Recording HD channels
I have the following equipment: 1. Philips 42PFL7403D Flat Panel TV 2. A HD Motorola Cable Box DCH3200 (from Cox) 3. Panasonic DVD Recorder DMR-EZ475V I would like to record the HD channels (700 series from Cox) which I can get with 1 and 2 but I can only record up to channel 135. What connections do I vae to use with what cables? All have HDMI and coaxial ports.
  • 67 Answers
Well you would need to hook up cable box to dvd recorder. the only draw back first off is one you cannot get hd onto a dvd. you can down scale and it will seem a little cleaner than standard def but of coarse it will never be high def. I'm not to familiar with the motorola boxes but if they offer dvr's in your area i would suggestgetting one you can record all channels then afterwards transfer them to a outside device. but as i said before high def cannot fit onto a dvd unless you plan to copy one movie to 6-7 disc. Just keep in mind a standard high def channelcan only fit 2 max on one freq due to the amount of data transfer as opposed to 10 to 12 standard def digital channels
Posted on May 08, 2009
Where is the serial number on Motorola dch3200?
MAC I D but I would use chat and they should help.
Mark
Motorola support
Jun 15, 2014 | Arris SURFboard SBG900 802.11g/b...
TV only detecting channels 2-13 should be detecting 2-63
Go back to the initial set up procedure for your Sharp TV and do a search for active HD channels. They will be decimal numbers such as 13.1.
Jan 13, 2014 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Missing user guide for DCH3200 hi def receiver
IF this is the Motorola DCH3200 HD Set-top you can get a download manual from;
http://www.generalmanual.com/TV-Tuners/Motorola-DCH3200-HD-Set-top.htm
If not you will have to supply more information.
Feb 14, 2011 | Televison & Video
When i go to hook up a hdmi cable to my philips flat screen it wont recognize that i have a hdmi plugged into it. so what could that be the tv? the hdmi works with my other tv though
This model has 4 HDMI inputs, do you get same problem in each HDMI input?
Did you checked HDMI input with any other video source like dvd player or PS3 etc instead of cable box?
Below are few helpful tips to connect HDMI input..
1. Ensure that your HDMI cable is certified.
2. Press SOURCE on the remote control to switch to another source and then switch back to the HDMI source.
3. Reset the accessory device and the TV.
• Turn on the TV
• Select the HDMI channel
• Turn on the accessory device
4. While the TV and the accessory device are powered on, unplug either end of the HDMI cable and then reinsert the cable.
Try above options and if tv still does not show picture of any video source through HDMI then it seems problem of HDMI processor located on main board, visual check is needed by qualified tech or call Philips if tv is under warranty.
Hope these info will help you.
Thanks.
Nov 26, 2010 | Philips 42PFL7403D/27 42 in. LCD TV
I am trying to hook up my panasonic tc-32lx700 tv to a motorola dch3200 cable box and i am totally confused! Help!!!!!!
I can help you but this may take a while with this method.
What do you have connected where at this point.
Give me from and to information:
ie: from the audio out on the cable box to video 1 audio in in the TV.
Apr 15, 2009 | Televison & Video
Is tv an HD tv
Yes, mostly all new displays are at least 720p which display a great picture ! However, coax cable is the worst possible cable you can use. Your best bet for HD from the cable box is to use component cable. These are the 3 RCA type colored cables, red, green and blue. You will also need another two RCA cables for the audio, which is usually red/black or red/white. If you have a surround sound receiver, then you will not need the 2 for audio to the TV. These 2 would goto the receiver or you can use a better digital coax or optical cable for audio.
Also, HDMI from the cable box to display is a more expensive cable which will give you HD but doesn't always look better then component on some HD cable boxes.
Mar 11, 2009 | Philips Televison & Video
Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Dec 29, 2008 | Philips 42PFL7403D/27 42 in. LCD TV
Cannot set screen width
Both the TV and the Cable box have Aspect(height/width) settings. You must confirme the setting on the cable box and then do the TV.
1. Set TV to Native, this should show image exactly as the cable box sends it.
2. change Aspect settings on the cable box until you get one that works
3. if you get a good one, then your OK. You will just need to find a setting between the 2 devices that work for you. Also, these settings may change automatically for the TV or cable box based on the channel
Dec 25, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Motorola DCH3200 Cable Box
Be sure that you took the time to force the output of the DCH3200 to 1080i. They do not seem to come set that way by default! This is true whether you are using either the component or HDMI output.
Power OFF the unit and immediately push the Menu key on the front panel. Using the remote, be sure that the 2nd line of the config is set to 1080i and not something less.
Mar 27, 2008 | Sony KP-57WS500 57" Rear Projection...
Panasonic PT-52LCX66...Connecting to HD
the TV is "automatically" HD. You probably have to turn to the HD channels (which sometimes require a subscription through the cable company. For example in my cable company there are 2 Fox stations, channel 10 with is NOT HD and then channel 810 whish IS HD
Jan 28, 2007 | Panasonic TH-50PHW6B 50 in. Plasma...
Televison & Video Logo
177 people viewed this question
Top Televison & Video Experts
