Question about Myphone Computers & Internet
Myphone a848i white screen lcd
    New Friend:
  • 6 Answers
Greetings!if ur phone is still under the warranty better you should go to the service center.posiblility u will be free of charge,and LCD is still working,just dislocated.or needs some reallignment.if ur have a tools for opening your phone you can do it with your self.but if ur not sure better not though or else will be worse..its easy to open it just be carefull.and look the the lcd flex if dislocated..
Posted on Dec 09, 2013
How to unlockphone security password myphonemy11
If you forgot your myphone security password, the easiest thing to do would be to hard reset the phone to gain access again. There are several ways to hard reset a myphone. You can follow the steps at http://www.hardreset.info/devices/myphone/myphone-rio-fun/ to reset your phone.
myPhone Rio FUN How to Hard Reset my phone HardReset info
Jan 16, 2016 | Active Password Recovery Software Active@...
White screen
"White screen" on Samsung LED TV - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I guess I better send it to the repair shop and prepare myself for a long break ... Hello i have experienced the white screen tv as well, i got mine as part of a deal ... Samsung LCD Green Screen
Jun 11, 2015
Samsung DLP TV w/ White Dots on Screen
Jun 11, 2015
Samsung DLP white dots fix?
Apr 10, 2012
Samsung LCD TV now bright white screen
Aug 1, 2011
More results from www.cnet.com
EASY Common BLANK SCREEN FIX FOR LCD SERVICE ...
? 4:42
https://www.youtube.com/watch?v=SARGnOExL8c
May 11, 2013 - Uploaded by Tampatec
EASY Common LCD REPAIR Blank WHITE DISTORTED VIDEO... LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test ...
Samsung TV "white screen" repair - YouTube
Dec 16, 2015 | Televison & Video
How to unlock a myphone a818g
If you have forgotten the code then you will have to reset the phone back to factory settings.
Turn off you phone then press both the up and down volume at the same time, then power on your phone it will bring you to the boot loader screen. From there reset your phone, it will bring it back to factory settings.
Aug 23, 2014 | Myphone Computers & Internet
Myphone m88 reset sorunu
There are several ways to hard reset a myphone. Follow the steps at http://www.hardreset.info/devices/myphone/myphone-rio-fun/ to reset your myphone.
Jul 05, 2014 | Active Password Recovery Software...
How much is the lcd of myphone a848i duo .. my phone just shutdown and when i try to pen it theres no interface ..
How long have you had it? Maybe covered by warranty? Or take it to a specialist repairer
Feb 05, 2014 | Myphone System Security Wizard
A friends laptop is only showing a white screen
Step 1:
Fix a White Screen on an LCD Monitor
b>When an LCD screen has turned completely white, there are three normal causes: the screen is defective, the video cable is not connected correctly, or the graphics card on the motherboard of the computer is faulty. You will need to troubleshoot these possibilities to determine which problem you have. If you are not experienced in working on computer equipment, you should not attempt to disassemble your LCD screen because you could easily damage it. Seek professional assistance unless you have experience working on computer hardware.
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot. If your computer display does not show on the functioning LCD screen, try rebooting your computer. If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance. If your computer display shows normally on the working LCD screen, proceed to Step 2. Unplug the LCD monitor with the white screen. Disassemble the rear panel of the monitor with the small screwdriver. Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor. Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen. See the References section for photos of the video cable for assistance. http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/ Unplug the cable, checking for any debris or blockage. Reconnect the cable firmly. Reassemble the LCD screen. Plug it in and connect it to your computer. If the screen is still white, you have a defective LCD screen. You will need to replace it or take it to a professional repair service for assistance.
b> b> b> Without this test you'll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You'll have to disconnect the video cable from the LCD screen (connector 2) and the inverter board (connectors 3 and 1). After that you connect another working screen and test video. For this purpose I'm using one of my test LCD screens. My test screen is cracked and because of that you see a wide white band in the center but it still works fine for this test.
The original screen is white but my test screen works normal (except the crack of course) and I can see the image. After this test I can tell that the problem must be related to the screen. After I assembled everything back together and connected the original LCD, it's still white. CONCLUSION. In my case this problem is related to the LCD screen and it has to be replaced. b> b>
Feb 06, 2013 | Toshiba 16" Satellite A665S6095 Intel Core...
Myphone a919 duo user manual
Hi can somebody help me? Please i badly need some :(
I recently changed my screen lock PIN password, but when i've tried unlocking it again my phone didn't recognize my numeric combination. How could I atleast reset my phone without even getting into it? The phone model is Phillipine's MyPhone A919 Duo
Feb 03, 2013 | Cell Phones
How do i unlock my Philippine MyPhone QW28 Duo Wifi mobile phone
MyPhone QW28 Duo Default Phone Lock Code is 1122.
Feb 22, 2011 | Cell Phones
MyPhone T11 cant transfer via Bluetooth
ahhm madali lang poh.nong bumili poh ako ng myphone t11. ang ginawa ko lang poh. linagyan ko poh ng sd card, and ang "sd card "nya poh ay micro SD. malapit pof yon sa my lalagyan ng baterry. tingnan mo na lng po sa manual booklet nun. baka andun poh. thankz poh
Nov 05, 2008 | Lands Phones
My sidekick 3 screen is white
take the phones and have the LCD or flexcbale replaced
Jun 18, 2008 | T-Mobile SidekickĀ® 3 Cellular Phone
Computers & Internet Logo
Top Myphone Computers & Internet Experts
David Payne
David Payne
Are you a Myphone Computer and Internet Expert? Answer questions, earn points and help others
