Question about Cell Phones
Samsung GT-5222 shows Auto Charging and Pc Connection after connection for charging, and after removing charger also, battery and USB indicator still shows
jaffi
  • 8 Answers
SOURCE: NOKIA 6630 displays not charging when connect charger
hi dude,
>>> dont remove any thing from u r mobile, first confirm the problem where it is...
>>> first try to put the charge by using other charger... still u r getting same problem means change the charging unit
>>>good luck... thank u....
>>> dont forget to rating the solutions...
Posted on Feb 16, 2008
  • 3 Answers
SOURCE: warning bad connection charger
charger is broken...get a new charger or charge it on pc via usb cable provided....hope it helps you guys....
Posted on Dec 21, 2008
SOURCE: Samsung j700 died overnight screen wont turn on, but will charge
change the flexi cable bro
Posted on May 14, 2010
  • 27 Answers
SOURCE: 1) My samsung champ GT-
Possibly your handset is wet...try to disassemble it and here's the manual you needed. Manual
Posted on May 31, 2011
SOURCE: hi sir, i am using
Hi I am sorry to tell you but you have a faulty charger in the phone, try a factory reset, if this doesn't work, then return it to the seller under warranty.. as it needs to be internally repaired :(
Posted on Jun 03, 2011
Why my phone keeps restarting
Battery may not be charged enough to run the phone. Keep the phone off and connect it to a charger to fully charge the battery or use an external battery charger.
Be sure the The micro usb connector is fully seated and that the battery is actually charging. A loose connection may appear to start the charging process, but if its loose, it may not be continuing to charge. Check the % progress.
Aug 11, 2014 | Samsung Galaxy S 4 GT-i9500 Smartphone...
My samsung galaxy y 5360 become auto charge when i plug it to charger, after removing charger it become still charging continiously.......plz send me solution on 7411mohit@gmail.com
BRO I THINK the problem is with your software so go to recovery mode and just wipe data and cache and remove your battery and place it after a minute or u must factory reset it may any solution helps you
Jun 04, 2014 | Samsung Galaxy Y GT-S5360 Factory Unlocked...
My samsung gt-c3303 champ auto charing problem,tell me solution of this problem?
Hello Friends:::::::::
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 14, 2013 | Cell Phones
Samsung gt e3213k charging problem.
First Option:
Second Option:
Sep 07, 2012 | Samsung Cell Phones
Samsung R519-53S not charging
Please remove battery and connect charger and turn on computer. If on adapter working fine, now connect battery without removing charger , and check charging.
May 09, 2012 | Samsung R519-53S Notebook
Samsung C3010S is not charging. No indication or reaction when charger is plugged. Battery and charger is good, tested it on other units. What would be the possible problem of my unit and can it be...
If the battery and charger are tested and they good...the problem will be in the mobile charging
connector,it might be needs to repair or replace a new connection base.
But first clean the charging connection by a teeth brush with Alcohol,
Sink the brush in Alcohol and clean the connection as you clean your teeth and make sure
you remove the dark color stucks on the charging connector.
I think the mobile will charge after you do this.
Jun 18, 2011 | Samsung Cell Phones
Lg km335 charging problem how to service
First Option:
Second Option:
Oct 26, 2010 | LG Cell Phones
Hitachi DMP850N When Connected to PC charging battery shows progresive charging When I use USB charger (Output 5v 400mV Max) the battery charge indicator doesn't change
the usb chargers 's transformoer might be having fault ...u have to replace the usb charger as a whole bcoz only transformer is not available ...
Oct 17, 2009 | Audio Players & Recorders
Charging Battery
did u try to charge it connected to your pc? maybe its the charger
Feb 04, 2008 | Motorola Mobility Moto Q
Samsung battery
Green:Fully charged
Amber:Improper connection
Red:Charging
Sep 04, 2007 | Samsung SCH-i730 Pocket PC
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
