Question about GPS
Digitech dc 1005 - GPS
2 Suggested Answers
SOURCE: I am unable to sinc
I bought my kids a set last year and also couldn't synch. By accident we worked out that the green one needs to be on channel 31 and the orange one on channel 32.
Posted on Jan 05, 2011
I need a manual for a Digitech dc-1005 walkie talkie
Hi Mitchell,
I own a Digitech DC1065 80 Ch CB HH, and no problems, so far.
Have you tried the Digitech website?
If so with no luck, may I suggest you join yahoo group specific to your radio Make/Model, there are experts with great info, plus you can download manuals, diagrams and software, etc.,,
I hope this is of help to you. (Ibought my DC1065 on ebay, no manual, but found the unit easy to work out, but I've got a bit of knowledge with radio equipment).
Cheers,
Peter
Jan 20, 2013 | Radio Communications
My digitech dc-1005 will sinc ok ,but one will talk and recieve one way but not the other way, has anyone ant ideas on what could be wrong with them,im thinking the rx or tx on one of them may be ********.
There are 2 oscillator circuits in each unit- one for transmit and one for recieve. It is likely the recieving section of the one that does not recieve the other is slightly out of tune.
Jan 25, 2012 | Radio Communications
My digitech rp 500 has power supply but it won't
Make sure you have the OFFICIAL Digitech power adapter. Universal adapters or those for MOST other pedals will NOT work... things may light up but you will NOT get audio. This unit requires an adapter supplying 9 VAC (not DC) at about 1 amp. These AC output adapters are not very common and people get the units without an adapter and try using universal adapters and they do not work. An AC adapter is used by Digitech so they can generate both plus and minus voltages internally. I don't know what your utility power voltage is in Cebu, so you need to get an adapter for your voltage that will give 9 VAC output and fit the power jack on the unit.
Sep 15, 2011 | Digidesign Digitech Control 2 pedal for...
My digitech looper phrase sampler will not turn on
A common problem is that somebody has paired the WRONG power adapter to this unit.
The REQUIRED adapter should be 9VAC (not DC) at 1300ma or 1.3 amps.
Note that UNIVERSAL replacement adapters will NOT work with the Vocalist.
Feb 06, 2011 | Digi-Tech Digitech Vocalist Live 4...
Vocalist live 2 problem. power to unit OK , lights up. Guitar output OK. No tuner, no vocal output.
NO power light or audio from Digitech Vocalist 2 live. Check that your power adapter is for 9 Volts AC (not DC like most pedals) and is rated at 1300ma or more. A DC adapter MAY light up the unit but not make it pass audio. Lights can be lit but that is NOT an indication thaat correct power is applied. They likely use the AC input to generate both positive and negative voltage within the unit. The use of a DC adapter will prevent generating one of these required voltages and prevent audio from passing.
Jan 13, 2011 | DIGITECH VOCALIST LIVE 2
How do I change the channel on the Digitech DC-1005 walkie talkie? THanks
Looking everywhere online for an instruction manual for my little green and yellow walkie talkies ( Digitech dc-1003) without luck, so I had to work it out for myself.
The first button with the circle with line though it is the on/off button but it is also the channel select button. Hold it down for 2 secs to turn it on or off, OR press it once to be able to choose channels (the flashing number can be changed using the triangle up and triangle down buttons). Once you've chosen your channel, press the on/off button to select Hi or Lo frequency then press on/off button a third time to save. If you don't want the annoying static that sometimes comes, press the on/off button a fourth time for the squelch function (saves batteries and eliminates annoying hiss).
The next button is "S" which is the scan button. Hold it down to start scanning through all channels to try to pick up a transmission (we found a conversation between two fishermen today). When it finds a transmission, it will pause to let you see the channel number then continue. Hold down "S" button again to go back to original channel.
Next button "C" is the Call button. Pressing this button transmits a beeping alert to people on the same frequency/channel to let them know you are about to transmit a message.
The trangle up and triangle down buttons control the volume or select channels (as mentioned above).
Hope this helps. :)
Dec 27, 2010 | Audio Players & Recorders
NO power light from Digitech Vocalist 2 live. Power supply OK. Is there an internal fuse. etc? need tips to troubleshoot.
Dec 23, 2010 | DIGITECH VOCALIST LIVE 2
I am unable to sinc my digitech DC-1005 together and was wondering how to do it
Dec 17, 2010 | GPS
GPS Logo
14 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
