Electrolux air conditioner
The outdoor unit starts to operate even the indoor unit is still off
    Master:
  • 571 Answers
Replace the thermostat or always have the fan in the on position
Posted on Dec 07, 2013
Therinnaiguy
  • 1420 Answers
SOURCE: Air Conditioner unit won't switch on outdoors
can you give us some model numbers and a make? Get both the inside and outdoor unit numbers please. Thanks.
Posted on Oct 10, 2007
  • 86 Answers
SOURCE: Error CA for LG air conditioner model Q-12 AWR
1.sensar of remote control.
2.indoor unit sirkit board may be there is problem.change sirkit board by new one
3.if any requirement abt airconditioner pls mail me i can send u spare parts of air conditioner,.
mintex007@yahoo.com
Posted on Mar 16, 2008
SOURCE: DeLonghi Planus quick connect split heat pump.
I was told by a delonghi technician that it does this to defrost the unit.
Hope this helps.
Posted on Apr 22, 2009
  • 1169 Answers
SOURCE: Airforce 12000BTU Air Conditioner wiring problem
The outdoor unit should have 2 small wires connected to the contactor coil. This delivers the 24v "Signal" to energize the coil. The wire from the t'stat for cooling are usually yellow, in almost every case. When you put the t'stat in the cooling mode and set the temp lower than the room temp, the indoor and outdoor unit should come on. Check for voltage on the terminal block for 24 volts accross the yellow and common wire. Common could be ground on some handlers. If you have the 24 volts, then check for 24v on the 2 small wires (usually 18 to 22 gage wire) on the contactor coil. If no voltage, trace the 2 wires back to the indoor unit and see where they go. If they are the ones that are not attached, put one on the yellow wire terminal and the other on the common terminal. This will send power to the indoor unit and then piggyback to the outdoor unit. Do not remove the yellow and common from the terminal block. Don't be too concerned about the colors from the outdoor coil wires. Just make sure they are hooked up right. Good Luck and hope this gets it going.
Posted on Jun 07, 2009
SOURCE: Mr. Slim MXZ30TN Air Conditioner: Indoor unit blinks on and off what is the problem?...
continuous flash is frost prevention ...clean the filter & switch fan to high
flashes once every 2 sec could be room air sensor contact loose/short...call dealer
flashes 2x every 2 sec is indoor coil sensor contact loose/short...call dealer
flashes 3x / 2sec sensor contact problem, or compressor overload protection trip or gas leak...call dealer
Posted on Jun 02, 2010
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
I have a neo plasma lg 7kw will not heat LG Air conditioner
Make sure the setting on the remote is correct . Sun symbol for heating. Make sure the filters are clean. On heating, the indoor unit will 1/2 open the flap but the fan shouldn't start. The outdoor unit should start and if working properly, will be blowing cold air. The indoor unit will open the flap fully and the indoor fan will start once it gets hot then you should feel warm air. If the outdoor unit is blowing warmish air, I would say the reversing valve coil has failed or one of the indoor temp or pipe sensors are faulty. If a sensor fails, a "CH" error should appear on the display.
Mar 30, 2016 | LG Heating & Cooling
Is the heat pump cooling itself down? It is a combination heat pump/air conditioner wall unit.
If a unit is in heating mode the outdoor unit is in cooling mode (outside always does opposite of indoor) after a while if there is a build up of ice on outdoor coil unit stops and puts hot gas through outdoor coil to clear it. The indoor fan stops to avoid and heat loss in area served buy unit once this has been done and indoor unit coil is hot again fan will start. This is the correct operation of the unit to save against bust could and reduced efficiency
Dec 31, 2015 | Heating & Cooling
I have two flashes on the timer light of my indoor unit of Fujitsu Inverter ASU9RLS
Serial signal (reverse) error, at operation start up. operation led - off, timer led - 2 flashes, coil dry led - off, check wire between indoor and outdoor
Jul 10, 2015 | Fujitsu ASU9RLS2 Single Zone Wall Ductless...
After I replaced the pcb on my samsung air conditioner indoor unit it won't start and all 3 led's are blinking
I have had similar problems with Samsung. Apparently, the indoor board fits a lot of different models and each has to be "programmed" in to suit your model. Not sure what was wrong with your machine before but it has been known for these units to have a faulty outdoor fan motor which causes the outdoor board to fail as well. When this happens, the indoor unit will usually work fine for about a minute or 2 and then shut down, with lights flashing. The outdoor wont start at all. If these were the symptoms, I would suggest putting your old indoor PCB back and then getting a new outdoor fan motor and outdoor PCB.
Apr 19, 2015 | Samsung Heating & Cooling
LG SPLIT SYSTEM AIR CONDITIONER INDOOR UNIT WILL NOT POWER UP
as described the voltage you are seeing is fake. if there is no led lighting in the indoor unit check the small transformer in the indoor unit you should get 12V DC or 24V DC out from it
Feb 10, 2014 | LG Heating & Cooling
Indoor fan slow to rotate in heat mode and no heat/compressor
The indoor fan will not run at normal fan speed untill the indoor coil reaches 32oC. This is done so that a cold draught is not felt when outdoor unit is not running. Check to make sure the outdoor unit is operating. If the outdoor fan is running but there is no indoor fan after 5 mins then you must likely have a gas issue or a fault compressor circuit.
May 31, 2010 | Fujitsu 24R1 Air Conditioner
Outside unit has frozen
Check your air filter and evaporator at the indoor, and also the outdoor condenser coil if clean, be sure that the outdoor has no obstruction to both front and back of the unit. If dirty then clean both indoor and outdoor. If clean let the ice melt by turning of the unit and unplug the power cord or off the circuit breaker to reset the error if error is present. And on the unit again and observe if icing is present when unit is operating. If icing is present after 10 to 30 min of operation then the unit is under charge.And while unit is operating adjust your thermostat to higher temp. to check if thermostat is operating normally. If the outdoor will trip off after the adjusting the temp. then your thermostat control is ok if not then the thermostat control have a problem.
Jan 21, 2008 | Hitachi RAS-09UH Air Conditioner
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
