Question about Alpine SWR-1222D 12" Type-R Series Subwoofer Car Speaker
Cant wire to mono amp
WIRING SWR-12222D DIAGRAPH TO MONO AMP
  • 655 Answers
Hello danielperez9,
There are two options for wiring a single 2ohm DVC subwoofer to a mono amp. The first gives a 1ohm load and should only be used if your amp is stable at 1ohm. The second option results in a 4ohm load and would be OK for most amps. Here are the diagrams:
Hope this helps.
Posted on May 08, 2009
I have a mono block kenwood amp and a type r sub their is no sound to my sub but there is power to the amp just no sound
Check your subs impedance to establish speaker is working ,Check crutch field advisors website for sub box construction and detailed wiring instructions.
Aug 06, 2014 | Alpine Type-R SWR-1242D Car Subwoofer
How would you hook a alpine r12 dual 4 ohm sub to sony xm-1s mono amp
in parallel get both positives and both negatives together and wiring them to amp for a 2 ohm load. the sony xm1s is a 2 ohm mono amp
Dec 31, 2009 | Car Audio & Video
Wiring alpine amp and sub
To wire your 4 ohm dual voicecoil to a 2 ohm mono load - all positives to + on amp.... all negatives to - on amp.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 29, 2009 | Alpine MRP-M500 Car Audio Amplifier
Can i bridge rsd60.1 ser#069243867003
Negative a any amp that is 60.1 or 1500.1 whatever it is .1 is a mono amp and needs no bridging. Some mono amps are set up like a 2 channel but they aren't bridgable they just add more options for wiring each individual sub to the amp...
Dec 11, 2009 | Phoenix Gold Car Audio & Video
2 channel amp to 6-6x9 wiring diagram
Hello magoocsl,
Yes, with the use of 2 high-pass and 1 low-pass crossovers, that Kicker amp will operate in what they call stereo and mono simultaneously (SAMS). You'd run 4 of the 6X9's in mono. Wire them in series-parallel with a low-pass crossover on the positive leg to the amp. The amp would see a 4ω load. The other two 6X9's would be wired as stereo, one to each channel with a high-pass crossover. Again, the amp sees a 4ω load.
Here's a link to the appropriate wiring diagram. The diagram is on page 5. Just substitute your 4 6X9's wired in series-parallel where they show the "mono" speaker.
http://www.kicker.com/sites/default/files/02KX300_400_500_800_2AmpManual.pdf
Hope this helps.
Apr 01, 2009 | Kicker KX500.2 Car Audio Amplifier
SWR-1242D wired at 4ohms
Hi!
Having to much power for a subwoofer is a veeeery good thing, it will provide a lot of control and quality sound to your sub.
But this sub is a dual voice coil at 2 x 4ohm so if you want to hook it up at 4 ohm u need a 2 channel amplifier running mono mode.
i dont recomend that you hook up in 4 ohm, its better to take some time adjusting the levels on the amp and the headunit.
This system has the potential to create a realy good bass sound if u tune it the right way.
Feb 10, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
Wiring Diagram
i HAVE 2 12 KICKERS L7 RUNNING ON A PERFORMANCE TECHNIQUE AMP 2000 WATS THE ampl its a mono //and i want to know how to wire the speakers
Jul 26, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
2 ohm dvc and monoblock sub amp
Yes. When you run two-two ohm subs to a monoblock amp its on the same channel meaning there ran parallel, and that makes it one ohm and most mono-blocks won't read one ohm. Are you popping fuses in the amp?
Apr 02, 2008 | Audio Players & Recorders
Wiring 2 subwoofers to a mono amp?
The subs can be wired "parralel" or in a "series". it depends on the ohm rating of the speakers and the amp. Most amps can only go down to 2ohms (mono) so it depending on the ohm ratings of the speakers when wired in a series vs parralel that will decide how to wire them. you can always take the safe route and just wire the positives of each to positive on the amp and the negatives to the negatives on the speaker terminals. Do you have the speakers model numbers?
Dec 14, 2007 | Car Audio & Video
Unsureness of wiring configurations.
Mamola,
Get an amp with at least 200 Watts RMS. The RMS value is what is important about driving Subs. This could be proclaimed to be a 1000 Watt amp. REad the RMS value.
Wiring. It is better to series your Speakers to give them and your amp more reliability,
Get a Mono or Bridgeable amp. If it si bridgeable, BRidge the output as described in the manual you get. Some Amps have a diagram right on the output..
AMP+ to Sub1 +
Sub1 - to Sub2 +
Sub2 - to Amp -
Get a 4 Guage wring kit. Run your power wiring down the Drivers side, and Audio signal wiring down the Passenger side, keep the two separate.
Nov 26, 2007 | Kenwood 12" 4-Ohm Single-Voice-Coil...
Car Audio & Video Logo
495 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
