Question about Rinnai Heating & Cooling
Is a new split system air con pre-gassed prior to installation
  • 86 Answers
SOURCE: Panasonic split system air con cs/cu-e24gkr
check the indoor unit sirkit board,there is problem.
Posted on Mar 15, 2008
  • 400 Answers
SOURCE: RECOMEDENT SIZE OF ROOM TO USE SPLIT UNITS FROM 12000BTU TO 24000
650btu/square meter
Posted on Mar 25, 2009
waelmet
  • 6 Answers
SOURCE: Split Air Conditioner Compressor Start Problem
you need to change it again.
rememper that I am not rich enghe to by the cheep
Posted on May 24, 2009
  • 81 Answers
SOURCE: TECO AIR CON SPLIT SYSTEM - THIS SYSTEM WAS
Whats the model number? I should be able to send you the manual, providied that I know the model number
Mat
Posted on Jul 16, 2009
koolbreezes
  • 540 Answers
SOURCE: Conia 3 HP, 5 yr old air con/ condensation from wall unit
NOW, THE EVAPORATOR COILS NEEDS CLEANNING OR THE DRAIN LINE PLUGGED,OR JUST CLEAN THE FILTER.
Posted on Dec 02, 2009
Where is the fuse box on a air conditioner?
in the main power board of the building
motor compressor split system has an on off switch
if a hole in the wall type air con unit
with plug in a wall socket
its a normal power fuse
Jul 23, 2016 | Heating & Cooling
Air con dead
Larger split system air con gets power from the external unit while smaller air con gets power from the internal unit. Can you find any power switch or power socket/plug around the external or internal units?
Nov 19, 2013 | Cell Phones
How can uninstal and shifting split air conditioner
This is not a DIY job. You need equipment to remove the A/C gas before dismantling the A/C system and after relocating and installing the A/C the system needs purging of air and then re-gassing.
I suggest you get an A/C installer to do this work.
Apr 05, 2013 | Heating & Cooling
Mitsubishi air con msza24yv. when we turn it on to the heating mode the operation light keeps blinking and nothing happens
Wait 5 mins after turning the unit on to make sure it is not on a pre heat, and if problem is still there check fault code on controller
Jul 04, 2011 | Mitsubishi MSZ-A24NA Split System Air...
IDEC aircon E5 error what does it mean?
i am air con tech and i face all ready this problem may be it will help u . e5 error is ur air con not have gas becoze of that the low presser switch give error on disply thanks best regard for all. pls let now if its help full
May 27, 2010 | LG LSC183VMA Split System Air Conditioner
Nov 30, 2009 | Heating & Cooling
Fujitsu reverse cycle split wont blow cold
same as car aircon, but uses different kinds of freon. check first the thermostat setting, may be it set too high. set it to 20'c. if still not cooling, check wiring on ACCU, check capacitor too.
Jan 18, 2008 | Fujitsu 18C1 Air Conditioner
Heating & Cooling Logo
14 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
