Question about Dishwashers
Teka DW6 58 FI
The machine shows an E6 error, the drainage is good, how to reset the code?
4 Suggested Answers
SOURCE: teka dw6 55 FI, error
its not draining
Posted on Sep 22, 2008
  • 3230 Answers
SOURCE: Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Posted on May 06, 2009
Daniel S
  • 4323 Answers
SOURCE: Drainage error code keeps flashing
Hi
If its been used once and the issue is there then it means there is an installation error and its better to use warranty and get it done. Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 09, 2011
Error message e6. Needle won't move
Check your owner's manual - troubleshooting section. Sometimes it will show the error codes. Otherwise, search the internet for:
Make + Model + "error code E6"
You can also check with the manufacturer.
Nov 09, 2016 | Sewing Machines
My Teka DW7 57 FI VRO2 dishwasher shows the error code E4.
E4 means it is overfilled because of too much inlet water. Turn off the main supply. Remove excess water from the base pan and restart the dishwasher. DW7 57 FI Teka official website Bathroom Kitchen Professional Kitchen and...
Apart from using the manual instructions, you can get technical help from the company directly too.
Hope this helps!
May 15, 2016 | Dishwashers
Error 1 in teka washing machine 1260 WD. What does it mean?
code E1 Main electronic control board failure Unplug the washer. Check the wiring connections on the main electronic control board in the console. If the wiring connections are sound, replace the the main electronic control.
Nov 07, 2014 | Washing Machines
What does E6 mean on a baumatic bwm70
E6 on the bwm70 means that there is a water sensor level error. You can try resetting the error code to see if it comes back on by pressing and holding the the power on, start/stop button, or unplug the washer, wait 30 seconds and try again. If you still get the E6 code, your washer will need to be serviced
Jun 18, 2014 | Washing Machines
E6 error I need help
Good Afternoon Ismael, I am happy to assist you. However, could the error code possibly be missing characters? According from my research Frigidaire does not have an E6 error code. Meanwhile, let's try resetting the washer by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn the washer on. If resetting the power does not correct the issue, could you please advise me of the new error code or if it continues to display E6? With this information I can better address the issue at hand. Thank you and I look forward to your response.
Aug 15, 2013 | Electrolux Washing Machines
Dishwashers Logo
166 people viewed this question
Top Dishwashers Experts
Owen Barnes
