What does usb ready mean ?
Does a usb ready tv record ?
Can you record from a smart tv with arecording box
First of all you need to check if your TV supports recording. Some 2010 models do and most 2011 have it implemented. Look for stickers or logos such as:
  • USB Recording
  • PVR (Personal Video Recorder)
  • DVR (Digital Video Recorder
  • The following manufacturers support it in some of their models. Typically mid-end to high-end models. Check the manufacturer web site if you are unsure.
  • Samsung
  • Sony
  • LG
  • Philips
  • Panasonic
  • Toshiba
  • Sharp (only Time Shift pausing)
  • Grundig
    What you need
    Many consumers have USB recording enabled TVs without actually using the function - simply because it requires an extra USB hard drive ou need the following:
    1. USB Recording: A HDTV that supports recording.
    2. A USB HDD: FlatpanelsHD uses a USB HDD from Transcend.
    3. Digital channels: Recording is only enabled on digital channels - not analog. You can record SD, HD and 3D.
    Some manufacturers recommend USB hard drives with external power supplies but we have used a Trandscend USB HDD that takes power from the USB plug on all manufacturers' TVs without any problems. Manufacturers typically allow 1:1 recording, meaning that you will see no loss in picture quality.
    How to set up USB Recording
    Once you have purchased a USB hard drive and connected it on the back of the TV you can move on to "pairing" the USB HDD with the TV. Here is how to set up USB recording.
  • Connect the USB HDD to a free USB port on the back of the TV.
  • The USB hard drive now needs to be formatted (all data will be deleted).
  • Most TVs help you to format the USB HDD automatically but on some models you need to enter the menu and select format HDD (or something similar)
  • Sep 29, 2016 | Televison & Video
    Trying to record on finlux smart TVs but it says no removable disk and initialisation failed . What do I need to do !
    Finlux USB Recording Functionality - YouTube
    ? 1:40
    https://www.youtube.com/watch?v=GKH-p6u0O8Y
    Mar 26, 2014 - Uploaded by MyFinlux
    Stay in control of your TV viewing thanks to our PVR functionality. You can pause live TV, or even record shows up to seven days in advance via USB. ... SEG 46" 46125 FullHD Smart TV Uydu Al?c?l? Kanal Ge?i?i ve Media Player ve ... Terms · Privacy · Policy & Safety · Send feedback · Try something new!
    Finlux 32H6020-D 32 Inch LED HD Ready TV - Full Video ...
    ? 13:54
    https://www.youtube.com/watch?v=pqfAs2kBKHM
    May 10, 2013 - Uploaded by TheSuperUberGOLDFISH
    Finlux 32H6020-D 32 Inch LED Widescreen HD Ready TV with Freeview & USB PVR Recording Black (New For ... Gadget Show Live 2013: Finlux 47inch LED Smart TV with 3D, £799 - Duration: 2:17. by ShinyShiny 12,627 views ... Terms · Privacy · Policy & Safety · Send feedback · Try something new!
    Finlux Smart TV System 2013 Review ' AVForums
    Jan 05, 2016 | Finlux Televison & Video
    Blaupunkt 40/148 tv. how do i record programmes to usb ?
    I could not find an owners manual for this TV but if it is like most TV's usb is for playing media, Not recording. I found a site that talks about your TV. The first reviewer explains the usb is for watching (not recording). I have a different TV and same holds true. IF you really want to record TV and have a computer with Windows 7 or Windows 8 you have capability to record to the computer and then move it to a usb to watch it elsewhere.
    Customer reviews for Blaupunkt BLAUPUNKT 40 148
    I hope this helps.
    Jan 29, 2015 | Televison & Video
    How do I record hd tv programs to a new USB?
    Try formatting in on FAT or FAT32.
    Oct 02, 2014 | Televison & Video
    My tv does not support san disk 16gb cruzar blade
    The device may be of "too low of quality"-- meaning..the device may be too "SLOW" to record the stuff you want to record...
    Lower (cheaper) storage, is often not as "FAST" to record, as higher quality device... sadly.. the simple solution..return the device, and try another.
    Nothing wrong with your TV....
    Oct 16, 2012 | SanDisk 16GB Cruzer Blade - USB Flash...
    VENTURER PLV91217S52 22" LCD TV Hi does
    Good day!
    Unfortunately that TV Doesn't play media from U.S.B device.
    This is the great features of that TV.
    • Free view built-in-- This TV includes a digital tuner which allows you to watch u p to 40 digital Free view TV channels with no monthly subscription or contract required.
    • Built-in DVD player--Your TV have a DVD player.
    • 720p H.D ready-----H.D Ready TV sets have a minimum horizontal resolution of 720 lines which means that they are capable of displaying high definition TV signals like play-station3
    • 1 High Bandwidth Digital Multimedia Interface - highest quality digital connection.
    Thank you very much.
    Apr 21, 2011 | Venturer PLV36220S1 22 in. LCD TV
    What type of usb HDD is required to record TV content?
    You are limited to size and speed, nothing else. So a 160Gb SATA drive at 7200RPM will do nicely. A USB2 caddy will be available for as little as $2.00 through ebay.
    Dec 24, 2010 | Panasonic TX-P42S10 42 in. HDTV-Ready...
    Can i use the USB port on my sagum freeview reciever to download programmes to my PC?
    This appears to be a television tuner with accompanying recording software. You can watch TV and record what you watch. You cannot "download from the Internet" using this device, if that is what you mean.
    Jan 09, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
    High definition box
    if you mean the digital set-top box (freeview) then it connects to the tv via scart just to deliver a signal but the vcr uses ordinary aerial input to record it's programs.. you cannot get a 'HD box' to plug into a tv the tv is either HD ready or it is not
    Oct 29, 2008 | Sylvania 6313CC 13 in. TV/VCR Combo
    Sabrent TV-USB20 USB 2.0 TV Tuner/Video Capture Box with Remote Control
    Try check your your cable or try use 3rd party recorder software. If green screen was appear it means your recorder software didn't receive signal.
    Best regards
    May 25, 2008 | Sabrent TV Tuner / Video Capture Box USB...
    Televison & Video Logo
    430 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
