To remove dust
SOURCE: SHARP XV-Z91E Projector Replaced lamp but
hold down menu, enter, and down arrow, then press power. this is the only way to reset the lamp timer. if it won't turn on and there are no leds lit, you may have to reset the bimetal breaker. to do so, remove the 6 bottom screws and the top 2 screws on the back panel, and remove the top case. on the front side of the lamp housing, you will see a red button. press it. if it clicks, it is reset. if it doesn't, it wasn't tripped, and you have a power supply issue.
SOURCE: I have a sharp projector xv-z9000u. I replaced the
While holding down ENTER, \/, and >, Press POWER ON.
Page E-48 Operation manual, Step #8.
So you have to hold three buttons at once.
Your projector needs little maintenance. The only thing you
need to do on a regular basis is
to keep the lens clean.
Never remove any parts of the projector except the lamp.
Contact your dealer if other parts
need replacing.
Cleaning the lens
Clean the lens whenever you notice dirt or dust on the
surface.
• Use a canister of compressed air to remove dust.
• If there is dirt or smears, use lens-cleaning paper or
moisten a soft cloth with lens cleaner
and gently wipe the lens surface.
Never rub the lens with abrasive materials.
