Question about Konica Minolta magicolor 2400 Laser Printer
Replace drum fuse 2400 - Konica Minolta magicolor 2400 Laser Printer
KONICA MINOLTA 2400W PRINT BLANK PAGES
Verify the drive transmission mechanism to developing unit,the image transfer current terminal and the scanner drive transmission mechanism.
Feb 13, 2013 | Konica Minolta magicolor 2400 Laser...
Where is the drum unit based
The drum unit is based into your printer. You have to open the front cover door and take out the drum unit along with all color toner cartridges.
For more information on replacing your drum unit check this useful information.
May 16, 2012 | Brother MFC-9320CW Color Laser Printer -...
On a Cannon Color laser copier 2400 We are getting an error code of E-061-0322 And ideas whats wrong with it or better yet how to fix it.
Hi MM. That code means the cyan drum is fried,OR the CLC 2400 "thinks" the cyan drum is defective as the copier has done a self diagnostic and determined that the most likely problem is the cyan drum.You must run alot of color(duh.....clc) and so if I were you I would consider if it might not be a good time to replace more than the cyan drum. Perhaps all 4. Easy for me to tell you to spend all that money.It's possible that the sensors that monitor the quality of the colors is merely dirty.But I'm afraid either way you will need "Copier Dude" to stop by.I wish I had better news but at least you will have a basis to start from. Take care.
Jan 06, 2011 | Canon CLC 2400 Color Copier
How do you empty the drum on the konica minolta 2400w
in the back side of the drum unit is an fuse
just replace the fuse
Jul 20, 2009 | Konica Minolta magicolor 2400 Laser...
Replaced drum error light blinking
Start the Konica Minolta Status application on your PC and check the error, you should get more info there.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Apr 14, 2009 | Konica Minolta magicolor 2400 Laser...
KM 2400w Laser Printer - Going through drums too fast
Go to the link below, you'll find the solution:
http://www.resetkit.eu
Apr 03, 2009 | Konica Minolta magicolor 2400 Laser...
Konica Minolta Magicolor 2400W drum cartrige-how to replace?
Did you buy a whole new drum unit, or just change the cartridge? If so, the fuse may still be blown. Also, you may need to empty the spent toner out of the old cartridge.
Oct 07, 2008 | Konica Minolta magicolor 2400 Laser...
OPC Drum Error
Replacing the fuse is only half the job. You also need to empty all the spent toner out of the drum as well. I actually drilled a 1/4 inch hole, poured out all the purple toner, and covered the hole with an old 5 1/4 floppy write protect tab. Any good piece of heat resistant tape should do. Then replace the fuse. Make sure that the contacts the fuse rests on are clean as well.
Aug 23, 2008 | Konica Minolta magicolor 2400 Laser...
MINOLTA 2400W
try installing it again, first turn off the printer.and then turnit on again. if that wount help, under the cartridge in left or right side, there is a small fuse, you can testit with tester, is it OK, if not, by new fuse
Jan 22, 2008 | Konica Minolta magicolor 2400 Laser...
Minola print smudge
Pleas check the imagine unit drum, is it clean or does there are the same marks as in paper.
if yes, the IU drum cleaning or drum itself is damaged and needs to be replaced.
Try:
after sending a print job, when printer has take a paper from tray, open cover, open cover before the paper enter the fusing unit, then you can see, if the mark is allready in the paper then the problem is in the IU or toner cartridge, if not, then fusing unit rollers.
Dec 31, 2007 | Konica Minolta magicolor 2400 Laser...
Konica Minolta magicolor 2400 Laser Printer Logo
16 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
