Question about LG DLE5955 Dryer
Dryer flow sensor shows 4 bars
LG DLE5955 dryer flow sensor has come on to 4 bars. I have disconnected the dryer from the vent and still show 4 bars. air is still coming out though and dryer is hot. Any suggestions
  • LG Master
  • 2,760 Answers
Lint trap holder has got some lint overflow caught down inside it ,past lint screen , I use a piece of small pool pump hose taped to the end of a normal vacuum to suck it out
Posted on Apr 21, 2015
  • 1894 Answers
SOURCE: Tromm DLE5955 dryer less than
did u do a hard reseet>?
Posted on Jun 08, 2008
  • 3422 Answers
HI,
Clean the lint screen/filter before or after drying each load of clothes. If clothing is still damp at the end of a typical drying cycle or drying requires longer times than normal, this may be a sign that the lint screen or the exhaust duct is blocked.
Please don't forget to rate or accept the solution.
SOURCE: Need to move the dryer vent on LG DLE5955 to the side opening.
Knocking out a plug in the dryer, taking ducting loose, moving it around, putting in some new pieces, etc.,etc. Mostly mechanical stuff -- not a teriffically difficult job. Would help to be handy, though.
Posted on May 03, 2009
SOURCE: LG DRYER 5955 W FRONT LOAD
Did you ever resolve this? I just took delivery of the same dryer and have the exact same problem. I have BestBuy coming out to look at it and I have a call into LG customer care and they said they will call me back. -Bill
Posted on Dec 31, 2007
I had the same prob. and got this from LG:
Dear James,
Thank you for contacting LG. We are delighted to hear from you as our Valued Customer. I sincerely apologize for the delay and any inconvenience you are going through with your unit.
I will be more than glad to assist you.
When the venting is just installed, in order to see the correct result in the vent testing option of your unit, is necessary to wait for 2-3 full cycles.
If after this period of time, the correct results do not appear, please contact us back via e-mail or call our Customer Service Department
If you have other questions or concerns, please do not hesitate to contact us again either via email, or by calling our customer service division at 800-243-0000 at your convenience.
Emely M.
E-mail Administrator
Customer Interactive Center
LGEAI
Posted on Nov 01, 2009
Drum turns..no heat
I would check inside and see the blower itself it may have lint or debris obstructing it, see if u can turn it by hand another thing to check is for full 220 at the outlet and terminal cuz if u only get 110 u will be able to run motor but have no heat
Mar 29, 2015 | LG DLE5001W Dryer
Dryer will not heat, It is not the vent, That has been thoroughly checked
one of ure saftey sensors has gone bad you need too have each one checked mine was hooked too a filter vent after i removed the back cover it can also be the heatind coil unit or sensor using a simple test meator can help.
Apr 09, 2011 | LG DLE5955 Dryer
Link is stuck in under the lint filter causing sensor on and wash taking 2-3 hours to dry
I believe your problem is not with the lint under the filter but with the exhaust vent in the wall being heavily restricted. The best way to test is to disconnect the exhaust vent from the wall and run a normal load. If it dries normally, you will need to have your exhaust vent professionally cleaned.
Good luck
Sep 26, 2010 | LG DLE5955 Dryer
My dryer is making a beeping noise while running. I stop it to check filter like it says and the filter is clean, then the dryer will not start and I have to turn it completely off to start it again
This happens on these if there is enough lent in the vent line as well. The excess buildup of the lint will decrease the airflow and cause the sensor to trip a trouble code. Try cleaning out your line and see if that doesn't help. Good luck.
Mar 15, 2010 | LG DLE5955 Dryer
Dryer is taking to long to dry. taking 3 hours to dry clothes
you nead to check the vent hose and make sure it is not pinched off,also check the vent hose from the dryer to the vent outside and make sure it is not pluged with lent.
Dec 26, 2009 | LG DLE5955 Dryer
Dryer LG DLE5955w
are you missing any socks? if so you need to throughly check the duct chamber in the machine, get it serviced this is a fire hadzard.
Jun 23, 2009 | LG DLE5955 Dryer
Items in dryer are not quite dry, cool down cycle is real short, heat is maintained in dryer when it stops and wrinkles clothes. Cool down cycle went from 4 minutes down to one, skipping 3 and 2. Same...
check and make sure it has a clear clean vent.no kinks in vent hose.if yours vents thru roof then you may want a chimney sweep to come and sweep your vent out.if it goes thru a wall check and make sure know blockage.
Mar 08, 2009 | LG DLE5955 Dryer
LG DLE5955 Dryer Logo
2,934 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
