Question about Alpine NVE-P1 Navigation Add-in Unit for IVA-W505
Won,t turn on
Worked on engine of vehicle now radio is messed up and it's not working
2008 saturn aura change the radio because the aux cord was messed up So i ordered another stock radio and plugged it in and it didn't turn on or anything put the old radio back and it worked just fine
Edgar, Strange old radio is fine now, maybe it was just a bad connection or ground. New radio maybe had to be programmed with a code to get up and working. Not sure ?
Apr 09, 2016 | Saturn Cars & Trucks
I have a 2004 saturn ion that currently got cought in the middle of a flood and now won't turn over the lights and the radio works perfectly fine but when I go to start it up it says service vehicles...
it has go into servise mode. you need to get it checked and have the sevise codes removed. the flood warter would of set this off if the service code was not remover from its last service.
Sep 15, 2013 | Cars & Trucks
The kenwood KDC-MP333 in my truck is connected to a set of kenwood speakers. But when I turn it on they won't work the stereo still shows the display but when I turn the stereo on it makes a sort of...
Disconnect the speakers and try it with another speaker or speakers not in the truck. If it works, the speakers or the wires to them are messed up. If it doesn't you probably damaged the output capacitor in the radio by turning it on without speakers attached. Realize that the speakers are part of the radio circuit and act as resistance. Without them, there is no resistance and it puts a strain on the radio.
Jan 02, 2013 | Car Audio & Video
If the radio works but the car won't start could it still be the battery
Yes.it takes more amps.to start your vehicle than run the radio
Sep 10, 2012 | Chevrolet Cobalt Cars & Trucks
My car won't start and key won't come out.
I hate to be the bearer of bad news, but your vehicle is NOT fixed. Fuses do not just go around blowing to make your day miserable - ESPECIALLY not a 60 Amp MAXI fuse! That is some SERIOUS stuff!
There is apparently an intermittent dead short to ground in one of your main power circuits if one of those are blowing. It WILL do it again if you do not locate the problem and repair it. I just hope you get it fixed before it burns your vehicle to the ground.
May 16, 2012 | 1997 Oldsmobile Achieva
Dish washer won't turn on when start button is pressed
Check your door switch. My dish washer would not work a couple of months ago, tore apart and messed with door switch and it has worked every since.
Dec 22, 2011 | Washing Machines
2003 Monte Carlo SS, FOBS won't unlock doors (new batterries), use key and open the door with the door open FOB will lock and unlock the door, shut the door and the FOB won't lock the doors. After...
If the passkey is messed up, there will be a light on the dash that says security, or have a picture of a car with a lock thru it. If there is no light when the key is turned forward, then its NOT a passkey problem.
Aug 17, 2011 | 2003 Chevrolet Monte Carlo
Engine Won;t Turn Over when starting
GLAD TO SEE IT WAS THE BATTERY. PLEASE RATE MY SOLUTION.
Jan 15, 2009 | 1997 Cadillac Seville
Radio, dome lights and EVIC power problem
I found a paritally blown fuse. When the fuse blew metal pieces ended up partially making contact. After replacing the fuse everything worked great.
Jan 07, 2009 | 1994 Jeep Grand Cherokee
Alpine NVE-P1 Navigation Add-in Unit for IVA-W505 Logo
66 people viewed this question
Top Alpine GPS Experts
Shehu Pro
Shehu Pro
richie46
Are you an Alpine GPS Expert? Answer questions, earn points and help others
