Question about Finance
How to start my own enterprise - Finance
Quickbooks error 3371
When you register or open QuickBooks, you see one of these error messages:
  • Could not initialize license properties. Error 3371: QuickBooks could not load the license data. This may be caused by missing or damaged files.
  • Could not initialize license properties. [Error 3371, Status Code -11118] QuickBooks could not load the license data. This may be caused by missing or damaged files.
  • Could not initialize license properties. [Error: 3371, Status Code -1] QuickBooks could not load the license data. This may be caused by missing or damaged files.
Important: This issue can occur if your product is hosted by Right Networks and you access QuickBooks with WebConnect and then select to open the file without saving. If you use QuickBooks Enterprise and your product is hosted by Right Networks, you must save the file and then import it.
How to fix it:
Before proceeding, ensure that your copy of Microsoft Windows is up to date.
If the latest Windows updates are not installed, the QuickBooks installation can fail or become damaged. To install the latest updates in Windows, click the Windows Start or Logo button, choose All Programs > Windows Update. Once started be sure to install any updates marked critical.
You may need to re-install your software. Have your license number and product number for your version of QuickBooks ready.
Try these steps in the order shown. If the first one fixes the problem, you do not need to do the other steps.
Re-create damaged EntitlementDataStore.ecml
  1. Close QuickBooks if it's open.
  2. Open the entitlement data folder for your operating system and version of QuickBooks.
    1. On your keyboard, press Windows + R to open the Run window.
    2. Enter (or copy and paste) the following information, and then press Enter
      • QuickBooks 2014 and Enterprise 14.0: C:\ProgramData\Intuit\Entitlement Client\v8
      • QuickBooks 2013 and Enterprise 13.0: C:\ProgramData\Intuit\Entitlement Client\v8
      • QuickBooks 2012 and Enterprise 12.0: C:\ProgramData\Intuit\Entitlement Client\v6.0
      • QuickBooks 2011 and Enterprise 11.0: C:\ProgramData\Intuit\Entitlement Client\v6.0
      • QuickBooks 2010 and Enterprise 10.0 : C:\ProgramData\Intuit\Entitlement Client\v6.0
      • QuickBooks 2009 and Enterprise 9.0: C:\ProgramData\Intuit\Entitlement Client\v5
      • QuickBooks 2008 and Enterprise 8.0: C:\ProgramData\Intuit\Entitlement Client\v5
      • QuickBooks 2007 and Enterprise 7.0: C:\ProgramData\Intuit\Entitlement Client\v3
  3. Right-click the EntitlementDataStore.ecml file and select Delete.
  4. Click Yes to confirm you want to delete the file.
  5. Open QuickBooks, open your company file, and follow the instructions to register the application.
Jan 30, 2014 | Computers & Internet
Tip
How to disable and re-enable hibernation on a computer that is running Windows
The Hiberfil.sys hidden system file is located in the root folder of the drive where the operating system is installed. The Windows Kernel Power Manager reserves this file when you install Microsoft Windows. The size of this file is approximately equal to the amount of random access memory (RAM) that is installed on the computer.
The computer uses the Hiberfil.sys file to store a copy of the system memory on the hard disk when the hybrid sleep setting is turned on. If this file is not present, the computer cannot hibernate.
Hibernation is made unavailable when you set the value of the Hibernate after setting to Never by using the Power Options item in Control Panel. To make hibernation unavailable, follow these steps:
Click Start, and then type cmd in the Start Search box.
In the search results list, right-click Command Prompt, and then click Run as Administrator.
When you are prompted by User Account Control, click Continue.
At the command prompt, type powercfg.exe /hibernate off, and then press ENTER.
Type exit, and then press ENTER.
To make hibernation available, follow these steps:
At the command prompt, type powercfg.exe /hibernate on, and then press ENTER.
Type exit, and then press ENTER to close the Command Prompt window.
APPLIES TO
Windows Vista Business
Windows Vista Enterprise
Windows Vista Home Basic
Windows Vista Home Premium
Windows Vista Starter
Windows Vista Ultimate
Windows Server 2008 Datacenter without Hyper-V
Windows Server 2008 Enterprise without Hyper-V
Windows Server 2008 for Itanium-Based Systems
Windows Server 2008 Standard without Hyper-V
Windows Web Server 2008
Windows Server 2008 R2 Datacenter
Windows Server 2008 R2 Enterprise
Windows Server 2008 R2 Standard
Windows 7 Enterprise
Windows 7 Enterprise N
Windows 7 Professional
Windows 7 Professional N
Windows 7 Ultimate
Windows 7 Ultimate N
http://support.microsoft.com/kb/920730
on Nov 19, 2013 | Microsoft Windows Vista Home Premium with...
How to start own enterprise
need cash down payment and george brown deegre in management
Nov 27, 2013 | PC America Cash Register Express...
What version of Linux runs on DL580 G4?
Minimum Supported Red Hat Updates •Red Hat Enterprise Linux 5 Update 1 •Red Hat Enterprise Linux 4 Update 5 6-Core/4-Core Intel Xeon Processor 7400 Series •Red Hat Enterprise Linux 5.22 •Red Hat Enterprise Linux 4.7 Minimum Supported Novell Service Packs•SUSE LINUX Enterprise Server 10 SP1•SUSE LINUX Enterprise Server 9 SP31 6-Core/4-Core Intel Xeon Processor 7400 Series •SUSE LINUX Enterprise Server 10 SP23 •SUSE LINUX Enterprise Server 9 SP44
Nov 28, 2012 | HP Compaq ProLiant DL580 G4 (430811001)...
My windows7 enterprise product has expired.want to purchase new product key.
You will have to go to Microsoft to purchase the key. The easiest way I have found to do that is start the computer, make sure you have a network connection, and select the "Activate Windows" option from the program menu or when asked by the Computer. If you can't do it that way you can call Microsoft and do it over teh phone in an Automated system.
May 19, 2011 | Computers & Internet
What can window does it take
I have loaded windows 2003 server on this but the following OS are supported:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3279705&lang=en&cc=us&prodTypeId=15351&prodSeriesId=316537&taskId=135
Microsoft Windows 2000
Microsoft Windows NT 4.0
Microsoft Windows Server 2003
Novell NetWare 5.1
Novell NetWare 6.0
Novell NetWare 6.5
OS/2
Red Hat Enterprise Linux 2.1 (x86)
Red Hat Enterprise Linux 3 (x86)
Red Hat Enterprise Linux 4 (x86)
Red Hat Enterprise Linux 5 Server (x86)
Red Hat Linux 7.2
Red Hat Linux 7.3
Red Hat Linux 8.0
SCO Open UNIX 8
SCO OpenServer 5
SCO OpenServer 6
SCO UnixWare 7
SUSE Linux Enterprise Server 7
SUSE Linux Enterprise Server 8
SUSE Linux Enterprise Server 9 (x86)
Dec 25, 2010 | HP Compaq ProLiant ML350 G3 Server
Enterprise suite removal Anyone know how to kill this without formatting?
Yes you can remove it without formatting just go on start, than run a command (appwiz.cpl) after running this command Add or remove programs windows is open
In this window you can remove it.
Thanks & Regard
Abhay Singh
Nov 20, 2009 | Microsoft Windows XP Professional
Redhat es5
This model was found not to be 64bit but 32bit.
May 18, 2008 | HP Compaq ProLiant DL380 G4 Server
Finance Logo
62 people viewed this question
Top Finance Experts
Debbie
Bill Boyd
Bruce Mommaerts
Bruce Mommaerts
Are you a Finance Expert? Answer questions, earn points and help others
