Question about Mitsubishi WS-65513 65" Rear Projection HDTV
I have a rear proj 65" about 6 yrs old. 2. problems. Most important right now is that it turn off a few seconds after I turn it on. I hear the electronic click, see the green light by the button illuminate then it pops off before any picture comes up 2nd problem, Intermitant warped picture, seperation of Red Green & Blue, ghosting.then snaps back and forth to and from normal. Please help!!
  • Brian B May 11, 2010
    is thas an lcd rear projector or dlp projector
    Sniper:
  • 64 Answers
This is definitely a problem you don't want to tackle at home. TV's are made to kick off when it knows a problem exists. The warped pic is a "convergence IC" issue. That IC needs to be replaced by a tech, either in home or in shop.
Posted on May 08, 2009
    Problem Solver:
  • 7 Answers
You have defective Convergence IC's and possibly bad yoke return resistors located right by the IC's.
Craig
I TOOK APART THE TV TO MOVE IT DOWNSTAIRS AND it worked great for 10 minutes and then shut down. I have the code and it is green and 2 and 2
That is called the "Parpadeo luz verde de la muerte" or Blinking green light of death. You may want to make sure all the wires are tight first and that when you moved it a cable wasn't seated. Instead of replacing the capacitors, your situation sounds more like bad solder connections on the DM module. Here is a link to a web forum where they talk about this exact problem.http://www.highdefforum.com/rear-projection-tvs/58189-blinking-green-light-death-frequent-prob-w-mitsubishi-rear-proj-widescreens.html Blinking Green Light of ***** frequent prob Mitsubishi rear proj...
Jun 25, 2015 | Mitsubishi WS-65413 65" Rear Projection...
WHY DOES IT KEEP TURNING OFF
Yes. Rear-proj.with 3 picture tubes. These, like most newer tvs have self-checks that shut the tv off if the fault could worsen problems for the TV (such as damage picture tubes.) or it's not able to put a picture up.
After it shuts off, you can press menu and input/device together for 5 secs, and it will flash a 2-digit code (such as "23" or "24", etc.)(vertical or horizontal error.) Though you will need to call a repair shop for repair. It's usually better if they are Mits. factory authorized, as they'll likely have more exper. on Mits.
Apr 24, 2014 | Mitsubishi WS-65511 65" Rear Projection...
Not powering on ?
when i plug up my hitachi 61sbx59b proj. tv.
the green lights in the back come on ,a few seconds after them set tries to come up, you can hear the hv. for a fraction of a second then it shuts down.
Initially ceramic fuse was open but replacing it made no diference,r760 seems over heated,(dont know if connected).
GIL SCOTT
May 15, 2010 | Hitachi 61SBX59B 61" Rear Projection...
Picture is very dark and hard to see
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is UX21513.You can find it here: http://www.discount-merchant.com/Hitachi-UX21513-LM500-Replacement-UHP-Lamp-Proj-p/hitach-ux21513-lm500-lamp-bulb.htm?Click=48173 Have a blessed one!
Apr 04, 2010 | Hitachi 50V715 50" Rear Projection...
I have a Mitsubishi medallion 65 and it keeps turning off,
Dear Sir,
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times.
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source)
1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 PART # 283P044020 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. I hope this helped.
Good Luck, big IRISH.
Dec 08, 2009 | Mitsubishi WS-65411 65" Rear Projection...
Rear proj TV picture keeps blinking out
comon sony problem Sony has and Ik circuit tha is suppose to not allow video in there is an uneven emission from the crts what you have on both sets the tube are getting so weak causing the circuit to kick in and out in other word you need crts inboth set and they are not avail new you can have them rebuild but the set will never look good again time to retire them
Dec 01, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Wont turn on. Green light comes on for a few seconds, andthen goes back o0ff.
Hi if its a Lcd or Dlp rptv most likely its time to replace the lamp if tv is between 2-4 yrs.If you hear clicking it could be the ballast which is the board that powers the lamp.Make sure fans are running ok ,dust them out if they are dirty.God bless you!
Oct 07, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WD-57734 TV Powers on, Have sound, No Pic, Shuts down!
Hi,if you hear constant clicking or trying to turn on it could be your ballast.But if tv is between 1 yr -2 yrs maybe its time to replace the lamp.This will be the part number you need 915P061010 you can find it in discount-merchant to get the Philips lamps that normally last 2-4 yrs.God bless. The price will be around $129.99 you can replace it your self just put the part number 915P061010 on youtube and you'll see instructions to replace lamp.
Sep 30, 2009 | Mitsubishi WD-57734 57" HDTV
65" toshiba projection tv no picture but has sound..
if you could hear only sound in tv and not picture means it might be the picture tube problem just check it.
Sep 17, 2009 | Toshiba 55H70 55" Rear Projection...
Akai pt4298hd rear proj tv
Unit may be in timer mode. Check menu settings
Apr 22, 2008 | Akai PT4298HD Rear Projection Television
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
106 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
