Question about Refrigerators
Ingels refregator works on 240 volt but not on 12 volt
    New Friend:
    Problem Solver:
  • 3 Answers
THANK YOU. THE MACHINE IS WORK ' BUT NOT DRY NO HIGHT
Posted on Nov 27, 2013
4 Suggested Answers
22yooper
  • 828 Answers
SOURCE: Dometic Caravan Fridge 7271
Your refrigerant may have completely separated in the system. Shut of the gas, disconnect the electrical and remove refrigerator from the coach or if you have sufficient room inside set it on a clean area. This operation is what is called burping the system.
1. From the base roll it onto the door and wait five minutes.
2. roll it onto the top and wait five minutes.
3. Roll it on the back and wait five minutes.
4. Return it to the base and wait five minutes.
Reinstall it or test it on electrical. It should show signs of cooling in about 30 minutes in the freezer compartment if the system is not plugged in the boiler.
Posted on May 26, 2008
  • 159 Answers
SOURCE: It works on 240volts and gas but not on 12 volts. Why and how do I gain access to the parts that I must test?
in the rear it have a round element you will see there are four wires going in the 12v side must be tested if there are any circuit if not it need to be replaced
Posted on May 20, 2009
  • 415 Answers
SOURCE: how to change 240 volt fridge to 12 volt
you can not if this is truly a 240v unit the items install on the unit are more than likely requiring 240v to operate properly
Posted on Sep 06, 2009
Where is the heating element for the 12 V side on Rm 2510 3 way Electrolux
two black wires from lower control board to chimney the one marked 12 volt on board
Mar 29, 2018 | Electrolux Refrigerators
Works on 12v, but wont work on 240 v?
Does not make any sense that it works on 12 volts, but not on 240 volts......why would you try it on only 12 volts? How do you hookup just 12 volts? with the use of a rheostat? Are you trying direct current or alternating current?
Aug 11, 2014 | Engel MT45F 43 Quart Portable Refrigerator...
Spa has no power on 240 volt side 12 volt side works error code e1 on control panel
careful if you have 12 volts you have source voltage need more info
Mar 01, 2014 | Jacuzzi Pool & Spa
Three year old Dometic RM 2555, 3 way Frig/freezer has failed on 240VAC however works on Gas. I suspect the PCB is faulty
My rm2555 has just failed on 240 volt. But not 12 volt.
It turned out to be the 240 volt element .
Fairly easy to replace. If you have a multimeter test the resistance, mine was open circuit.
Does yours work on 12volt?
The two heater elements (ie 12v and 240v ) are on the right when viewed from behind with four large wires coming out, plus an earth wire. There are labels on some of the wires. The 12 volt conects into a terminal connector, where as the 240 volt is fitted with spade connectors and is attached to the printed circuit board, under the white plastic cover. The elements are "L" shaped and are just pushed down in down next to each other. The cover seems to unclip fairly easily to enable removal.
Hope this helps.
Mark
Dec 26, 2010 | Dometic Refrigerators
I have a 1997 caravan in Australia, in the caravan is an Electrolux three way refrigerator, it operates OK on 240 volts, I expect OK on gas, but it isnt working on 12 volts, I checked the power supply at...
chances are the power inverter has gone,(it takes 12 volts upto 240)
easy to check,use a lightbulb and the two wires to check power output.BE CAREFULL NOT TO TOUCH THE WIRES.
Sep 10, 2010 | Electrolux Refrigerators
Can I use a 5 amp 240v AC domestic fuse to replace 5 amp 12v fuse
A fuse is rated for it's current carrying capacity so yes you can use a 240 volt 5 Amp fuse in a 12 Volt circuit.
The Voltage is given to indicate the insulation of the fuse, i.e. if you used a 12 volt fuse in a 240 Volt circuit it may arc and therefore is not suitable. You can always use a fuse with a higher voltage rating in a lower voltage rated circuit.
A 5 Amp fuse will carry 5 Amps indefinately and will only blow at 2 or three times it's rated current.
Oct 26, 2009 | Max American Terminal 30 i Fuses
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
