Question about Garden
I have a Ransomes twin trak 2000 mower that the belt has come off, and I can't tell how it's supposed to go.
3 Suggested Answers
wadembly
  • 513 Answers
SOURCE: I have a ransomes 350d mower and when you rev the
there should be a c clip around the out side of the tire push it out with flat tip screw driver or pliers some tractors have a cover over them you might have to pop it off with screw driver first to get to the rest the bakes are usually on passanger rear wheel
Posted on Jun 08, 2009
  • 3519 Answers
SOURCE: how to route the belt , the belt was taken off so we dont know how to route it around the 6 pulleys on a John Deere f620 z trak mower
Hi Nina:
A puzzle!
It's like a jig saw puzzle only there are seven parts...
- 6 pulleys and
- 1 belt.
- The "vee" of the belt faces inwards.
- some of the pulleys have a groove that the belt will go into. The belt goes on the "outside" of these pulleys and the belt will snug into the groove.
- some of the pulleys will be smooth. The belt goes on the inside of these so that the flat "outside" of the belt rides on the "inside" of the pulley.
- there will be one special pulley that is mounted on a lever and has a spring that keeps tension on the belt. It's usually easiest to route the belt around this one last.
Make sure that the control lever is in the "not cutting" position, the engine is off, and the keys are not in the ignition when you do the install.
Patience, time, and quiet logic.
You'll get it.
Posted on May 14, 2015
757 Ztrac. Why do I keep burning belts off?
if you dont use kevlar belts,then you are wasting money,they cost more,but,they last ten times longer,use the widest width that it can handle,dont buy from jd,it will cost you 100.00,go to ebay,etc,your tensioner should not be tight enoughto stretch the belt also,here is a jd belt,you can get cheaper just make sure it looks green or red,not rubber black, JOHN DEERE oem Mule Drive Belt TCU13195 737 757 Trak below 030000
OEM Replacement PTO Belt John Deere 737 757 Zero Turn Lawn Mower
JOHN DEERE TRAK 737 757 797 60 DECKS DRIVE BELT TCU13198 12760
Jun 24, 2015 | John Deere Garden
How do i replace cutting blades on bobcat ransomes 36 walk behind mower
Often, you can find manuals on line. Just Google using make model information. Search for a user's manual.
Oct 02, 2014 | Garden
757 z trak makes squealing noise when try to go forward or reverse
There are two version of this ZTR depending on the serial number. First I would check the drive belt that drives the hydrostatic system. Also the idler that keeps tension on this belt needs checking.
Mar 05, 2014 | John Deere Garden
Honda push mower
NEED BELT DIAGRAM FOR RANSOMES 956105 DECK
Jun 20, 2013 | Garden
I have a ransomes 350d mower and when you rev the engine up the mower cylinders rise up on there own, and can you tell me how to remove the drive units on the wheels so that iI can get to the brakes as...
Jun 07, 2009 | Garden
1957 Sunbeam Twin-Blade electric lawn mower shaft bushing
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=654762
Generic problem for all Vacuums
1957 Sunbeam Twin-Blade electric lawn mower shaft...
Posted by mower man on Jun 08, 2008
I have a late 50's series Sunbeam twin-blade electric lawn mower that I use regularly. The shaft bushing(s) on the left blade has worn out, and there's too much play for me to run it w/o ruining the machine.
It appears that the belt-run cog inside the housing is the part that is supposed to come off of the shaft to get to the bushings, but instead of a cotter pin or other fastener holding the cog in place, it looks like a rolled metal pin that may have been pressed in place.
How do I replace the shaft bushings so I can keep using this great vintage appliance!? I found a website that supplies parts for this model year, but no schematics or user manuals. Thanks!
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. This website is for vacuums and you would need to contact a local lawn mower shop in the yellow pages, they are amazing about the way they can fix old lawnmowers.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 08, 2008 | Vacuums
Garden Logo
186 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
