My Samsung remote only turns tv on/off but nothing else. When I press any other button it registers on the remote and tv but doesn't act on it??
  • Harley Sarah Quinn
    Harley Sarah Quinn Aug 17, 2017
    The new termites on Samsung advises you to take out batteries hold a button for 20 seconds replace batteries if utt works there was a glitch, however this didn't work, so i am a button presser, what i found was the remote disconnects from the tv, have had it three weeks and has done a few times, so to reconnect remote to tv, which is way simpler you hold the return button and play button together for 10 seconds until on your tv screen it says connecting tv to remote....
    Have the Samsung ue49mu6100 where there is no setup button or way to program you can't find anything that says the remote that can't be programmed disconnects from tv but it does, and why Samsung had nothing for three benefit of ut customers on this tells me they dont know, it's either to them the remote or the tv receiver.
    So hold return button and play button to reconnect the two devices, simple, free, and no hassle.
    Top Expert:
  • 12,223 Answers
Reset the code, if the problem persist, you need to open the keypads and clean for dirty, oxide, corrosion , clean with wd-40 or alcohol isopropyl. and try again.
God bless you
Posted on Nov 27, 2013
2 Suggested Answers
SOURCE: Samsung TV remote control
I HAVE THE SOLUTION TO THIS PROBLEM.
Confirmed with Samsung tech support. Problem is with remote. to fix, simple take the batteries out of the remote. Press and hold the UP Volume button for 2 Mintues (no cheating, it has to be at least 2 minutes), this Reset's the Remote Control. Put the batteries back in. Bob's your uncle. all fixed.
Posted on Jan 26, 2008
I have a Samsung Plasma TV (pn60f5300afxza) and when i try to open my TV there is nothing on the screen and the red light flashes. The screen doesn't open or nothing.
Samsung remotes sometimes have buttons up the top of their remotes to control other devices. I accidentally hit these sometimes and they change the controller to another (not connected). Ensure TV Button on top of controller is pressed before using remote to turn on tv.
Nov 07, 2016 | Samsung Cell Phones
We have a Model un40eh5300fxza tv, where on the remote is the OK button
    images for where on the remote is the OK button
    More images for where on the remote is the OK button
    RC: Tv code so i can use ok/select button on comcast remote
    www.remotecentral.com > ... > Consumer > Original Equipment Remotes
    Mar 3, 2010 - 13 posts - ‎7 authors
    I have the comcast dark grey remote and a vizio lcd tv .when i press the tv button i then can press the menu button it brings up my tv menu and ...
    Button Functions by Remote ' MyDISH ' DISH Customer ...
    https://www.mydish.com/support/.../remotes/button-functions-by-remote
    Register, Button, Button Sub-Category, Function, Condition ... on screen menu/pop-up, -. 2, Color Buttons, -, -, Function varies by screen and customer selection.
    Select/OK button doesn't work when Using Comcast remote with ...
    www.avsforum.com/...remote.../1533595-select-ok-button-doesn-t-work...
Jan 07, 2016 | Samsung Televison & Video
Ah59-02342a doesn't control tv anymore
Hi I had exactly the same problem with mine it worked the DVD player fine but not the TV even though previously it had worked both .......... Manual Guide In the manual guide I managed to dig out it says to do the following to set up the remote to work the TV
Press the TV button on the remote
Then whilst holding down the power button you need to enter in the samsung TV codes until your TV turns off (I only got to the first and it did it)
The numbers are 00, 15, 16, 17, 40, 43, 46, 47, 48, 49, 59, 60, 98
Hope this helps
Feb 24, 2012 | Samsung TV Remote Control
My Samsung 20" CRT model # TX-P2036 has power
May be you should press the channel button on the set itself or there is a problem with the eeprom of the set circuit.
Jun 15, 2011 | Samsung TXP2036 20" TV
Need IR code for Hisense 32" LCD tv to program
Are you referring to the iPhone/iPad app? if yes then this is not a remote app, it's a management app made for Comcast boxes and nothing else it doesn't controls tv's.
If you are referring to the actual remote for one of the Comcast boxes then it all depends on what model of remote you have and the exact model of your tv - some will support it thru the use of a Daewoo or Samsung code, others don't.
So you have 2 options:
1 - you try every Daewoo and Samsung code you have in the manual and if that fails you do a code scan on the remote as explained in the manual:
Turn on your TV
Press the TV button on the top of the remote, then press and hold Setup until the TV light blinks twice
Enter 9-9-1 and the TV button will blink twice
Press and release 1 and the TV button will blink twice
Point the remote at the TV, press and release the Power button, then press the CH+ button multiple times until the TV turns off
Press Setup once to lock in the code and the TV button will blink twice
If even that fails - the tv doesn't shuts down - then the remote is incompatible to the tv so
2 - you get a remote that is compatible with both. The only one i could find is
http://www.logitech.com/en-us/remotes/universal-remotes/devices/6812
Jun 04, 2011 | Hisense LHDN32V66AUS 32 in. LCD TV
My samsung remote for my blu ray player stopped working for my samsung TV today. i have never had this problem before. it still works on the blu ray player which then turns on the TV like it is supposed...
On blu ray remote control hold down TV Power+01 at the same time. If the TV turns off the controller is programmed. If not, try TV Power+02, +03, +04, +05, +06, +07, +08, +09. Different TV BRAND??? ...TRY http://remotes.com/remotes/documents/Samsung/AK59-00104K.pdf
Sep 16, 2010 | Samsung TV Remote Control
Bn59 00463 volume works nothing else cant turn on
Step 1: Remove the batteries
Step 2: Press the power button (red button) on the remote control 5 times.
Step 3: Replace the batteries and your remote should work fine.
Oct 20, 2009 | Samsung Televison & Video
Remot not working for Sens TV/DVD 19''
Hi sifrid,
Program the RCA remote with the instructions below, this will tell us if the problem is with the remote or the tv.
  1. Turn tv on.
  2. Press and hold tv button on remote
  3. While holding tv button press and hold power(on/off) button, led light shold go off then back on after a coupke of seconds.
  4. Release both buttons.
  5. Aim remote at tv and press the power(on/off) button every 5 seconds until tv turns off.
  6. When tv turns off press the stop button at bottom of remote, that will lock in the code.
  7. Turn tv back on with remote and test all buttons.
Let me know if this helps and please rate this solution.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 27, 2009 | Samsung Televison & Video
Remote control
There could be a cable that is not completely seated inside the set, there may be a software upgrade also that will fix it.
Oct 24, 2006 | Samsung LN-R328W 32 in. HD-Ready LCD...
Televison & Video Logo
3,565 people viewed this question
Top Televison & Video Experts
