Question about Datalogic Heron D130 Handheld Barcode Scanner
Driver heron d130 - Datalogic Heron D130 Handheld Barcode Scanner
4 Suggested Answers
Noggin
  • 944 Answers
SOURCE: Datalogic Heron D130 (Barcode Reader) Header setup
Whether or not you can set this feature depends on which interface type you are using if you are using wedge interface then the procedure is described below: The extended Header/Terminator keys for Wedge Interface users can be customized by defining them through a simple keyboard setting procedure. For example, the Numeric Keypad keys can be set for use as Headers or Terminators by substituting the default extended keys using this procedure. The type of computer or terminal must be selected before activating the keyboard setting command. Press and release a key to set it. Some characters may require more than one key pressed simultaneously during normal use (refer to the manual of your PC or terminal for keyboard use). The exact sequence must be indicated to the reader in this case pressing and releasing the different keys. Example: If one has to press the "Shift" and "4" keys simultaneously on the keyboard to transmit the character "$" to the video, to set the "$", press and release "Shift" then press and release "4". Each pressed and released key must generate an acoustic signal on the reader, otherwise repress the key. Never press more than one key at the same time, even if this corresponds to the normal use of your keyboard. Press "Backspace" to correct a wrong key entry. In this case the reader emits 2 beeps. Note: "CAPS LOCK" and "NUM LOCK" must be off before starting the keyboard setting procedure. "SHIFT" must be repressed for each character and cannot be substituted by "CAPS LOCK". Check page 31-33 of the "heron reference manual", downloadable near the bottom of this link page; http://www.datalogic.com/_vti_g2_dwnlDett.aspx?idCF=1&idC=44&rpstry=13_ Hope this helps :)
Posted on Mar 22, 2007
  • 10 Answers
SOURCE: How can i turn of the beep sound on a Datalogic
scan beeper off code on page 60 of this manual...
https://easeofaccess.scanning.datalogic.com/public/marketlit/Send.aspx?file=90ACC1877
Posted on Aug 04, 2009
SOURCE: Windows Vista Heron D130 7.31.84 Installation
http://driversdownloadnow.com/Microsoft-Vista/drivers/
HiHope this page will be of use to youKind regards :)
Posted on Feb 07, 2012
We have a Heron DataLogic D130 Bar code scanner for our POS system. We have had them for 3 years with no previous issues until a day and a half ago. I just got a new computer setup with the POS softwa
Possibility is the that the engineers of your POS Software company are right, but we can definitely prove them wrong provided we test and, or check the same POS software or setup on a similar brand new computer.
Sep 05, 2014 | Datalogic Computers & Internet
HOW DO I ALIGN THE FRONT WEELS ON A D130
loosen up tie rod unhook tie rod from spindele turn tie rod in hook tie up to spindle see if straight if not repeat till straight make sure tie rod end is not bad replace if is make sure spindle not bent replace if it is
Sep 04, 2014 | John Deere D130 22HP V-Twin Foot Pedal...
Config
Quick reference is just for simplified configuration. For detailed configuration go to the reference manual.
Download:
Hopefully you know about Code families and specifications? If not - you can learn it here.
Apr 25, 2013 | Datalogic Heron D130 Handheld Barcode...
How do you network unlock a Blu Dash D130?
well got new blu dash3G 2.3 phone,and i put on a pattern lockand so many people was tryin to get into my phone so it got lock out and how can i get my phone pattern to get unlock
Oct 24, 2012 | Blu Dash D130 Unlocked Gsm Phone With 3g,...
Heron's formula
Heron's formula is used to find the area of triangle when the length of all sides is known.
Formula:
Oct 23, 2011 | Texas Instruments TI-84 Plus Calculator
The scanner doesn't read the barcodes anymore and makes a weird noise while we're using it. is there anything I can do to solve the inconvenience immediatly? thanks
We have had the problem, that the scanner generated a crazy sound after it dropped onto the concrete floor. I think the buzzer came loose. Best thing to do on a short time basis is to disable the beep via the manual.
You can find the manual here:
Jan 20, 2011 | Datalogic Heron D130 Handheld Barcode...
Mar 19, 2007 | Datalogic Heron D130 Handheld Barcode...
Datalogic Heron D130 Handheld Barcode Scanner Logo
37 people viewed this question
Top Datalogic Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Paul Bade
David Payne
David Payne
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
