Question about HP Designjet 4500ps InkJet Printer
Error 01.0:01 - HP Designjet 4500ps InkJet Printer
More than one error code 01 on electrolux dishwasher
Good Morning Friend,
I understand you are receiving more than one, error code "01" on your Electrolux dishwasher. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose your appliance and determine why you are still receiving an error "01" on your dishwasher. Hope this is helpful.
-Best Regards-
WP
Jun 18, 2014 | Electrolux Dishwashers
System error 86:01
System Error 86:01, Noise Along the Carriage Path carriage moves or system error 86:01 is being displayed on the printer's front panel. General causes are media or other obstructions in the carriage path, the trailing cable, worn carriage bushings, lack of lubrication in the carriage path, a dirty encoder strip, the scan-axis motor, or the service station.
Troubleshooting this error is a bit complex, you have to check for paper jams and determine the source of the noise, if there is one.
Try checking this document for steps to determine the cause and solution to this issue.
HP Designjet 500 and 800 Series Printers TWI System Error 86 01 Noise...
Aug 08, 2013 | HP DesignJet 500 InkJet Printer
H5-01 error on sharp AR-M450N
Sharp AR-450 H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error C1 00 MC unit malfunction C2 00 TC unit malfunction E7 00 Image Processing Unit error 01 Memory back-up battery dead 02 Laser unit problem 03 HDD defective 10 black level calibration error 11 white level calibration error 13 CCD calibration error 90 Image Processing Unit error F1 00 Lost communication with the Sorter 01 Sorter registration problem 02 Paper transport motor overloaded in sorter 04 Bin position error in sorter 05 Bin position error in sorter 06 Shift sort motor overloaded 08 Stapler position error 08 Stapler overloaded 11 Sorter problems 14 Second shift tray jammed 15 Sorter drive problems 50 Sorter not installed properly 80 No powerin sorter F2 00 ID pattern reading error 02 Toner add mechanism malfunction 31 ID pattern reading error 32 ID pattern reading error 39 Drum thermistor error F3 12 Paper does not lift in the tray 22 Paper does not lift in the tray F9 00 Printer board problems 01 Printer board problems 02 Printer board problems 03 Network card error 04 Firmware error 05 Not enough memory 10 Printer board problems 90 Printer board problems H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error 02 Zero cross signal error U2 00 EPROM error 11 EPROM error U4 02 Duplex not working properly 03 Duplex problems U5 00 Communication with the ADF is lost 01 Registration sensor problem in ADF 02 Exit sensor error in ADF 03 Timing sensor problems in ADF 11 Paper feed drive overloaded in ADF U6 01 Paper lift problem in 1'st optional tray 02 Paper lift problem in 2'nd optional tray 08 Paper feed unit without power 10 PFU paper transport motor overloaded 22 Paper feed unit without power 50 Paper feed unit not installed properly 51 LCT not installed properly U7 00 Main board malfunction U9 00 Op panel problem 90 Op panel problem EE EU Low toner density in the developer EE EL High toner density in the developer FA 01 Memory back-up battery dead PC Key counter not installed
Apr 01, 2010 | Sharp AR-M450N Copier
Sharp ar 122 ccd trouble how to repaire
Sharp AR-122 Код ошибки Подкод Описание C1 00 MC unit malfunction C2 00 TC unit malfunction E7 00 Image Processing Unit error 01 Memory back-up battery dead 02 Laser unit problem 03 HDD defective 10 black level calibration error 11 white level calibration error 13 CCD calibration error 90 Image Processing Unit error F1 00 Lost communication with the Sorter 01 Sorter registration problem 02 Paper transport motor overloaded in sorter 04 Bin position error in sorter 05 Bin position error in sorter 06 Shift sort motor overloaded 08 Stapler position error 08 Stapler overloaded 11 Sorter problems 14 Second shift tray jammed 15 Sorter drive problems 50 Sorter not installed properly 80 No powerin sorter F2 00 ID pattern reading error 02 Toner add mechanism malfunction 31 ID pattern reading error 32 ID pattern reading error 39 Drum thermistor error F3 12 Paper does not lift in the tray 22 Paper does not lift in the tray F9 00 Printer board problems 01 Printer board problems 02 Printer board problems 03 Network card error 04 Firmware error 05 Not enough memory 10 Printer board problems 90 Printer board problems H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error 02 Zero cross signal error U2 00 EPROM error 11 EPROM error U4 02 Duplex not working properly 03 Duplex problems U5 00 Communication with the ADF is lost 01 Registration sensor problem in ADF 02 Exit sensor error in ADF 03 Timing sensor problems in ADF 11 Paper feed drive overloaded in ADF U6 01 Paper lift problem in 1'st optional tray 02 Paper lift problem in 2'nd optional tray 08 Paper feed unit without power 10 PFU paper transport motor overloaded 22 Paper feed unit without power 50 Paper feed unit not installed properly 51 LCT not installed properly U7 00 Main board malfunction U9 00 Op panel problem 90 Op panel problem EE EU Low toner density in the developer EE EL High toner density in the developer FA 01 Memory back-up battery dead PC Key counter not installed
Apr 23, 2009 | Sharp Office Equipment & Supplies
Paper tray will not go up or down. Cannot get it to move.
Sharp AR-650 Код ошибки Подкод Описание C1 00 MC unit malfunction C2 00 TC unit malfunction E7 00 Image Processing Unit error 01 Memory back-up battery dead 02 Laser unit problem 03 HDD defective 10 black level calibration error 11 white level calibration error 13 CCD calibration error 90 Image Processing Unit error F1 00 Lost communication with the Sorter 01 Sorter registration problem 02 Paper transport motor overloaded in sorter 04 Bin position error in sorter 05 Bin position error in sorter 06 Shift sort motor overloaded 08 Stapler position error 08 Stapler overloaded 11 Sorter problems 14 Second shift tray jammed 15 Sorter drive problems 50 Sorter not installed properly 80 No powerin sorter F2 00 ID pattern reading error 02 Toner add mechanism malfunction 31 ID pattern reading error 32 ID pattern reading error 39 Drum thermistor error F3 12 Paper does not lift in the tray 22 Paper does not lift in the tray F9 00 Printer board problems 01 Printer board problems 02 Printer board problems 03 Network card error 04 Firmware error 05 Not enough memory 10 Printer board problems 90 Printer board problems H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error 02 Zero cross signal error U2 00 EPROM error 11 EPROM error U4 02 Duplex not working properly 03 Duplex problems U5 00 Communication with the ADF is lost 01 Registration sensor problem in ADF 02 Exit sensor error in ADF 03 Timing sensor problems in ADF 11 Paper feed drive overloaded in ADF U6 01 Paper lift problem in 1'st optional tray 02 Paper lift problem in 2'nd optional tray 08 Paper feed unit without power 10 PFU paper transport motor overloaded 22 Paper feed unit without power 50 Paper feed unit not installed properly 51 LCT not installed properly U7 00 Main board malfunction U9 00 Op panel problem 90 Op panel problem EE EU Low toner density in the developer EE EL High toner density in the developer FA 01 Memory back-up battery dead PC Key counter not installed
Apr 19, 2009 | Sharp AR-650 Copier
Visual studio instalation problem
just take a look to this site:
http://www.codeproject.com/
you will get your answer there easily.enjoy it!
Feb 23, 2009 | Microsoft Visual Studio® 2005 Professional...
Same Problem Again - Mega Raid.... Unknown Error
Hi
The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
However, the extract posted in your suggests network problems.
Any number of physical to driver and configuration issues can result in network problems.
Try the basic checks;
1. Change or try a known patch cable
2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
4. Can you try another switch
5. Check and load correct or latest manufacture's drivers
Reply with more info.
Mike
Jan 23, 2008 | Dell PowerEdge 1800 Server
Kodak i640 communication Error
I Have had the same problem. I changed the power supply an the error was never detected
Feb 08, 2007 | Kodak i640 Path-Through Scanner
HP Designjet 4500ps InkJet Printer Logo
16 people viewed this question
Seeker5211
Seeker5211
