Question about Exercise & Fitness
Cardiotech x7 e1 code
Has a burning smell from the motor compartment but isn't coming from 1 of the motors. Treadmill will turn on an start but the belt doesn't move. After about 10 seconds the e1 fault code appears
    Top Expert:
  • 12,223 Answers
Test the input terminal motor, if there are the motor is faulty, see my personal TIPS 2) test the output voltage from control board, if there ARE NOT for input voltage motor, the board is faulty. see the diagram attached. 3) the error coming from speed sensor, Run the software calibration for easy diagnostic and fix it. However you must LUBE the deck belt,+rollers bearing front +back see the video attached.
God bless you
Posted on Nov 27, 2013
  • 6 Answers
SOURCE: Treadmill motor not coming on, belt not moving
most likely cause is a burnt out motor controller, you'll need to replace it.
Posted on Mar 17, 2009
  • 192 Answers
SOURCE: Your Problem: Spirit Treadmill motor will not turn on
I'd start by attaching a voltmeter across the motor contacts to see if you get any voltage when the unit is turned on. It's probably an AC motor but I'd check the label to be sure. If you get voltage but no turning either the motor or a startup capacitor is bad. If this is the case try moving the tread by hand with the unit turned on. If it moves on it's own after you start it moving then the start up cap needs to be replaced. Otherwise it may be time to replace the motor. If you don't have voltage across the motor contacts when the machine is turned on, I'd unplug the unit and trace the lines back from the motor to somewhere on the PC board. I'm guessing there's probably a relay on the PC board that controls the motor. I'd use an ohm meter to make sure the relay coil hasn't turned into an open circuit. Next I'd put a voltmeter across the relay coil, plug the unit back in, and turn the treadmill on and off several times. Ideally you should see the voltage across the relay coil go up and down as you turn the treadmill on and off. This voltage could be AC or DC depending on the type of relay used. If you get the proper voltage across the coil but the relay contacts aren’t' opening and closing to provide power to the motor then you need to replace the relay. If you don't get the proper voltage across the relay coil the problem is further back on the PC board.
Posted on May 15, 2009
  • 64 Answers
SOURCE: Treadmill runs then stops. E1 error and sometimes works fine.
Yes if speed sensor is too far from magnet it will not pick up belt movement. This confuses the computer and as a safety precaution it shuts the machine off. Find speed sensor and check for proper alighment with magnet.
Posted on Jun 08, 2009
SOURCE: I have a horizon fitness, Quantum II treadmill.
im having this problem too if some one could email me how to fix it @ djbense@hotmail.com
cheers
Posted on Feb 26, 2010
  • 33 Answers
SOURCE: Treadmill cuts out after 10 seconds and gives an E1 message.
Your problem might be that a magnet has fallen out of place. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Posted on Oct 09, 2010
Merit 725 T plus reading E1
If you wish to get some details about treadmill error codes and repair; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Nov 28, 2016 | Exercise & Fitness
Technofit TS500i treadmill error code?? ( E1 & E2) please help!!!!!!!!!
Dear Sir:
The error code E1or E2 coming from this reasons.
1) Adjust the speed sensor, see the diagram attached, clean, and tight the connector wires.
2) Test the main motor input voltages coming from the output from the main motor board.
3) The main motor or motor board can be faulty or need repair.
See my personal TIPS for HELP and guide you.
sincerely. God bless you
Apr 23, 2012 | Exercise & Fitness
NordicTrackl c2300 model NTL12944 bad burning smell
Dear Sir:
You have 4 conditions when burning smell:
1) Very high belt/deckfriction.(Lack of lubrication by maintenance2) Short in the motor.(The same problem maintenance)3) Short in the wiringor electronics.You must have some skill in electricity or electronic or you can cal some service tech.4)Literally cooking the lacquer or cardboard core (on cheap machines) in themotor from belt friction or a drive system,The same lack of maintenance and lubrication.
And recommend that RUN the Calibration Software for easy diagnose and troubleshooting that coming with your treadmill, most of them the instruction step coming from the Hood of motor, and follow the instruction, or use your manual Ins.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Feb 12, 2012 | Exercise & Fitness
E1 error code
Lets eliminate the motor first, unplug unit remove motor shroud fin the 2 leads from motor to lower board. Connect a 18v DC battery to the leads this start the motor to move at approx. 1 mph if it does motor is good,if not you may worn motor brushes worst case open connection in the motor.
Now if the motor is good then reconnection the leads and plug in unit the lower board should have some LEDs lit up. Now find the LED that says PWM start unit if that light should start to flicker then the upper board and wire harness are work properly. Turn off the treadmill then turn it on and with a multi meter insert the leads into the connectors that go to the motor, then put the meter on 200v DC then start the treadmill you should get a reading 5 to 10v DC if you get 0v DC then the board will need replacing
Jul 07, 2010 | Cardiozone Supersport Hr Club Commercial...
I have a v-fit PST-04 treadmill, model no DK 2510. When I switch it on and try and use it, it comes up with the Error Code E1 what does thos mean
Most E1 codes are speed sensor or no belt movement.
You wil lneed to unplug your unit the remove the motor shroud then plug unit in most Motor Control boards have LEDs. First thing I would do is start the unit look down at the board one of the light should start flickering this is a signal being sent to the lower board from your upper console. This tells me that the upper console and cable connecting the upper and lower boards is working also notice if the drive motor moved if not then E1 will come up. Now turn your unit off then turn back on to reset , next manually push with one of your feet the belt you should notice another flickering light the faster you push the light will flicker faster this tells me that the speed sensor is working if not replace the speed sensor. Next procedure check the motor using a fully 18v drill battery or car battery which ever is handy connect the two motor leads usually red and black in some cases black and white to the battery, if the motor move at a speed of approx. 1 mph then you have a good motor if not you can have worn motor brushes or open winding the motor.
If the upper board and drive motor are good then the only thing left is the motor control board if you have a multi meter handy connect the lead to the two spades that motor lead came off of the press start you should get a DC voltage of about 5 to 10V DC if not replace the board.
May 31, 2010 | Exercise & Fitness
My tunturi treadmill 661f is showing E1 on the
E1 error code : Unplug unit remove motor shroud and check the distance between the speed sensor and the flywheel and ensure that the speed sensor is properly attached to the motor frame. Check also speed sensor connections.
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
Check the motor brushes either they worn or not sitting properly
May 16, 2010 | Exercise & Fitness
Error message E1
hi there we have an E1 error after 7 seconds of operation??
Apr 09, 2009 | Exercise & Fitness
Tredmill error code e1
Trimline treadmill starts up then code E2 comes up, and the display shuts down.
Any ideas???
Apr 02, 2009 | Nautilus Tr300 Treadmill
Exercise & Fitness Logo
335 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
