Question about Makita Saws
Sparking carbon brush hr5001c - Makita Saws
  • Makita Master
  • 885 Answers
Brushes can have very small, blue sparks coming off them and be OK. If it's bad enough that you can hear, smell or see excessive sparking it can be caused by: a) The brushes are worn down or the springs are collapsed and the brushes are not making good contact with the armature. b) The armature contact (commutator) is damaged or there is a short in the armature windings. Replace the brushes or armature as needed. I can't give part numbers as your problem is listed in cut-off saws and grinders but your model number is for a rotary hammer.
Posted on Apr 28, 2014
2 Suggested Answers
  • 885 Answers
SOURCE: new carbon replaced produces too much sparks making it hot
Either your new brushes don't meet up with the armature properly or the commutator is damaged. Brushes usually 'wear in' within the first couple minutes of running. If it's getting excessivly hot you most likely have bad armature contacts and need to at least resurface the commutator or replace the armature.
Posted on Dec 30, 2011
Rival slicer model #65301, sparks when I slice meat, need a new motor ?
possibly not as sparks can be from low brush length or the armature needs a clean up
all brushed motors spark when they run and normally it is a small blue spark the full length of the brush and contained under the brush
If it is a harsh arc like spark then the motor should be looked at by an appliance repair shop
Oct 05, 2015 | Kitchen Appliances - Others
Need brushes for a 111409-01 branch wizard
Remington Pole Saw Carbon Brushes
If you're Remington Pole Saw is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Remington carbon brushes on E-bay Search for:
Remington Pole Saw 8 AMP Carbon Brush
May 03, 2014 | Remington Electric Chain Saw
Trouble starting
If you're Remington Pole Saw is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Apr 19, 2014 | Remington Electric Chain Saw
Extremely weak motor model 108526-01 remington
Feb 12, 2014 | Remington Garden
Are brushes available for remington 106890-02
Nov 06, 2013 | Remington Electric Chain Saw
Flashing on carbon brush, even after replasing field coil, armature and carbon brush.
Check for a weak/collapsed spring on the sparking brush. Also check the brush holder for any interior debris which might impede proper brush movement. Do both brushes spark? There should be a fine line of spark at the brush contact to the commutator normally. Make sure the motor tuns easily, as a bad bearing can cause sparking due to overload conditions. Hope this helps!
Feb 09, 2011 | Garden
Where can I get brushes and at what cost?
Parts for Remington saws are few and far between. Brushes are a common failure point and those available have about been bought up. You best chance is to check with a well-stocked hardware store or an electric tool repair shop for a similar brush from a different tool. You may have to modify something similar to fit. Good luck!
Dec 11, 2010 | Remington 111409 - 01 6" Branch Wizard...
The switch of the saw is not working 00
You need an AC voltmeter to trace the problem with the switch. It can also be a bad motor brush/spring--these saws are great for killing motor brushes, and there are virtually no replacements available as Remington has ceased saw operations. If it is a bad brush, visit an electrical tool shop to see if they have something that will work from a different brand of tool. Good luck!
Jun 28, 2010 | Remington 16" Electric Chain Saw
I have a Dewalt DW 566 type 3 sds+ drill that runs slow and sparks arround the comutator. Ps I have already fitted new brushes
Take the carbon brushes off one at a time. Clean the
commutator by Grit 800 sandpaper to clear it from carbon deposits. You can manually rotate the drill to have it clear from carbon deposits. Thereafter clean it
further by cotton cloth. Sparks will now be minimized
until the brush is fully seated on the commutator.
Nov 22, 2009 | Washing Machines
Saws Logo
93 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
