Question about HP Color LaserJet Professional CP5225n Laser Printer
My HP cp5225n is too slow - HP Color LaserJet Professional CP5225n Laser Printer
  • Gary Crosbie
    Gary Crosbie Dec 09, 2013
    Hi Bashar Gaznakhy, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Is it directly connected to your computer? Colour printers tend to be much slower than b & w. If you can select print all in black and white, that will speed it up too.
Out Bin Full
I share a informative link please visit and read it.... HP Support document HP Support Center and HP Printer Support
Thanks,
Jul 24, 2014 | HEWLETT PACKARD - LASER JETS CE711ABGJ...
Officejet 4500 desktop printing slow
This page provides some solutions for slow printing for that Officejet Printer.
Slow Printing HP Officejet 4500 Desktop All in One Printer G510a HP...
I am an HP employee.
Apr 09, 2014 | HEWLETT-PACKARD Office Equipment &...
CP5225N WRONG FUSER INSTALLED ERROR
Was the replacement fuser 'new' or 'refurbished'? Try re-installing the fuser, that will usually correct the problem. If not, contact your vendor & see if they will exchange it. Always try to replace parts with Factory New. I don't work for or represent any brand, but in always tell my customers: Buy new Factory parts.
Mar 20, 2014 | HEWLETT-PACKARD Color LaserJet CP5225...
How to replace dc controller board on hp cp5225n
Remove 5 screws from rear cover and remove it
Open the right door to expose 2 screws holding right cover, release tab and remove Right Cover
disconnect 22 cable connections and 6 flat cables from the DC Controller PCB
Disconnect 3 intermediary wire connections and release the cables from the cable guides on the top and right sides
remove 4 screws from the 4 corners of the DC Controller
Remove PCB
Oct 01, 2013 | HEWLETT-PACKARD Color LaserJet CP5225...
Slow in my hp laptop
There are a number of reasons that might be causing your HP laptop running slow, but generally two factors: outdated hardware or poor system maintenance. For hardware part: you can get more RAM, higher CPU etc. For system part: there might be a lot of junk files, caches, errors etc out there, about 80% slow HP issues are caused by this reason, in this case you can rely on http://www.speeduphp.com/fix-slow-hp.html to free detect and fix related issues.
Jun 06, 2012 | Origin Burnout Paradise The Ultimate Box...
Why hp g62 hang & very slow
Hi, there. There are a number of reasons that may causing your HP computer running slow, but generally two factors: outdated hardware or poor system maintenance. For hardware part: you can get more RAM, higher CPU etc. For system part: there might be a lot of junk files, caches, errors etc out there, about 80% slow HP issues are caused by this reason, in this case you can rely on http://www.speeduphp.com/fix-slow-hp.html to free diagnose and fix related issues. Hope it helps. regards!
Feb 16, 2012 | HP G62144DX Laptop
Why hp g62 hang & very slow & heat
There are a number of reasons that may causing your HP G6 computer running slow, but generally two factors: outdated hardware or poor system maintenance. For hardware part: you can get more RAM, higher CPU etc. For system part: there might be a lot of junk files, caches, errors etc out there, about 80% slow HP issues are caused by this reason, in this case you can rely on http://www.speeduphp.com/fix-slow-hp.html to free detect and fix related issues. Good luck!
Pavilion a1410n (ER890AA) PC Desktop: HP s1410n windows XP sp3 slowing down...also runn...
Uninstall SP3. In certain cases improper installation of sp3 has caused the system to slow down.
May 18, 2010 | HP Pavilion a1410n (ER890AA) PC Desktop
Very slow printing
printer hp laserjet 1020 its working when giving first page to print but after gives second page its take time
Apr 02, 2009 | HP Office Equipment & Supplies
HP Color LaserJet Professional CP5225n Laser Printer Logo
51 people viewed this question
Seeker5211
Seeker5211
