Question about Dell Dimension 4600 PC Desktop
Dell dimension2400 power light is orange and fan is on machine not working
    Problem Solver:
  • 58 Answers
Sometimes the computer just gets confused. try taking out the cmos battery with computer unpluged. also un plug the power supply from the mother board and cpu fan after this reconnect everything and see if it starts.also try booting with 1 memory stick at a time.
Posted on Feb 04, 2015
  • Dell Master
  • 998 Answers
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Posted on Apr 25, 2014
  • 326 Answers
SOURCE: Dell optiplex won't Boot-up.. Orange light on motherboard
its going to rather your power supply or your motherboard has died, id try a different power supply first
Posted on Aug 11, 2008
SOURCE: My Dell Optiplex 170L
If I recall correctly, we had this happen when we first got our 170L's. The problem was the actual on/off switch on the unit was defective. Ours were still under warranty so Dell replaced the units. If you have spare 170L's you can pop the faceplate and swap on/off switches to see if that corrects the issue and then order a switch from Dell.
Posted on Dec 16, 2008
  • 489 Answers
SOURCE: My Dell Precision 380's power light is orange
Check all of the electrical connections to all devices in the machine, especially the motherboard. Many times this is a result of a poor connection being jarred loose during a move.
Posted on Jul 07, 2009
  • 15 Answers
SOURCE: dell optiplex 270 startup
You need to have the Power Supply replaced on your Dell. Don't even think about repairing a power supply it caries dangerous voltages and you can get seriously injured. So just take the Dell to a Certified A + Technician Shop near where you live Local shops will often work with you if you do upgrades and repairs with them Good Luck! If you fel you can do this repair be sure to ground yourself so you dont short out your Motherboard components. and remove tyehb screws from the power supply and detach the power cables from the motherboard and hard drive and other drives optical drives CDRWs then replace and reconnect the new power supply dont buy the cheapest one getb a power supply rated higher than yoiur current one so that when you upgrade the system there is enough power there to run all the drives and devices. Good Luck Write me if you have questions I am a A+ Certified Technician with 14 years experience and I have a part time Computer Business. I had a Retail Computer Store and Repair business for over 8 years in St Petersburg ,Fl I do part-time repairs and upgrades now as well as new custom builds by request.
Posted on May 22, 2010
Current009
  • 135 Answers
SOURCE: Dell optiplex 330 flashing orange on the power botton
Try to clean the RAM and place it again in the motherboard.
Posted on May 31, 2010
Have a Dell Optiplex 740 desktop. Power button is lit solid orange. No diagnostic lights on. Fans still blowing. Replaced power supply unit still nothing. HELP!!!!!
before replacing main board,try replacing individual hardwares like ram,processor and if still not working,try resetting the bios by alternating the jumper on the labelled CLR CMOS
good luck
Mar 28, 2013 | Dell OptiPlex 740 PC Desktop
Dell insipirion 530s power light stays orange fan running wild
Hi deb lewis,
the orange power light is your warning that your power supply is going bad. I'd replace the power supply with the same size or larger (preferred)
Best of Luck
Mark
May 11, 2012 | Dell (E210882) Motherboard
Dell inspiron 1150 wont power up the power light flashes green and batery light flashes orange but the fans or any thing else wont work
You may have a burnt board or the input pin is bad, try wiggling the pin while it is plugged in to see if you can at least get the fans to start you obviously have a short of power in the power button area. You may want to try replacing the power button board for your model this may offer you a solution. If you take it in they can test it with a meter to make sure that this is the problem before a board issue is determined. It is difficult to diagnose this kind of things without the machine in front of me. My advice is to take it in and have the power investigated.
Just because the lighting on the battery is going and showing signs of life does not mean the power button is not bad or not getting the proper power to start the computer. It seems to me that the power button board is bad. Or the input cord pin may be shorted out and only supplying power to the mains but not the power button circuitry. Just a good guess!......John
May 11, 2012 | Dell Inspiron 1150 Notebook
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
The power LED light is orange instead of green and it won't turn on
Hi! for most dell machines if the power led is orange its an indication of a issue with the ram, try to reseat the ram first.if that doesnt work normally for dimension 4600, there are diagnostic lights that are located at the back panel of the machine, they are four bicolor lights(amber and green) You can determine the exact problem by checking these lights and you can interpret them by going to this website: http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/adtshoot.htm#1112886 hope this helps...
Jun 12, 2010 | Dell Dimension 4600 PC Desktop
May 31, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
The power light on my dell dimension 2400 is orange (it is not blinking). The loading light next to it is green. the computer is on but it will not do anything.It wont show the dell logo or anything. What...
You May hev one of two problems, either you towers power suply is broken, or on of the system fans are not working.
Check the power supply fan on boot. If its working check the CPU fan
Regards
Feb 21, 2010 | Dell Dimension 2400 PC Desktop
My Dell Precision 380's power light is orange and the computer won't boot up after we moved it. We replaced the power supply (the fan blows), but is still orange. What is wrong with the Dell? The manual...
Jul 07, 2009 | Dell Computers & Internet
Aug 04, 2008 | Dell OptiPlex GX520 PC Desktop
Gx260 pc wont start
Have you checked the post lights located in the back of the system by where the keyboard plugs in? There are is a row of 4 lights; either yellow or green. If the systems gets stuck at a particular post location, the lights will tell where. Good luck
Aug 16, 2007 | Dell OptiPlex GX260 PC Desktop
Dell Dimension 4600 PC Desktop Logo
91 people viewed this question
Alun Cox
