocouple
with a resistance of approximately 20 ohms at the
splices located approximately 6 inches from the
heater and 40 ohms measured at the extension wires
at the I/O control board.
The IR element is controlled via the K5 solid state
relay and the IR thermocouple via the I/O control
board.
Also try this
1. Verify the high-limit thermostat is not tripped.
o If high-limit is tripped, reset and allow the oven to warm up.
o If high-limit is not tripped, follow the instructions below.
High-limit thermostat is not tripped.
Place a small water load in a microwave/heat-resistant container
(approx. 275 ml) in the oven and place the oven in TEST MODE. Press
the MGTRON key to actuate the microwave. While holding down the
MGTRON key, watch the CC and IR temperatures. If either temperature
bounces substantially, there may be a noise (EMI) problem.
To correct this problem, examine the wire routing for each
thermocouple wire. If the wires are routed near any high voltage
components such as the magnetron or high voltage transformers, reroute
the wires. If this does not correct the problem, verify that both
magnetrons are securely mounted.
Good Luck
May 20, 2010 | TurboChef TORNADO Electric Oven
F2 error and door locked display while self cleaning and fan will not turn off for 4 hours after using oven
F2 during the cleaning cycle will occur when the oven control senses an oven temperature above 915F-930F
If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
**((The fans will continue to run if the control has been damaged, due to the high heat))
Sep 09, 2009 | GE Profile JTP56 Electric Double Oven
My oven keeps beeping F2 and it won't turn off. The top broiler coils are bright red and heat is pouring out of the oven. I have held down the off button, pushed start, pushed bake, anything I can think...
Control senses oven temperature above 615F-630F. shut down the breaker switch asap.
If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
Jul 08, 2009 | GE JGRP17 Gas Single Oven
My oven turns off on me after only a minute never heating up fully
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turning then replace fan. If mains voltage is not present then its the thermal switch.
Jun 19, 2008 | AEG B1180-4 Electric Single Oven
No heat after self-cleaning
gain access to top of oven...pull it out if necessary. remove all panels possible and look for a wire connection that has deteriorated with high temperature. this may not be easy to see, so use a continuity meter and check across each wire-to-terminal connection. it also is possible that the over temperature fuse (or breaker) has opened. check for this also. for further help, ask me.
Aug 10, 2007 | Whirlpool RBS305PD Electric Single Oven
Oven will not heat to requested temperature
Shaffy, When baking only the bake element should heat. When broiling only the broil element (upper) should heat. Your oven is a Kitchenaid, you have a 5 year warranty on any electronic element or control board. You may have a temperature sensor that is not working right. The oven just might need to be calibrated, the instructions would be in your owners manual. Your bake element might be failing, it would have to be ohmed out. You also need to verify that the bake element is getting 240V. when turned on. Catriver...post back
Sep 07, 2006 | KitchenAid KERC507 Electric Kitchen Range
Belling 644 Electric Kitchen Range Logo
14 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Mike Carew
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
