Vaillant ga 100-8 will not light - jumpered out thermostat and replaced thermocouple
  • 7,627 Answers
Wrong category. You can find a manual here:
Posted on Nov 27, 2013
Light blinks on thermostat but pilot wont lite up
Sounds like the thermocouple is bad. The thermocouple is a sensor that is heated by the pilot light. The thermocouple let's the gas valve know that there is a flame to ignite the burner when you turn up the thermostat. When you first light your pilot light by holding down the pilot light button and the pilot light goes out after holding the button for about a minute then the thermocouple is usually bad. It is an inexpensive part normally found it any Box Store.
Jan 03, 2018 | Heating & Cooling
I replaced the thermocoupler and it still will not stay lit.
is the tip of thermocouple in the flame of the pilot.
where the thermocouple screws into the control valve you just tighten it hand tight and then 1/16 of a turn. or you might have damaged the magnet.
is the flame big enough on the pilot light as it might need the jet cleaned.
failing all that then the magnet in the controle valve where the thermocouple screws in has failed and needs replacing if your model will allow.
Sep 28, 2016 | Whirlpool 6th Sense 40-Gallon 6-Year Tall...
Vaillant Gas boiler/furnace not firing up
There is a thermocouple heat detecter in the pilot flame clean it 240 sand paper is ok. replace if not working.
Oct 22, 2014 | Water Heaters
Vaillant gas water heater - pilot light only, not lighting the main gas ring when tap is turned on..
first check to see if the thermocouple is close enough to the pilot. if it is and won't light the ring, replace the thermocouple.
Mar 01, 2014 | Water Heaters
Intertherm furnace M1BG wont fire
Make sure the gas valve is turned to the ON position after you had it in PILOT position. Also check the thermostat low voltage wiring @ furnace...jumper the Red & White wires to bypass the thermostat temporarily. Make sure there is 24 volts on you low voltage circuit.
Dec 16, 2013 | Intertherm P3RA-048K Air Conditioner
I have a Dayton 3E366B hanging my garage, and it starts up -lights the burners - the fan kicks on, and then it shuts off... This cycle goes on and it does not run for long times to really get the heat up....
No I do not believe it is your thermocouple, as that only detects heat from the pilot light and permits the gas valve to open and have main flame ignition. I would be looking at thermostat placement, and safety limits built in to the heater. Making sure that the thermostat is not getting a straight on blast of hot air from the heater is my first guess. Try jumping out the thermostat by first removing the thermostat from it's housing and placing a jumper between the red and white wires as they are usually the control for heat. If your heater stays running it is the thermostat. If not you now have to trouble shoot all safety limits one at a time with a volt ohm meter and run continuity tests the limits should read closed except for the fan high limit it should read open until the temperature of the heat exchanger reaches it's set temperature. Remember to power down your unit when trouble shooting please.
Jan 11, 2011 | Dayton Heating & Cooling
Pilot will not light
Unable to light pilot Gas supply turned off Turn on gas supply Gas **** knob dial not positioned correctly Check lighting instructions. Set control knob Defective thermocouple Check and replace thermocouple Defective safety magnet assembly Check and replace gas valve Pilot burner orifice clogged Clean or replace Pilot tube pinched or clogged Clean, repair or replace Poor thermocouple connection Check and tighten Air in gas line Purge air from gas line Thermostat's single use ECO is tripped Check ECO and replace gas valve Gas valve defective Check gas valve
Jun 06, 2010 | American Standard AMERICAN STD 100G NGAS...
Water heater keeps shutting off
Is your pilot light staying lit? If not, then replace the thermocouple. If it is, and you have the thermostat on it turned up, then the thermostat is bad and you will have to replace the whole gas valve. To do this, you will have to completely drain the heater and then remove the flame Assembly and screw out the valve. Replace the valve and reassemble the burner Assembly. That should take care of it. If the water heater is old, then I would replace the whole thing. A gas valve will cost you over a $100 anyway. Good luck.
Apr 05, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
