Question about Dishwashers
On/off switch - Haus dishwasher WQP12-9250G - Dishwashers
What size hot fill hose do i need for haus dishwasher wqp12 9250g
All the hoses are standard washing machine hoses. Just pick one up in Home Depot or similar. The standard colour for hot is red, but white, black and grey are available.
Feb 06, 2016 | Dishwashers
Haus dishwasher
This sounds normal, what is the problem?
Dec 20, 2013 | Dishwashers
I just had a Haus slimline dishwasher delivered and have tried to set it up. I have followed the instructions to the letter but the water inlet hose keeps leaking out water when you move the dishwasher...
It is possible the dishwasher inlet is set for low water pressure.
Check the water pressure setting matches your inlet water pressure.
It might help if you provide the model number of the dishwasher.
May 31, 2011 | Dishwashers
Just bought a Haus 12 9250g off ebay worked fine on first wash but now goes straight to rinse program since put into position and does seem as if water is going in
just purchased a haus slimline dishwasher from gumtree just wondering if you ever found a solution to the problem as mine is doin exactly the same thing
May 13, 2011 | Dishwashers
My washing machine (HAUS WM1050 is full of water, it won't empty whatever cycle i put it on. How can i fix this??
Hi, i have a Haus WM1050s which is also full of water and will not drain. There is a cover at the front with NO filter behind it, just a large plastic screw (unsure what). I suspect the filter is blocked, does anyone know where it is before i pull the machine out please.
Thanks in advance
Alison :-)
Feb 10, 2011 | Washing Machines
I need a user manual for a HAus HW50-1010 Washing machine
http://www.manualowl.com/m/Haier/HW50-1010/Manual/180896
It seems that Argos recycled a brand called Haier (Chinese) and turned it into HAUS (German)!!
The washers are exactly the same. Manual is the same.
Jul 13, 2010 | Washing Machines
Dishwashers Logo
51 people viewed this question
Top Dishwashers Experts
