Question about Whirlpool Dryers
I have a thermal cutoff kit 326F to repair my whirlpool kenmore dryer, but it came with very little instructions how do I step by step make the repairs?
I need step by step instructions for installing my replacement parts
  • 1028 Answers
SOURCE: replacing Kenmore dryer parts
that one is old enough to vote..if filter on top remove back find small hole on right just below top may be hidden by pasted on tech sheet..through hole insert long socket 5/16 or reach up from underneath with short ratchet and socket remove screws and attached wires lift element housing up slightly and pull bottom of housing out and down..5/16 screw on backside holdes element in
Posted on Jun 19, 2008
  • 115 Answers
SOURCE: HOW TO REPLACE A THERMAL CUTOFF ON ELECTRIC DRYER
you will need too take off your back panel of your dryer and the heater is on your right the thermal cutoff is on the left of the heater housing at the top and then there is a little white thermal cutoff on your blower housing in the bottom left of the dryer now if this is not how your dryer looks let me know cause there is several different style of kenmore dryers but this is the most common one
Posted on Dec 29, 2008
jsrock516
  • 5911 Answers
SOURCE: Estate by Whirlpool Dryer TEDX540RQ1
Check your exhaust ventilation for clogs.
A simple test that you can try is to remove the exhaust duct from the back of the dryer and attempt to dry a load of clothes like you normally would. The air coming out of the back of the dryer should be forceful and warm (about 140 degrees F).
If the air flow is good, temperature is hot and the clothes dry normally, then you need to inspect your ducting from the point where it leaves the back of your dryer, to where it exits your home. Check for any kinks, bends, sags or anything else that may create a choke point where lint can accumulate. In addition, you should be using semi-rigid aluminum ducting. It is crush and kink resistant, resists heat well and resists rodent intrusion.
If the air leaving the back of the dryer is weak, then you need to check the air blower housing INSIDE the dryer for obstructions.
Leaving a dryer in a clogged condition can actually cause the heating circuits to overheat to the point of failure. Not to mention, this can be a fire hazard.
Lastly, if you replaced the TCO, did you additonally replace the Hi-Limit Thermostat? These two components are mounted on the outside of the heater box and work in conjunction to regulate the heating circuit. It is strongly recommended that if either of these two components go bad, you replace BOTH of them at the same time to prevent premature failure of any components you replace. I've seen it happen on numerous occasions where someone buys the kit, but only replaces one of the two components and later ends up with a non-working dryer again. That is why they are often sold as a kit. You can find the kit at appliancepartspros.com for about $20 (part number AP3094244). Just type in your model number and look under the "Bulkhead Parts" heading for item 6.
If you have any questions/comments, please let me know. I hope this helps you.
Posted on Jul 30, 2009
  • 44 Answers
SOURCE: Have replaced heat element, thermostat, thermal
I'd like you to try something easy. Set the dryer to Air Fluff and see if the dryer still puts
out Heat let it run for about 2 full minutes If you dryer is still putting out Heat get back to me
Posted on Nov 20, 2010
  • 3074 Answers
SOURCE: Kenmore series 90 dryer.
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Posted on Nov 26, 2010
Thermal cutoff switch fails 2x in a year. Heating coil ohms out ok.
Whirlpool Thin Twin, dryer thermal cutoff failed twice - Appliance ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Oct 12, 2011 - 6 posts - ‎2 authors
Friends Whirlpool Thin Twin came with purchase of condo half a year ago. A month ago it stopped heating. I checked continuity and found the ... Whirlpool Dryer Thermal Cutoff
Jan 9, 2013
Thermal cutoff blew again (Whrpl Elect Dryer)
1 post
Jan 5, 2013
More results from forum.appliancepartspros.com
Why does the thermal fuse keep blowing in my dryer ...
www.shopyourway.com > Manage My Life > Questions
Dec 28, 2015 | Dryers
Where is the heating element for a Kenmore heavy duty 60 series soft heat large capacity?
How to Replace Your Electric Dryer's Heating Element
www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid Electric Dryer's Heating Element. Here's a common job that many folks are afraid of, but it's ...
Whirlpool / Kenmore Dryer Heater and Thermostat Test ...
? 7:40
https://www.youtube.com/watch?v=KZY9CQ_CqvY
Sep 13, 2010 - Uploaded by Bill Newberry
Basic checks for a Whirlpool made dryer. ... Whirlpool & KenmoreDryer Repair - How To Diagnose No Heat ...
Whirlpool - Kenmore - Maytag Dryer Not Heating Repair ...
? 2:42
https://www.youtube.com/watch?v=i95okOr2rOI
Mar 1, 2011 - Uploaded by ApplianceAdvice
It will explain step by step instructions on how to test the thermostats, fuses, and heating element inside the ...
How To Fix Dryer With No Heat ' Dryer Repair - PartSelect
Dec 12, 2015 | Kenmore Dryers
I have a whirlpool dryer that won't heat. I removed the heating element and there were no breaks in the coils. I had the thermal cutoff tested and it was bad so I replaced it as well as the part
check the little 1"long x 1/4" wide white plastic fuse located on the dryer blower housing in the lower rear area,its held in place with 1 hex head screw,if its open dryer wont heat
Mar 11, 2012 | Whirlpool Dryers
Have replaced heat element, thermostat, thermal cutoff, thermal fuse and cycle thermostat on whirlpool dryer. keeps blowing thermal cutoff! Exhaust is clear inside dryer and outside! What is causing all...
Nov 06, 2010 | Whirlpool LER4634J Electric Dryer
How to connect dryer wires to thermal cutoff
The first thing I would like you to do is get your model number from the dryer, it is located near the inside the of the dryer door. you need to make sure you have the right heater and thermal cutoff kit. The manufacture has more than one type of heater and thermal cutoff kit out, (( some will not work with others ))... Call another parts store or sears and make sure you have the correct parts !!
Most of the thermo cutoff kits have direction and if they are not making scence then the chance of you having the rong one is good !!!!!!!
If you remove the thermal cutoff from your origanal heater and then look at how many conetion pins are left. The new heater and old heater should be the same.
The most common heater is the 2 conection. But they made one with three. and if you have the one with three, it has to be replaced with the same one !!!
Without knowing the model of your machine, I cant tell you how to wire your machine.
I recomend you use the direction that came with the Cutoff kit.
Aug 11, 2010 | Kenmore 62602 Electric Dryer
Dec 29, 2008 | Kenmore 67082 Electric Dryer
Kenmore 80 Series Dryer - No Heat - Thermal Cutoff Kit 279769
that therm. will actually come off the heating element part, it is always good to change both, I use a small screwdriver to get it off
Nov 07, 2008 | Kenmore 63942 Dryer
Dryers Logo
55 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
