Question about Refrigerators
What temp should my heir refriderator b set on?
    Sergeant:
  • 192 Answers
Whatever you like. If you like your milk super cold, crank the fridge up. The lower numbers will be more efficient.
Posted on Nov 27, 2013
GE Profile refriderator PSC25MSWA is frosting/icing on bottom of Refriderator side
Try defrosting entire unit. Put all food, freezer and refrigerator sides in coolers with ice. Unplug unit and wait at least 24 hours for unit to completely defrost, if neccessary open doors, plug unit back in and see how unit functions. By doing this lines that carry freon should become unclogged.
May 05, 2014 | GE GSS22SGM Side by Side Refrigerator
I have a GE profile side by side refriderator. The freezer is working(temp is below zero on coldest setting, but the refridge is warm, ranging from 36 -59 degrees depending on the shelf. (this is on the...
the ice is caused from the frozen drain in the back. the cold coil is also frosen / this stopes the air to the fresh food .. so defrost the freezer and ck the heater and defrost termator . . you may also need the main control that has the defrost timer on it . located on the back of frig.. hope this helps . mm
Jul 11, 2011 | GE Refrigerators
GSS25KGPJWW side by side; refrigerator running almost constantly and my wife noticed that food in the "Fresh Produce" bin and the "Deli Fresh" bin was freezing. I now have the...
Try shutting the vent between the freezer and the produce bins, the freezer should be colder-down at least to 5 degrees, turn the freezer control to max cold and leave the fridge temp where you put it. the go from there
Jun 24, 2011 | GE Refrigerators
Refriderator side is nice and cold. Freezer side is hot 55 degrees. I have unplugged a couple of times but still won't lower the temp.
did you replace the fan on your unit? its not possible that the fridge is colder than freezer unless the fan is reverse..
Oct 01, 2010 | Refrigerators
When I call so body I heir them ok but they cenot heir proprly
Try deleting the headset from your phone, turn your phone off for about 45 seconds and then power it back up. Then repair your headset to your phone. See is this will fix the problem.
Below is a link to the Explorer 300 Series User's Guide for more information:
Plantronics Explorer 300 Series User's Guide
Good luck from Headsets Direct!
May 20, 2010 | Plantronics Explorer 330 Headset
65 jvc iart model 65wp74 ,have a convergence problem,how do i get front panel off and where is circuit board located.Thanks
you need original jvc remote for this to work. Do not open anything until you. Go to menu on your remote find convergence and press the volume button to the right go to manual and press right again. you should see a bunch of rectangles, now you should also see a set of red cross heirs press the #2 to move cross heirs up and eight to move down numbers 4 and 6 will move left and right and 5 will place the cross heirs back to the center once you have chosen the selected section to adjust line up the magenta with the other colors using the channel and volume buttons these move the lines up down left to right adjust all lines until they are white. i do not know how to switch from magenta to green or blue but this should get you started on the right track with out having to replace anything. good luck! if you figure out how to switch from maqgent to green or blue please post it so that I may adjust mine as well tahnks
Feb 23, 2009 | JVC AV-65WP74 Rear Projection Television
Samsung Refrigerator
this is a design fault on the appliance normally caused by the failure of the element and built up of ice around the circulating fan (the humming is the fan motor trying to turn ) youll find that if you defrost it it will work for a little while and then ice up again the need to replace a panel inside the fridge modified and a couple of sensors and poss the heater element
Oct 30, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
