Question about Jeep 1999 Grand Cherokee Laredo
Transmittion problem no shifting gear
I changed shift solenoid .and ecu and have no dtc code . but yet no shifting gear ????
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 42 Answers
Check for leaks of red fluid, if not that, check to see if your transmission fluid filter is clogged...yes it has one, if its not any of those, your gears may be worn out and a rebuild is in order
Posted on Nov 27, 2013
2005 chevy malibu damage Light front end damcodend error codes P0401 P0605 P0842 P0642 The 0401 code is being thrown twice and I belive it is the egr wich is common on these cars from what my buddy tells...
DTC P0401 Exhaust Gas Recirculation (EGR) Flow Insufficient
Probably plugged passage's , not the EGR valve .
What type code reader are you using to read these codes ? I have factory service info. Doesn't show P0842 or P0642 , no such codes . You don't show what engine yours has , I'am assuming you have 3.5 L !
P0604
Control Module Random Access Memory (RAM)
PCM
DTC P0601, P0602, P0603, P0604, P0605, P0606, P0607, P1600, P1621, P1627, P1680, P1681, P1683, or P2610 in Engine Controls - 2.2L (L61)
or
DTC P0601, P0602, P0603, P0604, P0605, P0606, P0607, P1600, P1621, P1627, P1680, P1681, P1683, or P2610 in Engine Controls - 3.5L (LX9)
P0717
Input Speed Sensor Circuit Low Voltage
PCM
DTC P0717 in Automatic Transaxle - 4T40-E/4T45-E
P0741
Torque Converter Clutch (TCC) System - Stuck Off
PCM
DTC P0741 in Automatic Transaxle - 4T40-E/4T45-E
P0742
Torque Converter Clutch (TCC) System - Stuck On
PCM
DTC P0742 in Automatic Transmission - 4T40-E/4T45-E
P0748
Pressure Control (PC) Solenoid Control Circuit
PCM
DTC P0748 in Automatic Transmission - 4T40-E/4T45-E
P0751
1-2 Shift Solenoid (SS) Valve Performance - No First or Fourth Gear
PCM
DTC P0751 in Automatic Transmission - 4T40-E/4T45-E
P0752
1-2 Shift Solenoid (SS) Valve Performance - No Second or Third Gear
PCM
DTC P0752 in Automatic Transmission - 4T40-E/4T45-E
P0753
1-2 Shift Solenoid (SS) Control Circuit
PCM
DTC P0753 in Automatic Transmission - 4T40-E/4T45-E
P0756
2-3 Shift Solenoid (SS) Valve Performance - No First or Second Gear
PCM
DTC P0756 in Automatic Transmission - 4T40-E/4T45-E
P0757
2-3 Shift Solenoid (SS) Valve Performance - No Third or Fourth Gear
PCM
DTC P0757 in Automatic Transmission - 4T40-E/4T45-E
P0758
2-3 Shift Solenoid (SS) Control Circuit
PCM
DTC P0758 in Automatic Transmission - 4T40-E/4T45-E
P0815
Upshift Switch Circuit
PCM
DTC P0815 in Automatic Transmission - 4T40-E/4T45-E
P0816
Downshift Switch Circuit
PCM
DTC P0816 in Automatic Transmission - 4T40-E/4T45-E
P0826
Up and Down Shift Switch Circuit
PCM
DTC P0826 in Automatic Transmission - 4T40-E/4T45-E
P0973
1-2 Shift Solenoid (SS) Control Circuit Low Voltage
PCM
DTC P0973 in Automatic Transmission - 4T40-E/4T45-E
P0974
1-2 Shift Solenoid (SS) Control Circuit High Voltage
PCM
DTC P0974 in Automatic Transmission - 4T40-E/4T45-E
P0976
2-3 Shift Solenoid (SS) Control Circuit Low Voltage
PCM
DTC P0976 in Automatic Transmission - 4T40-E/4T45-E
P0977
2-3 Shift Solenoid (SS) Control Circuit High Voltage
PCM
DTC P0977 in Automatic Transmission - 4T40-E/4T45-E
Sometimes with code readers they get confused an just throw any old codes . Have it checked by someone with GM Tech 2 scan tool .
Aug 03, 2017 | Chevrolet Malibu Cars & Trucks
1998 pontiac sunfire auto shift control solonoide lacated
What are you talking about auto shift control solenoid ? Which transmission does yours have ?
Automatic Transaxle - 3T40 Automatic Transaxle - 4T40-E
1-2 Shift Solenoid Valve
In transmission valve body
Transmission Component Location
Automatic Transmission Internal Connector End Views
2-3 Shift Solenoid Valve
Is there a DTC - diagnostic trouble code stored ? Which gear or gears are not working ?
Jul 07, 2016 | Pontiac Cars & Trucks
P0753, p0758 and p91860 what's my problem and how do I fix it?
Your best bet would be to take your vehicle to a ASE certified professional . You do not have the tools to diagnose this or the information.
DTC P0753
The 1-2 shift solenoid (1-2 SS) valve controls transmission fluid pressure acting on the 1-2 shift valves to position the valves for the appropriate gear. The 1-2 SS valve is a normally-open exhaust valve located on the control valve body. A fused circuit supplies ignition voltage to the 1-2 SS valve. The PCM commands the solenoid ON or OFF by switching the ground path. When the 1-2 SS valve is commanded ON, the PCM senses low voltage. When the 1-2 SS valve is commanded OFF, the PCM senses high voltage. Refer to Shift Solenoid Valve State and Gear Ratio .
If the PCM detects a continuous open, short to ground or short to power in the 1-2 SS valve circuit, then DTC P0753 sets. DTC P0753 is a type B DTC.
DTC P0753 sets when one of the following conditions occurs for 5 seconds:
Condition 1 The PCM commands the solenoid ON and voltage feedback remains high, B+.
Condition 2 The PCM commands the solenoid OFF, and the voltage feedback remains low, 0 volts.
DTC P0758
The 2-3 shift solenoid (2-3 SS) valve controls transmission fluid pressure acting on the 1-2 and 2-3 shift valves to position the valves for the appropriate gear. The 2-3 SS valve is a normally-open exhaust valve located on the control valve body. A fused circuit supplies ignition voltage to the 2-3 SS valve. The PCM commands the solenoid ON or OFF by switching the ground path. When the 2-3 SS valve is commanded ON, the PCM senses low voltage. When the 2-3 SS valve is commanded OFF, the PCM senses high voltage. Refer to Shift Solenoid Valve State and Gear Ratio .
If the PCM detects a continuous open, short to ground or short to power in the 2-3 SS valve circuit, then DTC P0758 sets. DTC P0758 is a type A DTC.
Conditions for Setting the DTC
DTC P0758 sets when one of the following conditions occurs for 5 seconds:
Condition 1 The PCM commands the solenoid ON and the voltage feedback remains high, B+.
Condition 2 The PCM commands the solenoid OFF and the voltage feedback remains low, 0 volts.
What's this p91860 , no such code .
Apr 02, 2016 | 2003 Pontiac Aztek
Can A DTC P0750 Generate A DTC P0706?
Yes! One is related to the other. The first is low/reverse solenoid malfunction and the second is an indication of range failure.
Aug 29, 2014 | Cars & Trucks
2-3 shift solenoid circuit
P0758 Chevrolet P0758 Chevrolet - 2-3 Shift Solenoid Circuit Electrical
Possible causes
- Low transmission fluid level
- Dirty transmission fluid
- Faulty 2-3 Shift Solenoid Valve
- 2-3 Shift Solenoid Valve harness or connectors
- 2-3 Shift Solenoid Valve circuit is open or shorted
What does this mean? When is the code detected?
When the Powertrain Control Module (PCM) detects a continuous open, short to ground or short to power in the 2-3 Shift Solenoid (SS) valve circuit, then DTC P0758 sets.
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Transmission will not shift gears
P0758 Chevrolet Description
The 2-3 Shift Solenoid (SS) valve controls the fluid flow acting on the 2-3 shift valves. The 2-3 SS valve is a normally-open exhaust valve that is used with the 1-2 SS valve in order to allow four different shifting combinations. The solenoid attaches to the control valve body within the transmission. The Powertrain Control Module (PCM) controls the solenoid by providing the ground path.
Read more: http://engine-codes.com/p0758_chevrolet.html#ixzz3kcwzXFmK
Jul 14, 2014 | 2000 Chevrolet Silverado 1500
I have a 1998 dodge Grand Caravan with codes P0700,P0734 & P0733. What does this mean?
P0700 is a informative transmission code, about some problem there; the P0733 and P0734 is the specific problem there.
I would first try changing the fluid and filter. Although the fluid may look like it is brand new, with 100K on the fluid, I can assure you that even if those miles were all highway at steady speed and no load that the fluid has deteriorated and no longer lubricating the internal parts properly and that there is some debris in the ******.If codes return and shifting problems are still present, there is definite internal failure, possibly the pump or in the clutches.
DTC P0733The powertrain control module (PCM) uses the crankshaft position (CKP) sensor, input speed sensor (ISS) and output speed sensor (OSS) to determine engine speed, input shaft speed and output shaft speed. These sensor readings are used to determine the current gear ratio and RPM slip across the torque converter. The PCM uses this information from the sensors to determine if the commanded gear matches the actual gear. During normal driving conditions, the PCM will adapt main line pressure via the pressure control (PC) solenoid to prevent slipping and harsh shifts. Shift solenoid 3 is used to apply or release third gear clutch. The PCM controls 3rd gear by controlling the ground for shift solenoid 3. The PCM will turn the solenoid OFF, open the driver circuit, when 3rd gear is commanded On to apply 3rd clutch. Shift solenoid 3 is supplied ignition voltage from the fuel pump relay whenever the PCM commands the fuel pump relay ON. DTC P0733 sets when 3rd clutch still slips after the PCM has commanded high main line pressure.DTC Parameters
DTC P0733 will set if the PCM detects an incorrect actual 3rd gear ratio when 3rd gear is commanded On when:- The condition exists for longer than 3 seconds (2001)*- The condition exists for longer than 3 seconds, 1 minute is allowed to elapse, then condition exists again for longer than 3 seconds (2000)- The high main line pressure has been commanded- The transaxle is in a forward gear- The input speed is greater than 224 RPM- The vehicle speed is greater than 5 km/h (3 mph)- The speed noise parameter = NO- The steady state ratio fail counter equals 255 for an in-gear failure, or the shift fail counter is greater than 100 on a downshift or upshift to 3rd gear (128=0 or normal operation)DTC P0733 diagnostic runs continuously once the above conditions have been met.
DTC P0733 is a type A DTC for 2000, type B for 2001.**Applicable to vehicles built after June 2000.
Diagnostic AidsImportant: If DTCs P0745, P0746, P0756, P0758, P0761, P0763, P0766, P0768 or P0789 is set, diagnose that DTC first. A diagnosed PC solenoid, shift solenoid 2, 3 or 4 low/high circuit fault DTC may have caused DTC P0733 to set.Important: If a shift solenoid performance DTC P0783, 4th gear stuck ON, is set, diagnose that DTC first. A 4th gear stuck ON may cause no 3rd gear, no 2nd gear, or TCC stuck Off.
Refer to Pressure Ports - Air Check and Parts Description for pressure apply points and for component/location description.
Possible causes of no 3rd gear are listed in the flowchart on the succeeding page.
Verify TRANSMISSION ISS and TRANSMISSION OSS read correctly on Scan tool.
Make sure the pressure control, shift 2, shift 3 and shift 4 solenoids are not intermittently sticking. A sticking shift solenoid 4 may cause 4th gear to be applied from an initial start resulting in no 3rd gear. Audible sound should be similar for all solenoids. A muffled tone indicates the need for replacement.
Check this pinout HERE
P0734 refer at ratio 4 gear, and the rocedure is the same.
Hope helps.
Jan 22, 2013 | 2003 Dodge Caravan
Codes p0700,p0733,p0734 dodge caravan 1997
Hope helps.
Apr 03, 2012 | 2003 Ford Focus
O/d light blinks when driveing o/d seems to be engaged car has 198000 miles and runs very good also engine light is on
O/D light blinks, but with that the check engine light is ON.--- This will make your troubleshooting easier.When the check engine light comes on, and remains on, this indicates that there is error stored in your cars computer.---- Once the computer is scanned, you will get error codes, as per that error code it will point towards faulty part, which is causing the O/D light to blink.-------- Most probably the O/D light blinks, If a problem exists in No. 1 or No. 2 solenoids or speed sensors .
--------------- For car after 1995 it requires OBD2 tool and for car before 1995 it requires OBD1 tool.------- --------- You car will require OBD1 tool.There are very few auto parts store and repair centers who have OBD1 tool.In your case you required OBD1 tool.------ You can just contact local auto-parts store and they will guide you to the nearest store who has OBD1 tool.There you can get your car scanned.If there is error set in your cars computer, then you will receive the error code.As per error code it will point towards the faulty part causing this problem in your car.------------- -------------- The codes which you get is scanning will be mostly any of this following codes:--- DTC P0500 - Vehicle Speed Sensor Malfunction
. DTC P0750 - Shift Solenoid "A" Malfunction
. DTC P0753 - Shift Solenoid "A" Electrical Malfunction
. DTC P0755 - Shift Solenoid "B" Malfunction
. DTC P0758 - Shift Solenoid "B" Electrical Malfunction
. DTC P0770 - Shift Solenoid "E" (SL) Malfunction
. DTC P0773 - Shift Solenoid "E" (SL) Electrical Malfunction
. DTC P1520 - Stop Light Switch Signal Malfunction
. DTC P1705 - Direct Clutch Speed Sensor Circuit Malfunction
. DTC P1765 - Shift Solenoid Valve SLN Circuit Malfunction
. DTC P1780 - Park/Neutral Position Switch Malfunction
--------------- Now it all depends on what code you get, as per that you can replace the following part.------- This will help.Thanks.Helpmech.
Jul 07, 2011 | 1995 Toyota Camry
My oldsmobile silhouette2000 does not shift gear when in drive
Hi.
Check the TPS (throttle position sensor). The TPS is located on the throttle body. Its signal is used by the transmission control module to decide when to activate the solenoids and switch gears.
The TPS can be tested by reading volts at its terminals while someone else is pushing down the accelerator pedal. If voltage has gaps (in your case this is likely the result), or if voltage does not change smoothly, then the TPS must be replaced.
Other part that can be responsible is the speed sensor, mounted on the transmission. This part is more difficult to test, and gets usually replaced if TPS and solenoids are OK.
The transmission gears are operated using an array of solenoids called solenoid pack. The solenoids are located inside transmission, in the valve body. A shorted solenoid can cause the transmission getting stuck in gear. An open solenoid will result in one gear not working. The solenoids are tested using an Ohm meter. If a solenoid is open then it must be replaced.
Wiring to solenoid pack must also be checked to be sure that the problem is not the wiring harness.
If all the rest is OK, then the TCM (transmission control module) or a defective transmission box can be responsible for the problem.
Transmission problems may store DTC (fault codes) in the ECU (Car main computer). If an obdII reading done on the ECU returns DTC P0700, that means that there are more codes addressing specific transmission codes stored in the TCM. A scan to retrieve TCM codes can be done at the dealer.
If first gear does never kick in, then I think the problem is likely a blown solenoid. The TPS can be tested first as it is an easy job.
Regards.
Ginko
Jun 13, 2011 | 2000 Oldsmobile Silhouette
4x4 not working on my 2002 chevy blazer ls 4.3l replaced the in dash switch and the tcm and the encoder motor what eles can be the issue when it went out it clicked when i switched into 4x4 then down the...
Is the switch lit up , light flashing ? Did you have the system checked for DTC'S - diagnostic trouble codes . Should have had this done before replacing parts . TCM ? your replaced the transmission control module ? Or the transfer case shift control module ? If no codes ,check B+ power and grounds for the control module . Find a wiring diagram so you know which wires are what etc.....Videos on youtube on basic automotive electrical testing , testing inputs an outputs for control modules . This system can set a number of codes !
DTC B2725
DTC C0300
DTC C0305
DTC C0308
DTC C0309
DTC C0310
DTC C0315
DTC C0323
DTC C0324
DTC C0327
DTC C0362
DTC C0367
DTC C0374
DTC C0376
DTC C0387
DTC C0550
DTC C0611
The front axle control circuit consists of a Front Drive Axle Clutch Solenoid which is electronically controlled by the transfer case shift control module. This solenoid opens and closes a vacuum control valve allowing vacuum to apply and release a clutch pack inside the front axle housing. The transfer case shift control module determines whether or not the clutch pack has been applied or released based on a signal from the front axle switch mounted on the front axle housing assembly. The front axle is normally locked or engaged during AUTO 4WD, 4WD HI, and 4WD LO modes. The front axle is unlocked or disengaged only during 2 HI or neutral modes.
The NVG 236/246 transfer case features a 4 button shift control switch located on the instrument panel. When the vehicle has the ignition key in the RUN position, the transfer case shift control module starts monitoring the transfer case shift control switch to determine if the driver desires a new mode/gear position. At a single press of the transfer case shift control switch, the lamp of the new desired position will begin flashing to inform the driver that the transfer case shift control module has received the request for a new mode/gear position. The lamp will continue to flash until all shifting criteria has been met and the new mode/gear position has been reached, or has been engaged. Once the new mode/gear position is fully active, the switch indicator lamp for the new position will remain ON constantly.
The NVG 233 transfer case features a 3 button shift control switch, located on the instrument panel. When the ignition is in the RUN position, the transfer case shift control module starts monitoring the transfer case shift control switch, to determine if a new mode/gear position has been selected. At a single press of the transfer case shift control switch, the lamp of the new position begins flashing to inform the driver that the transfer case shift control module has received the request for a new mode/gear position. The lamp continues to flash until all shifting criteria has been met and the new mode/gear position has been reached, or has engaged. Once the new mode/gear position is fully active, the switch indicator lamp for the new position remains ON constantly.
Which 4X4 system does your's have ? Three or four button ?
Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
How to Use Multimeter to Troubleshoot Common Problems
Electric Testing Techniques You Need to Know
Jul 04, 2017 | 2002 Chevrolet Blazer
Jeep 1999 Grand Cherokee Laredo Logo
51 people viewed this question
Top Jeep Audio Players & Recorders Experts
Thomas Perkins
Thomas Perkins
Tom Chichester
Duff Howell
Are you a Jeep Audio Player and Recorder Expert? Answer questions, earn points and help others
