Question about ASUS F5VL-A2 Notebook
No slider to change resolation to small - ASUS F5VL-A2 Notebook
Low brightness. Can not adjust. Push brigntness function on screen and no slider comes up on screen. I have a Z665C and know how to adjust brightness.
Go to Control Panel, make sure that view by is on large icons or small icons and choose Power Options.
Click "change plan settings" next to the active dot. Then use the slider to adjust plan settings
Dec 06, 2015 | Computers & Internet
How can i resol the error h4-00 manual
clear>interupt>0>interupt>1>4>start button>1>start button
Apr 30, 2014 | Sharp AL-1655CS Copier
Shoes resoled
it is possible to get these resoled. I have seen hush puppies resoled several times.
Jan 10, 2014 | Hush Puppies Clothing Accessories
How do i change image size
Right click on desktop and select properties>Settings and select your resolation.
Dec 17, 2012 | Gateway 6510GZ Intel Pentium M 1.6GHz...
Everything on my desktop and internet so tiny i cant read.all icons and writting extremely small.
clik start then control panel then classic view then display and then select from drop down menu ...set it to 1024 x 768 resolution this should help
Aug 10, 2010 | E-Machines eMachines Desktop PC
Screen print is too small to read and I cant seem to resolve the issue myself
You seem to have a very high resolution setting. This leads to very small font size and difficulty in reading the text, especially on web pages. To change resolution: 1. Switch on the computer. 2. Wait till the boot process complete. 3. Click (right button on mouse) anywhere on the desktop except where there are no icons. 4. A small pop up box opens. 5. At the bottom there will be properties. 6. Click ( left button on mouse) on properteis. 7. You will see another pop up box, which will say display properties. 8. Click ( left button on mouse) on settings tab. 9. Some where in the middle of the page that opens you will see screen resolution. There will be a slider which moves moves beteen less and more. Chances are that your slider is ket towards the end of more. 10. Bring this slider towards the center . You can click in the center or click and drag. Then click Ok. You may see another box saying it needs your permission to change resolution or will go back to original resolution. Select whichever option that will change the resolution to new one. The screen may blink or at times the computer may reboot. You will see that the fonts has now become bigger. Repeat the process if necessary till you find a resolution that is comfortable for you.
Jul 28, 2010 | Computers & Internet
I downloaded win7 transformation pack and it has large iconsin desktop how to switch it to classic icons?
right click on dektop.then click on properties and click on appearences.then u will see there "screen resolation"the u will able to large and small your icons.
May 29, 2010 | Microsoft Windows XP Home Edition
Just set up monitor after we moved. The fonts on microsoft features are now small. Attempt to change font size (on control panel) are not successful. example of "features" = task bar words very small,...
anywhere on the desktop(not over an icon or folder) right click on the mouse and go to properties. A window called display properties will come up. On th tabs at the top click on settings.
There will be a slider bar called screen resolution, move the slider down and the windows icons and folders and fonts will get larger adjust this and keep clicking apply until it was the same size previously
Aug 22, 2009 | Acer Computers & Internet
Switch is stuck in on position braun 7505
You only need an small screwdriver, pull out the blue button and the metallic part, Ready!. Only one thing, you have to forgett about the aesthetics of the shaver, but it's work perfectly, Thanks a lot!
May 30, 2008 | Health & Beauty
ASUS F5VL-A2 Notebook Logo
15 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
