Question about Epson EPL-N3000 Laser Printer
Didn't work paper out mp ctm
How do i disconnect fuse to seat belt alarm tried three time method didnt work
The seat belt warning chime is controlled by the central timer module ! You can't just disconnect fuses , other things may stop working !
Safety Belt Warning Indicator Lamp and Chime
The safety belt indicator and chime feature is controlled by the CTM. The driver safety belt switch is hardwired to the CTM. If at any time during the first 60 seconds after the ignition switch is placed in position II, if the driver safety belt is sensed as being unfastened, the CTM will process the input, and in turn, output a signal to the CTM through a hardwired circuit. In turn the CTM will output a visual warning to the instrument cluster. If at any time during the first six seconds after the ignition switch is place in position II and the safety belt is not fastened, the safety belt warning chime will sound.
When the seat belt is connected the warning still chimes ? Could have code stored in the CTM .
B1464 Safety belt switch circuit short to battery CTM Go To Pinpoint Test B .
SoW
Jun 30, 2015 | 2002 Ford SVT Focus
Dodge dakota headlight
The most likely cause of this is a failing Central Timer Module (CTM). The CTM directly supplies power to the headlamps and dash illumination. The head lamp switch sends a signal to the CTM, and then the CTM sends power to the lamps. Replacing the CTM should take care of this.
May 15, 2013 | 2003 Dodge Dakota Club Cab
Ford Explorer wipers, power windows, doom lights won't work
Are u assuming the GEM module is at fault ? Did you or your local auto electrician check for DTC'S - diagnostic trouble codes?
GEM/CTM Wiggle Test Diagnostic Trouble Code (DTC) Index DTC Description DTC Caused By B1317 Battery Voltage HIGH GEM/CTM B1318 Battery Voltage Low GEM/CTM B1322 Driver Door Ajar Circuit Short to Ground GEM/CTM B1330 Passenger Door Ajar Short to Ground GEM/CTM B1352 Ignition Key-In Circuit Failure GEM/CTM B1410 Driver Power Window Motor Circuit Failure GEM B1438 Wiper Mode Select Switch Circuit Failure GEM/CTM B1441 Wiper Mode Select Switch Short to Ground GEM/CTM B1446 Wiper Park Sense Circuit Failure GEM/CTM B1450 Wiper/Wash Interval Delay Switch Input Circuit Failure GEM/CTM B1453 Wiper/Wash Interval Delay Switch Input Short to Ground GEM/CTM B1462 Seat Belt Switch Circuit Failure GEM/CTM B1577 Park Lamp Input Circuit Short to Battery GEM/CTM B1610 Illuminated Entry Input (From RAP Module) Circuit Short to Ground GEM/CTM
Did you an your auto electrican check power an grounds for the GEM ? Voltage drop testing ? . Did you check power an ground circuits for the affected systems . Working when they want sounds more like a loose connection somewhere .
ECM Inputs and Outputs Diagnosis
Symptom Chart
Symptom Chart Condition Possible Sources Action
  • The Wipers Are Inoperative
  • CJB Fuse 16 (30A).
  • Circuitry.
  • GEM/CTM.
  • Multi-function switch (13K359).
  • Wiper run/park relay.
  • Wiper HI/LO relay.
  • Wiper motor.
  • DTC B1431.
  • DTC B1432.
  • DTC B1438.
  • DTC B1450.
  • DTC B1840.
  • GO to Pinpoint Test A .
Plus looking at GEM scan data on a factory scan tool .Too many people miss diagnose these system's because they don't have a clue .
Jul 03, 2017 | 1999 Ford Explorer
My lights and central lock are no longer working in my 2003 Dodge Dakota. How do I fix it?
Hi you need a new CTM (central time module)
Here is the location
when your siting in the truck it is behimd the panel next to your left foot 3 wire plugs and 4 screws remove it
80bcf9db.gif spacer.gif spacer.gif View Full Image spacer.gif 1 - CENTRAL TIMER MODULE 2 - COWL SIDE INNER PANEL 3 - SCREW (3) 4 - HEADLAMP & DASH WIRE HARNESS CONNECTOR 5 - INSTRUMENT PANEL AND BODY WIRE HARNESS CONNECTORS
DESCRIPTION Two versions of the Central Timer Module (CTM) are available on this vehicle, a base version and a high-line version (Central Timer Module). Whichever version of the CTM the vehicle is equipped with, it is concealed behind the trim on the left cowl side inner panel below the instrument panel, where it is secured with three screws. The CTM is enclosed in a molded plastic housing with three integral external connector receptacles that connect it to the vehicle electrical system through one take out and connector of the body wire harness, and two take outs and connectors of the instrument panel wire harness. The base version of the CTM is used on base models of this vehicle. These base models are not equipped with the optional power lock system, the Remote Keyless Entry (RKE) system, the Vehicle Theft Security System (VTSS), or the remote radio controls. The high-line version of the CTM is used on high-line vehicles that are equipped with one or more of those options not found on base models.
The CTM utilizes integrated circuitry and information carried on the Programmable Communications Interface (PCI) data bus network along with many hard wired inputs to monitor many sensor and switch inputs throughout the vehicle. In response to those inputs, the internal circuitry and programming of the CTM allow it to supply the vehicle occupants with audible and visual information, and to control and integrate many electronic functions and features of the vehicle through both hard wired outputs and the transmission of electronic message outputs to other electronic modules in the vehicle over the PCI data bus.
The features that the CTM supports or controls include the following:
  • Automatic Door Lock - The high-line CTM provides an automatic door lock feature (also known as rolling door locks). This is a programmable feature.
  • Battery Protection - The CTM provides a battery saver feature that performs timed load shedding whenever courtesy, reading, visor vanity, center console, glove box, cargo lamps, or any exterior lamps are left on with the ignition switch in the Off position.
  • Central Locking - The high-line CTM on vehicles equipped with the optional Vehicle Theft Security System (VTSS) includes a central locking/unlocking feature.
  • Chimes - All versions of the CTM provide chime service and beep request service through an integral chime tone generator.
  • Door Lock Inhibit - The high-line CTM provides a power door lock inhibit feature.
  • Enhanced Accident Response - The high-line CTM provides an optional enhanced accident response feature. This is a programmable feature.
  • Exterior Light Features - The CTM provides control of park lamps, fog lamps, and headlamps. This includes support for optical horn (also known as flash-to-pass), headlamp time delay, cargo lamps, daytime running lamps (DRL - Canada only), and battery saver features.
  • Interior Light Features - The CTM provides control of courtesy lamps and dome lamps. This includes support for a timed illuminated entry with fade-to-off, interior lighting delay, courtesy illumination defeat, and battery saver features.
  • Intermittent Wipe Control - The CTM provides control of the intermittent wipe delay, and wipe-after-wash features for the wiper and washer system.
  • Panic Mode - The high-line CTM provides support for the optional RKE system panic mode including horn chirp, headlamp flash, and park lamp flash features.
  • Power Lock Control - The high-line CTM provides the optional power lock system features, including support for the automatic door lock and door lock inhibit modes.
  • Programmable Features - The CTM provides support for certain programmable features.
  • Remote Keyless Entry - The high-line CTM provides the optional Remote Keyless Entry (RKE) system features, including support for the RKE Lock (with optional horn chirp and park lamps flash), Unlock (with optional park lamps flash), Panic, and illuminated entry modes, as well as the ability to be programmed to recognize up to four RKE transmitters. The RKE horn chirp, park lamps flash features are programmable. On quad cab models only, a driver-door-only unlock or unlock-all-doors feature is also programmable.
  • Remote Radio Switch Interface - The high-line CTM monitors and transmits the status of the optional remote radio switches on the steering wheel.
  • Speed Sensitive Intermittent Wipe Control - The CTM provides a speed sensitive intermittent wipe feature.
  • Vehicle Theft Security System - The high-line CTM provides control of the optional Vehicle Theft Security System (VTSS) features, including support for the central locking/unlocking mode and control of the Security indicator in the instrument cluster.
Hard wired circuitry connects the CTM to the electrical system of the vehicle. These hard wired circuits are integral to several wire harnesses, which are routed throughout the vehicle and retained by many different methods. These circuits may be connected to each other, to the vehicle electrical system and to the CTM through the use of a combination of soldered splices, splice block connectors, and many different types of wire harness terminal connectors and insulators. Refer to the appropriate wiring information. The wiring information includes wiring diagrams, proper wire and connector repair procedures, further details on wire harness routing and retention, as well as pin-out and location views for the various wire harness connectors, splices and grounds.
All versions of the CTM for this model are serviced only as a complete unit. Many of the electronic features in the vehicle controlled or supported by the CTM are programmable using the DRBIII® scan tool. In addition, the CTM software is Flash compatible, which means it can be reprogrammed using Flash reprogramming procedures. However, if any of the CTM hardware components are damaged or faulty, the entire CTM unit must be replaced. The hard wired inputs or outputs of all CTM versions can be diagnosed using conventional diagnostic tools and methods; however, for diagnosis of the CTM or the PCI data bus, the use of a DRBIII® scan tool is required. Refer to the appropriate diagnostic information.
Jul 13, 2010 | 2003 Dodge Dakota Club Cab
I keep geting remove MP paper
This indicates that the machine 'sees' paper loaded in the multipurpose (MP) paper tray. In order for the machine to print faxes and machine generated reports and lists, this tray must be empty as the machine prints from the cassette. Remove paper from the MP tray.
Jan 18, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
The printer display: paper out MT CTM
which paper tray is out.
The top or bottom?
Jun 22, 2009 | Canon PIXMA MP980 All-In-One InkJet...
Time delay relay for interior lights
I would suspect you have a bad door switch on one of the doors or liftgate. They are usually plunger switches. Try pusing them in one at a time and see f the lights go out. Hold it in long enough to account for the time delay.
please rate if this helps you.
  • The Courtesy Lamps Stay On Continuously
  • Circuitry.
  • GEM/CTM.
  • Ignition switch.
  • Interior lamp relay.
  • Dimmer module.
  • Door ajar switch.
  • DTC B1322.
  • DTC B1330.
  • DTC B1334.
  • DTC B1338.
  • DTC B1371.
  • DTC B1574.
  • DTC B1610.
Generic Electronic Module (GEM)/Central Timer Module (CTM) Controlled Functions
The generic electronic module (GEM) is equipped on four-wheel drive vehicles with power windows. The central timer module (CTM) is equipped only on two-wheel drive vehicles without power windows.
NOTE: GEM/CTM diagnostics are compatible with New Generation STAR (NGS) Tester.
The GEM/CTM incorporates the functions of several different modules into one, and offers diagnostics to easily locate and repair concerns affecting the subsystems that it controls.
The GEM/CTM constantly monitors the systems under its control and reports a concern in the form of a diagnostic trouble code (DTC). A DTC can be retrieved with NGS Tester through the communication link.
NGS Tester is a menu-driven tester that allows the user to run specific tests. NGS Tester can isolate faults in the GEM/CTM subsystems through a symptom-driven diagnostic procedure. Connecting NGS Tester to the GEM/CTM communication link will not alert the GEM/CTM. If the GEM/CTM is "asleep" when the diagnostic connector is plugged in, the GEM/CTM must be "awakened". If the communication link cannot be established, it is advised to turn the ignition to RUN.
NOTE: The GEM/CTM has a sleep function to minimize battery consumption. During the sleep mode, the GEM/CTM turns off all outputs and monitors only the following:
  • Door ajar (driver door, passenger door, liftgate, LH rear and RH rear doors).
  • Key-in-ignition.
  • Key in RUN or ACC.
  • Two-step unlock switch (unarm switch).
  • Digital TR sensor.
  • Illuminated entry request (remote anti-theft personality [RAP] module).
If a change of status occurs at one of these inputs while the GEM/CTM is asleep, the GEM/CTM will "wake up." When the GEM/CTM awakens, it performs an internal self-test, and begins normal operation. At this point, the GEM/CTM will have all of its functions operational.
The GEM/CTM will go into the sleep mode immediately after both of the following conditions have been met:
  • Key in OFF or key not in ignition.
  • After 45 minutes with no change in any wake-up input.
The GEM/CTM control system has two modes of operation; the normal operating mode and the tester-dependent diagnostics mode.
The normal operation of the GEM/CTM can detect errors. An integral part of the normal GEM/CTM operation is the continuous diagnostic capability. Continuous diagnostics detects errors and changes the GEM/CTM control strategy. There is no warning lamp for the GEM/CTM; therefore, a DTC concern will direct you to the GEM/CTM. Examples of faults that may be detected during normal operation include:
NOTE: The GEM/CTM can only detect open circuit/short to GRD faults when the GEM/CTM in not energizing a load, and short to battery faults when the GEM/CTM is attempting to energize a load.
  • GEM/CTM continuous self-test (RAM, ROM, EEPROM, A/D checking).
  • Output driver monitoring (open circuit/short to ground [GRD], short to power).
  • Illogical combinations of input signals.
Apr 28, 2009 | 1998 Ford Explorer
Printer error reads 'Paper Out MP CTM'
Sounds like the document that is being sent to the printer, or the one if pending prints are present, has a page size set to other than what the printer has its set to for the tray feed (or tray feed is set wrong), so it is defaulting to the Manual Feed for insertion of correct medium CTM (not sure if int. but thats maybe a country thing we use A4, ENV and B5 mainly
Dec 01, 2008 | Epson AcuLaser C3000 Printer
IBM infoprint 1422 won't feed through paper tray, only works with mp loader
Ok.... I have these printers at work...and i think i have figured this one out :
Under setup menu , goto configure mp , then switch the settings from cassette to manual. You see these printers are used at Hotels where the bottom tray is for legal size paper used to make key packets and the mp is used for regular sized paper printing reciepts....Hilton family hotels use them for example....the next thing I'm trying to figure out is how to set it so I won't have to push the go button every time I print something
Oct 22, 2008 | IBM Infoprint 1422 Laser Printer
Lexmark T644 MP Feeder STOP ASKING FOR MP FEEDER???!!!
Thanks mate, it worked for me too and my works printers (work in IT and this 'error' was driving us crazy)
Jul 29, 2008 | Lexmark T644 Laser Printer
Epson EPL-N3000 Laser Printer Logo
27 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
