Question about Vivitek D510 Projector
D510 color wheel error - Vivitek D510 Projector
Color wheel error
Optoma HD20 Projector color wheel repair replacement
Here a video of the color wheel replacement on a very similar model.
Aug 19, 2013 | Optoma HD70 DLP Projector
My vivitek d510 projector lamp is not turn on.
You need to check the power supply feed to the lamp circuit and if this is workingg fine check if there is lamp reset- hours used. Also if the filter is blocked remove and clean, check the fan and also the connections/connectors in the mother board.
If not there can be errors in the motherboard.
Sep 28, 2011 | Vivitek D510 Projector
How to turn on the wifi in lattitude d510
Hi Friend, In order to turn on the wireless switch on Dell Latitude D510 laptop you have to press and hold the "Fn" key in blue color and then press the key "F2" for once and then release both of them. It will turn on the wireless switch of the system
Dec 11, 2010 | Dell Latitude D510 Notebook
Dell latitude d510 want power on
Why can't you dell latitude d510 power on?You didn't descript your dell latitude d510 problem clear even.It may be the problem of ram,graphics card ,mainboard,or dell latitude d510 battery.
May 31, 2010 | Dell Latitude D510 Notebook
Check Fan No. 2 Error Message
The DMD board you installed is bad. It senses the detection line from the fan and generates the error code. Try installing the old DMD board.
Mar 15, 2010 | Samsung HL-S5086W 50" HDTV
Compaq Evo D510 errors
the RAM may be corrupted or not properly installed into the slot. also check if the processor fan is working properly.
Nov 19, 2009 | Compaq Evo D510 PC Desktop
Can,t find ethernet controller for evo d510 running windows xp
coppy this link into your browser
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=97128&prodTypeId=12454&prodSeriesId=316510&swLang=13&taskId=135&swEnvOID=1093
and download all the drivers u need and rate this solution after wards
Oct 30, 2009 | Compaq Evo D510 Minitower (Open Box)...
Latitude D510 Hard Drive S/N IDE 167K0396T error. The laptop will not boot. Error test found only 1 location. Read Test error 0f00:0244 at Block 5842740. Can Windows XP be repaired so the computer will...
If boot sector of this hard drive resides on block 5842740 then this is a problem. Try followings...
1. Boot with a XP CD, try to repair. OR
2. When PC boots are you able to go to safe mode by pressing F8? If yes, try Good Known Configuration option first.
3. Otherwise boot in safe mode, go to command prompt, type chkdsk and then reboot your PC and let it check disk. If it ask to find sector and block issues and wanted to gic them automatically, accept it.
Good luck....
Jamil
Oct 05, 2009 | Dell Latitude D510 Notebook
Dell Latitude D510 Screen Failed
The 14.1" inch screen is compatible with Latitude models D500, D505, D510, D600, D610 and Inspiron models 500m, 510m, 600m.
You may also need a screen inverter - in fact that is often the reason a screen is considered to be failing. The lcd inverter can be one of the most common items to become defective in a laptop computer. You may need a lcd inverter replacement if your screen is dim, dark, colored oddly, blinking, flickering or has dark stripes. Just something to keep in mind.
Hope this helps,
Chris
Mar 20, 2009 | Dell Latitude D600 Notebook
Vivitek D510 Projector Logo
Top Vivitek Office Equipment & Supplies Experts
Electro Med Services...
Are you a Vivitek Office Equipment and Supply Expert? Answer questions, earn points and help others
