Question about Pentair STARITE PUMP HOUSING / TANK BODY
Thermal cutout tripped in sapphire spa
How to fix
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pentair Master
  • 1,448 Answers
Need new pump motor and seals
Posted on Sep 07, 2014
After circuit tripping, the power doesnt work
pwr trip probably caused by internal short which may have blown an internal fuse or thermal cutout
Feb 08, 2016 | Microwave Ovens
Electric dryer won't heat
Thermal overload cutout tripped or is defective and needs replaced. Look for a red reset button near the heater element on the thermal overload. If no reset button, replace the thermal overload cutout. The timer itself could be defective, which will prevent power going to the heater element.
Sep 14, 2015 | Roper Dryers
Bosch dryer will not heat
If you have a Tumble Dryer that is not heating up but the drum is turning ok, then the chances are the thermal overload cutout has tripped. Bosch dryers have a reset button but you will have to remove the heater cover panel to access it, you will find it just above the heating element (a black stat with small red button) simply press the red button and if it clicks you've fixed it.
It also may be:
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced
Dec 13, 2013 | Bosch Nexxt 800 Dryer
When I turn my spa on the pump sounds like it is laboring real hard then kicks off, does not trip breaker, then after about 20 seconds it does it again so on and so forth
That's the thermal overload shutting the motor off. It generally indicates a problem in the bearings or motor windings. The usual fix is to replace the motor.
Nov 02, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Bissell bag type upright won't turn on. No power. How do I fix it?
It would have to safely be taken apart and voltage to the switch measured to know, just be careful.
Most have a thermal fuse or cutout that if the motor gets too hot will trip all power off.
Dec 23, 2012 | Vacuums
LER7646 won't heat. I checked the resistance of the heating element (12ohms). The high limit thermostat reads 0 ohms and the thermal cutout read open on the ohm-meter. I replaced the thermal cutout and...
A typical reason the thermal cutoff would go out so quickly is because of a poor airflow so the heat is being built up in the dryer instead of being vented out.
What to check is for a blocked/restricted vent,lint built up in the blower housing that is restricting the airflow& or a broken blower wheel that isn't moving the air from the dryer.
GENE
Sep 05, 2011 | Whirlpool LER5636P Electric Dryer
I have a powerstar ae115 water heater that is 3 years old. The thermal cutout onthe left side keeps tripping. after shutting off the shower the temp on the top of the unit is reaching 185*f. I have...
You've done the required first-step troubleshooting and maintenance.
If thermal cutout keeps tripping, and unit is actually reaching 185, then something is wrong with wiring, temperature sensor, gas valve, or PC board. Or combination of factors.
Call service technician, and open following link for some Bosch tankless resources including Bosch contact information:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Jun 26, 2011 | Bosch PowerStar AE115 Tankless Water...
NO HEAT TO DRYER NO COILS APPEAR TO BE BROKEN TO HEATING ELEMENT. ALSO I CAN LOAD DRYER SET THE AMOUNT OF TIME AND CLOSE THE DOOR AND THE DRYER AUTOMATICALLY COMES ON. I DO NOT HAVE TO PUSH START BUTTON....
This problem is usually the result of an overheat causing a thermal cutout to trip. While I don't know this machine specifically, you will probably find that there is a screw on bulge on the back of the machine that covers the fan and heater unit. (Unplug from the mains first!!) remove the panel (Usually about 6-8 screws) and inside you will find a heater element. Near to this you will find at least one thermal cutout, it will be a little metal disc set in plastic, about the size of a penny with 2 wires coming off it. There may be more than one of these, but typically, only one has a tiny hole in the back at the centre. If you push a paper clip or pin into the hole gently, you will hear a click as the metal disc in the cutout pops from a concave to a convex shape and re-sets the cutout.
Reassemble and the problem should be fixed. Now ask yourself why it tripped? Usually because:
  • One or more filters or the condensor were clogged and needed cleaning
  • The inlet or outlet for the airflow were obstructed
Both these things will cause an overheat and the cutout will trip.
These things very seldom fail because of a fault, but if the unit keeps tripping the thermal cutout, the problem may be a real heater fault and you should look to change the heater element or get someone to change it for you if you are unsure.
Mar 26, 2009 | Whirlpool Dryers
No heat to dry clothes
The machine is probably doing exactly what it is supposed to do and failing safe because of a problem. This problem is usually the result of an overheat causing a thermal cutout to trip. While I don't know this machine specifically, you will probably find that there is a screw on bulge on the back of the machine that covers the fan and heater unit. (Unplug from the mains first!!) remove the panel (Usually about 6-8 screws) and inside you will find a heater element. Near to this you will find at least one thermal cutout, it will be a little metal disc set in plastic, about the size of a penny with 2 wires coming off it. There may be more than one of these, but typically, only one has a tiny hole in the back at the centre. If you push a paper clip or pin into the hole gently, you will hear a click as the metal disc in the cutout pops from a concave to a convex shape and re-sets the cutout.
Mar 13, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Problems with Breville SK500XL Stainless Steel Cordless Electric Kettle
There's a thermal cutout that trips if the regular safety switch isn't enough. According to the manual, if the thermal cutout trips you have to send it back to Breville for servicing.
That may be what happened, if just letting it cool down and trying again didn't work.
Aug 13, 2007 | Breville SK500XL Stainless Steel Cordless...
Pentair STARITE PUMP HOUSING / TANK BODY  Logo
42 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
