Question about Konica Minolta 1149-0291-01 Minolta Cs Pro Ep 2080 Ep 3000 Copier Drum
Light change c0400
Minolta dialta Di 470 gives code C0400
polygon motor abnormal please clean laser unit.
May 03, 2014 | Minolta Office Equipment & Supplies
2005 chevy uplander
there is no c0400 there is a c0040 left front wheel speed check the wiring at the speed sensor about 3 to 6 inches from the conector on the body harness for a brake in the wirring
Apr 01, 2014 | Chevrolet Uplander Cars & Trucks
C0400 dialta 470
REplace the exposure lamp and board, The exposure lamp is the Lamp on the big glass, raise the doc feeder press start to make a copy does the very bright light come on
Jan 07, 2014 | Konica Minolta Office Equipment & Supplies
Malfunction Code C0400
You might try Googling the copier name, model number and/or any error code message you receive.
Nov 11, 2013 | Konica Minolta Office Equipment & Supplies
Mesin fotocopy
The C0400 deals with the scanning lamp not turning ON. I would check the fuse for the scanning lamp and check the lamp to see if it is blown. You will most likely need to replace one or both of the parts. Good Luck
Oct 30, 2013 | Minolta EP4000/5000 CS/PRO Copier
Minolta ep4000 error code c0400
C0400 -Exposure lamp failure to turn ON
C0410 -Exposure lamp turning on at abnormal timing
Turn OFF the copier,remove the glass,Work a screwdriver trough the hole in the frame at the left front side of the copier and remove the screw that secures the scanner unit.Move the scanner to rhe right hand side of the copier.Remove 3 screws to free the scanner.(To remove the scanner turn it counterclockwise).Remove 1 screw and the wire guide,remove 1 screw and the ground wire.Unplug the exposure lamp terminal connector,unplug the thermal fuse connector.Remove the scanner from the copier.Verify the continuity of the exposure lamp and thermal fuser.If is defective change.
Jan 02, 2013 | Minolta EP4000/5000 CS/PRO Copier
What is a code C0400?
Open the front door to your left upper, remove the access cover and press the trouble reset button the code you have is for the very bright light that comes on under the big glass when each copy is made. if the code comes back replace the exposure lamp and board. try web site below for a start,
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Feb 04, 2012 | Minolta Office Equipment & Supplies
Problem c0400 for Minolta
Exposure lamp to reset open front door to your upper left remove the access cover press the trouble reset, if the code comes back replace the bright light under the big glass
Oct 31, 2010 | Minolta EP4000/5000 CS/PRO Copier
Code C0400 contact rep at certain phone #...# out of service.
c0400 is exhaust fan code. Open the front door to clear. Make also all covers are closed front and both sides.
Jul 02, 2009 | Minolta EP4000/5000 CS/PRO Copier
Clearing a service code ''C0400'' on a Minolta CS Pro 6001
C400 is exposure lamp fails to come on, on start up the main exposure lamp should come on and do a scan.
If the lamp is not detected by the sensor, then you get the code.
Restart the machine, watch for the exposure lamp. if it does not come on before the code occurs, then the lamp or thermal fuse is likely gone.
if the lamp comes on then the code, the AE sensor is likely gone.
Hope this is of some help.
Ed
May 11, 2009 | Konica Minolta Office Equipment & Supplies
Konica Minolta 1149-0291-01 Minolta Cs Pro Ep 2080 Ep 3000 Copier Drum Logo
14 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
